How to extend the life of my Trooper?
in Isuzu
I sure am glad that I found this site. I need some advice and the way I figure who else but those among us that own and love Troopers.
Here is my situation: I own a 2001 3.5L 4x4, that now has 215,000 miles on it, I have gone trough 4 sets of tires, and 3 tranny fluid changes, one tune up plugs etc, 1 set of shock absorbers,1 serpentine belt, pcv vlaves,one water pump, I used Mobil 10w30 full synthetic oil, K&N Air fileters and K&N oil filters, and that is ALL.
I have never been back to the dealer and dont plan on it either.
I plan on keeping this Trooper for ever. Even if it means replacing the engine, tranny etc.
Can anyone give my some advice on something that I need to change that I may have missed?
Should I do another tune up? My mechanic keeps telling me to wait for the truck to start running rough or idling rough???
thanks to all
thanks to all
At 215,000 miles it sounds like you're doing a lot of things right - way to go!
Have you changed the timing belt tensioner? I usually change the timing belt tensioner and water pump with the new timing belt. I am due foe my first timing belt replacement on my 2001 Trooper and if your tensioner has gone all 215K I think I might re-use my same one. Thank You BoxTrooper
I am also changing the shock absorbers, timing belt, water pump, hoses, serpentine belt, cleaning the fuel injectors, flushing the radiator. And others if needed.
What is your opinion on the tranny? Do you flush it and change the fluids?
Differentials? mine is 4x4.
I ALMOST sold my Trooper last week. Because I thought that I had to have a new pick up. My mechanic talked me out of it. I am glad that he did. I just hope that I can replace the engine when the time comes without to much hassle?
I need major help with my Isuzu Trooper 01'. Like most girls we pretty much dont know anything about cars, and i am one of them. I took my car for an oil change and they advised me to change my air filter (im @ 51k miles). So i agreed. They charged me about $100 for everything. Well now...its leaking fluid. My guy cousin told me it looks like transmission fluid. OH and when i was driving, it sort of jolted forward, like the rpm went from 1 to 4 just suddenly. i have no idea what to do or what this means. Guys, i will really appreciate any help. i love my trooper.
Get the fluid changed and flushed ASAP and hopefully it's just low fluid.
-mike
The only other possibility would be they drained the trans by accident, and didn't refill it completely.
I would bring it to a different shop and have them check and refill the trans, perhaps even a dealer.
-mike
I'm getting about 18mpg average consumption. Better on the highway.
More people spend countless $$ working on things that aren't broken + make their auto parts shop or mechanics fat + rich beyond belief... I KNOW FIRST HAND..
I worked on BMC, British Motor Cars, + never made more $$ than there..
Go take a class at the local Community Collage + learn how to fix it yourself..
That makes more sense than throwing $$ at another guy to fix stuff you can handle if you have the product knowledge.. Learn them + then you can be a pro like the folks who monitor this site... Right guys ??
