The 1121 code indicates throttle pedal position sensor issue, this devise is activitated by your throttle pedal -- the could be as simple as raising the hood and spraying the devise that is connected to your pedal wire with electrical contact cleaner and then ( with the engine off) working the Pedal up and down 5 or 6 times and spraying again and working the pedal again
I would appreciate your finding with the 1642 code since i have the same issue. I did rest my code and turned OFF the cruise contol switch to see if the code comes back on --- I will let you know
The P1000 code indicates the code functions are working. This code you should not be concerned with.
The P1111 codes indicates the code system has done a complete scan.--- This code likewise should be ignored for NOW.
The 1642 and 1121 could be just a bad connection at the PLUG of the harness between the ECM and the other devices
Unplug the connectors and plug them back together.. If you need more detail Eamil me at crpace@cox.net
Hope this helps
What did you do to fix this problem? Is it computer related?
should I try and get the computer re-programed?
Be sure and disconnect the battery before doing the ABOVE. Get the correct cleaners for the Throttle Plate and Map Sensor.
Please post if this works for you.
I do know that "ground" gremlins can cause strange problems on most any car.
2 cents
