Taurus/Sable Electrical Problems
                    I have a 2003 Mercury Sable (3.8 liter 24 value engine)after the car is driven for 15-20 minutes the battery light flashes on and off. The dealer has put in 2 new alternators and the battery light still flashes. The light will not stay on constantly. The dealer checked the battery and it is fully charged. It will not go on when the car is in park. There are no codes in the computer. The dealer says the light needs to stay on constantly in the shop. Then they can diagnose the problem. Can anybody help
My 2002 Ford Taurus has the door ajar light on constantly when engine is running. Also, the center light on iside of roof is constantly on.
I tried obvious things like slamming all 4 doors, and trunk, and hood, but no luck.I also turned the rotating switch to adjust intensity of dashboard lights and to manually turn on light in roof, but it is OK as well.
As a temporary fix, I removed the center light bulb in the roof, so I don't think I am draining battery.
This all started for first time today. Have been playing with it all day. No luck.
Everything else seems to be OK.
Any and all ideas for a solution are appreciated.
Dan
Stopped a local shop, didn't have a lot of confidence in them, but they offered to check the alt for free. Hooked up a device that measured the voltage, but it had a scale, not digital. He said it showed 11 volts, I notice it was in the "weak" section. Has me turn on the lights and stuff and nothing happened to the dial. He said that was because the alt was bad. I asked about the megafuse (between batt and alt. cables)and he said that if it was blown, nothing would work. Does that sound right?
He said I need a new alternator. He uses the brand A-1. Said it is 299 for the part because of the 24 valve, and it is hooked to the serpentine. I did notice on NAPA.com that the serpentine alternator was much more $$. He figured 4 hours labor, depending on how hard it is to get everything off to get to it. Almost 500 total!!
I left to think about it. Well, tried to leave, car wouldn't start. They got a device and basically jumped it, he said it was a boost and should get me home. Less than 4 miles later and I literally limped home the last mile. Seemed like the fuel pump was stopping, more idiot lights came on, the ABS and air bag came on first, by the time I got home the brake one was on and the radio seemed to turn on with static. I hope I didn't screw up some more......
Nothing was said about the computer except that the car wouldn't go if I blew that.
Can anybody shed some light on this? Is there anything else between the alt and the batt that could cause a problem, or is just a fried alternator and I am stuck with 500 repair bill? How to tell if I did in the computer??? Can they check the alt while on the vehicle by attaching volt readers to the alt?? I am so worried now that it is the computer.
Here's what happened. Your alternator is broken, that's the thing that keeps your battery charged. So you have been running off of the battery. The battery wasn't fully charged and you tried to limp home. Weird things happen as the battery depletes and the voltage drops. The car should be just fine once you get the battery charged up and a new alternator put in.
If you want to drive the car for short distances go buy a battery charger at K-mart and charge up the battery. Keep in mind though that you just may get stranded if you drive too far or go too long between charges. If you get stranded you'll have to call a tow truck or pull out the battery and take it somewhere and charge it up and then put it back in.
Isn't this getting old yet ? Just maybe it's time to pay the price and pay someone to fix your car.
Thanks everyone who helped, and there were a few, each with a slightly different tip. I hope this info helps someone else.
Thanks for the information that you had posted it. I just have a similiar problem with you. My MPV MAzda 2001 was suddenly slowdown on the HWY and then could not be started it. Then, i towed to the nearest garage. The mechanic told me, The alternator need to be replaced $ 550,00 brand new one + 2.6 hrs labor fee. I went to get a refurbished one cost me $ 220, then i gave it to the mechanic to replace it. The MPV is running now, but the Battery light is still on. The mechanic told me, some thing wrong with the alternator, but the alternator is charging. He suggested me to uninstall the alternator and bring it back to the shop where i got my alternator. Anyway, i spent almost $ 500, now they ask me another $ 200 to reinstall new alternator.. :mad: Could you tell me, which mega fuse (What is the code name)that located on engine compatrment fuse box that you had replaced and only cost you $ 5. I opened my compartment fuse box.. and i could not find any fuse that had a name like batterry... PLeaseeee... again
thank you.
TJ Wija
I thought mine oculd be a fuse because it received a large jolt of power that blew it when I put the battery in backwards. I have also heard that there is some sort of electrical part that is attached right to the alternator that can go bad. I think it might be replaced with the alternator though.
You need to have the voltage checked on the battery to see if it is charging. It should be over 12 volts with the car running.If it picks up a charge to 13-14 while it is running, then your fuse isn't blown and neither is your alternator. This is what I have learned!
Also, check your owner's manual for the schematic that diagrams all the fuses. Good luck!
Working hypothesis: wire in #8 circuit has broken and fused to ground, probably inside the boot connecting to the door (driver's side or maybe passenger side). Two other wires belonging to #14 and #4 have developed a high resistance short to one another, probably due to heat from #8 short or due to whatever caused #8 to short. So "Unlock" puts voltage on parking light circuit, and short prevents "Lock" from developing enough voltage to activate the mechanisms.
Questions: Does this sound plausible and if so, how do I find the shorted wires? Its impossible to get into the boot or anywhere near the cables leading to the boot and even if I cut the wires (LtG/Y) that run through the boot on both ends, how do I replace them?
If this isn't plausible, any other ideas are welcomed. Oh yes, why do the color codes on the wires not always correspond to the colors on the schematics, or better yet,where can I find a scematic specific to this vehicle?
Thanks for any help.
Hope this helps
I can not start it right after I turn it off.
But it has radio and light, and battery light is on also when try starting.
I can not hear any starting sound except a "click".
After wait for a while (after the engine cool enough???), it can be started without any problem.
Could any body know the possible reasons?
Thank you very much.
It seems the battery is fine.
Is there anyway to check the starter myself?
I just need this car for a coupole of months (looking for a new one). Thus jsut wanna keep expense on repairing it as little as possible.
I am going to have my car (battery, starter) tested in Autozone tonight. Not sure how good they are, but it is free anyway. Hope they can find out something.
Got the problem fixed finally. It was the battery all along. Apparently sometimes when the plates get weak in the battery they will hit together and causes the whole car to short out. The mechanic who fixed it said that he has had one other car to do this and that is how he figured it out. The battery will not show battery on the testers unless it is actually doing it at the time. Replaced the battery and it has ran fine for over a month now. So Happy.
Happy New Year.
1) The factory alarm system sets itself off under different circumstances. Leaving the car unlocked is the only way to avoid the problem.
2) The passenger window sometimes works and sometimes does not. The motor was replaced.
3) I noticed what appears to be a ground strap on the drivers side that is attached to the body below the windshield and then to the hood. This strap is broken. Neither of my 2003 Taurus's have something like this. Does anyone know what it is for?
Any suggestions? Could the two issues be related?
Thanks, Frank
Does anyone know where/how to do it? What part number is required? (Probably only sold to Canadian Dealers).
