Ford Ranger 4x4 Problems
I have a 1995 ranger 4x4,5 speed manual,6cyl, 4.0L. It has shift on the fly 4 wheel drive and when I put it in 4High or 4Low it doesn't engage. However the light o n the dash still light up. I want to know if this is a minor problem and/or what the problem is.
If it really isnt engaging, I would check out the motor on the transfer case that is responsible for engaging that part of the system. I am willing to bet the hubs are engaged, but the transfer case isnt.
I've been told that this may be a rubber bumper stop in the transfer case that is worn that allows the gears to "over shift".
My Ranger is a 1995, automatic, 4.0L, shift on the fly
When you start the eng to check the trans level it's checks OK (cold). But you drive the truck for just a few minutes then check the level the fluid poors out. I checked the vent tube and blew air in it, it does not seem pluged.
The truck has not been driven much.
any thoughts?
I flip the switch to 4-High, and the light switches to 4-High, but no power to my front wheels. Stop the truck, put it in neutral, flip it to 4-Low, and it switches over. I can feel the power difference because it gears lower, but still no power to the front wheels.
First time I found this out I was off-roading and got stuck in some sand. My roommate was with me and noticed that my rear wheels were kicking up all kinds of sand but my front wheels weren't moving at all, even though I had supposedly had it in 4-High the whole time. Any thoughts? A friend who's a mechanic said he's almost positive it's the hubs, and the local Ford dealership says they can replace the hubs for about $300 but I need to make sure before I spend the money. Totally appreciate any help you guys can give!
Hub the likely culprit. I'll know more in a day or so.
best of luck,
Kevin
and if the motor is working you can install manual locking hubs see here
http://www.baseline4x4.com/proddetail.asp?prod=15001.70
Is the ranger rear wheel drive while in 2 wheel drive, or front wheel drive?
I know this is real simple question, but thanks for any input.
kcram - Pickups Host
Kevin
I think the truck is officially P.O.C.? (Piece of Crap) I have to add oil to every other fill-up as well as antifreeze I know the oil/ antifreeze problem is to expensive to fix. ( i'm not a mechanic) Is it the powetrainthat I screwed up or something else? and how to go about it to get it fixed.
Is there something that I can try to correct the problem myself or is it a quick fix in the mechanic shop?
I use this truck mainly for bowhunting (seasons winding down) and hauling stuff back and forth which is not to often. It is nice to have for a back-up vehicle.
is it worth fixing or try and sell it and be up front with the potential buyer about the engine problem and powertrain.
sorry about the loong posting and thank you advance for any suggestions.
With my 95, I am able to hear the shift if I activate the switch with engine not running, and radio. fan, etc off. If you can hear that, then the fuses are likely good, but it doesn't take much to check them anyway.
good luck,
Kevin
have a good christmas
Randy
i read other post & was happy about the fuse under the hood!! dont have the fuse under the hood. only 95.000miles. with the exception of a little rust around the rear wheel well, the ranger is in excelent cond.
:confuse:
I really need help with this problem i live in N.E PA. ALL THE POST HAVE SOMETHING FOR 93 AND BETTER. I cant for the life of me figuer out why the four wheel worked before i had the valve cover gaskets changed & not now. what could posabley happend?
Otherwise I'd start out with a volt meter or test light and start following the 12v until you can't find it anymore. Maybe you aren't getting power to the 2wd/4wd selector switch, maybe a loose or corroded connector somewhere in the system.
Good luck!
Kevin
best of luck,
Kevin
When shifting out of 4WD into 2WD, try doing so when stopped, back up a short distance, then proceed forward and see it that solves your problem.
good luck
Kevin
1)check to see if power is getting to shift motor.
NO? a) fuses
b) wiring/connectors
YES?
a) hubs
best of luck,
Kevin
Because we jacked up the truck, put it into 4x4 and you can grab the wheel and stop the wheel comepletely.
