Chevy Silverado and GMC Sierra Crew Cab Experiences
Will be in the market for 05 or newer crew cab LS, 4x2. Anything I need to look out for on any of those model years, pro/con to any of those certain years. Thanks...
1offroader
2. Is it ok to run dextron III in the 4 wheel drive transfer case?
Since we have to guess as to what year your truck is (and yes it makes a difference) have you tried reading your owners manual for that info?
How abou the Dextron III in the transfer case? This is what a parts house recomended.
If you look under the maintenance schedule in your owner's manual, it should provide the recommended maintenance items based on mileage/date. When it's time to replace the dextron III in the transfer case there should be a page next or before that tells you what to use when replacing the transfer case fluid.
