Mazda 5 idle shake
winnieking
Member Posts: 10
Is a slight shake at idle normal for 2007 Mazda 5? I can feel it in park or in gear at stop light. Not sure whether to take it to the stealer. Also feel slight shimmy under my seat between 55 and 80 mph. Two wheel balances and it's still there. Everything else is great so I'm hesitant to make a stink.
Anyone?
Anyone?
Can you describe the shimmy you refer to.
I'm not sure exactly what a shimmy is.
it could be a front end alignment issues though
that would appear as a vibration in the steering
column.
I do have your first problem where the car idles non-smoothly sometimes.
Did you try it?
I found that it idles perfectly smoothly in park but
in drive (with the brake on) there is a small shudder
every now and then. Your situation sounds worse.
Try the link above. If no good, navigate to "Vans & Minivans" section of this forum, then "Mazda MX-Flexa/Mazda5", then look for thread 1064 through 1066.
Have not had the time to try this - it's too darn cold!
Good Luck
The wire that is on the driver side inner fender structure is NOT the main grounding point for the engine, it is the grounding point for the battery.
