Do you currently own a 2019 or newer RAM pickup? A reporter would like to speak with you. Please reach out to [email protected] by 1/27 for more info.
Mazda MX-5 Miata Starting and Stalling Problems
My Miata keeps stalling while I'm driving 60+ miles/hr. Nobody can figure out what is wrong. Mazda isn't claiming up to what is wrong.
Help!!!
Help!!!
We just bought a 2001 Miata with an automatic (a compromise demanded by girlfriend), and I am having the exact same problems with stalling as are jerseygirl137 and caledelaney. Miata.net has some discussion about "idle dropping" and Mazda's seeming unwillingness to acknowledge this problem, but no definitive solutions.
My dealer mechanic is not sure and says we must go down the list replacing this and that beginning with the cam sensor, then the fuel pump, and then the coil. And even then he cannot say if the problem will be solved.
Has anyone else had this problem, and even better, how has it been resolved? If you know any talented Miataphiles or mechanics who might be able to help, please forward them these emails. Please help, we love our Miata, but this problem might literally kill us on Atlanta highways filled with 80 mph tailgating SUVs and semis. Thanx for your help - J
I also had this problem and after much research by my mechanic (mainly) and by me (secondary) we figured out what the problem was. It is the Cam Position Sensor (CPS) and it appears to be a common problem. Many websites have information on this and several of them refer to Miata.net where you can find all kinds of Miata-based information. Here is a link of what someone wrote about our same problem:
http://grassrootsmotorsports.com/news/082005/cam-position-sensor.php
The part is roughly 80-100 dollars although a mechanic may charge more for it (mark-up). Labor isn't tough and should maybe run you another 80-120 dollars.
Hope this helps.
Cheers,
Paul
Your problem is the Cam Position Sensor (CPS). It probably needs replacement. The part should cost somewhere around $100 and labor about the same. See my other post to another person on this same message list for more info.
Cheers and good luck,
Paul
hope this helps out
Miatas are known for timing chain to "go" @ 60k hopefully you have a decent relationship w/the prev owner and you can find out what kind of modifications were made prior
Patrick
'00 Silver
Finally, I removed the throttle body, and found the inside of the plenum behind it coated with an oily mud. The crankcase ventilator (PCV valve) spits a little oil mist in there. Then the super fine dust that finds its way through the air filter turns that into mud. I cleaned as much as I could reach and the throttle valve. That didn't fix it.
But after thinking about it, I figured some of that oily mud may have been partially bocking the idle bleed needle valve, or the idle bypass (both located in/on the throttle body).
So I opened the idle bleed a lot. That fixed it. I reset the faults again, and they didn't come back. So my car idles perfect (like new) and there's no Check Engine light on.
The idle bleed needle valve is a phillips head screw, that's recessed in a hole, facing the passenger side on the top of the throttle body.
As far as the underlying cause of the problem... The PCV valve worked fine. So I assume an oily film is normal in the plenum. I upgraded the air filter to a K & N to hopefully reduce the fine dust.
My sister has been driving my Miata for some time now and yesterday the car stalled (she is not sure why) but it got towed home. Today I came to check it out and at first, when I started it up the check engine light was on. The problem I noticed is that the car starts up fine and it idles fine, the problem was that when I step on the gas it feels like it starts dying (like choking) so I have to let go of the gas for it to idle again. I started checking spark plugs, oil, etc but everything seemed fine. I kept trying to give it gas and eventually I was able to get it going to where the engine would not die when I stepped on the gas. Took it out for a ride and it seemed like it was running as if nothing had happened. I thought it was fixed, but the problem came again when I shut it off and started it up again. This time the check engine light was gone, but now the problem is that when I press the gas pedal the engine will "purr" (rpms go up) but then it will stop and pause and then it will "purr" again. So even if my foot is fully pressing the gas pedal (and staying pressed) the car will do "purr" pause "purr" pause "purr" pause "purr" etc. So it feels like it will not hold the throttle. I tried taking it out for a quick ride to see if bringing the rpms higher would help, but the car ends up sort of stalling. As I step the gas it does the "purr" pause "purr" thing in first then as I shift it to second it sort of hesitates; so it starts to accelerate then stop then accelerate again as if it was about to stall. When I stop and let go of the gas it idles good.
I tried replacing the plugs, cleaning battery, checking throttle cable, etc but do not know what is wrong or how I could fix/diagnose what is happening. Anyone have any ideas?????
p.s. SHe noticed that it started getting bad as she was driving in the rain, I also noticed that the exhaust as it was warming up kept throwing whiteish smoke and water drops from it. Not sure if the rain has something to do with it (i.e. water in the engine)
My educated guess is it's the spark plug wires. Those only last ~30k miles on the Miata. I'm already on my 3rd set.
Spark or fuel, as they say. If the fuel filter is not clogged up and the fuel pump is OK, it's probably the spark, so I'd look there first.
:mad: :confuse:
You've replaced the plugs, so next thing to check are the plug wires. I've replaced mine twice already (every 30k). That's most likely.
Do the 99s have an ignition coil? If so that would be my next guess.
Beyond that I'd look at the fuel system - filter, fuel pump, etc.
So the car was taken back to the garage (towed) :sick: and the mechanic ordered a new ignition coil saying 'that should fix it". Jeez I seriously hope so. Can an ignition coil really be the problem? Wouldn't sulphur smell lead to the catalytic converter? :confuse:
I live in a super small town and the closest Mazda dealersip is 3 hours away! I haven't taken that route because I totally trust my mechanic -he's not a swindling type. I just want to know as much as I can. Knowledge is power.
Basically you replace things in order of cost, cheapest stuff first.
Fuel filter is already replaced and the ignition is also checked, nothing helped. Ron, do you know what caused the problem?
Thierry.
They have TWO coils driving 2 cylinders each. The coils in MX5's/ Miata's begin to fail, not by dying by by DIMMING. (Induction dimminishing intermittantly) As the spark in one coil becomes weaker with it's partner coil, your car Will idle erratically on TWO cylinders. (Engine also 'pinks' as lack of spark uses the compression to finish the explosion, once its at the top of the cylinder movement) The failing one IS producing a spark, but is a little dim orange one not a big blue BANG! The fuel doesn't completely burn and gives the illusion of the Fuel/air ratio been out. (You can smell raw fuel yet normal exhaust at the same time) The computer is constantly trying to adjust the fuel to match the info from the caddy convertor, which is a mixture of 2 correctly burning cylinders and 2 that are filling with raw fuel. Hence- idle up down, purr, choke, stall etc. Then it will not restart as the plugs have drowned in unburned fuel deposits and raw fuel and the spark is too weak to combat this. The failing coils primary resistance is too high from being hot, ie 2.0 ohms + instead of 0.72 to 0.94 ohms to chuck out a good spark, which is why it restarts when it cools down. Then, wherever the weak link in the coil is can suddenly make a good contact again- and away she goes for another year... then suddenly... she won't restart after a short run...(#$%@**#)
I was fooled doing the 'It's either fuel (theres tons of it) or no spark" tests, as when removed, the plugs WOULD fire when the lead was attached to the plug and the plug earthed on the engine to test. I finally noticed when faulting, 2 cyclinders produced a blue bright spark, and the other 2 produced a dim orange spark. The secondary coils (that the leads plug into) read 12k ohms each as they should so had not been investigated further. I took the coils out completely (easy as- took 2 minutes) and measured the primary coil underneath the housing and got my answer. (finally- $4 grand of repairs that never worked later...)
The car has not run correctly for 9 years and today, after putting new coils in (20 minute job to change wires over and install) and she goes like a bat out of heck now. DON"T just do one coil... do both.
Once this is done, check you have the NKG B5 sparks- (Cold plugs) not the NKG B6 (hot type) as they self clean really well. Both are specced by mazda- but are factory fitted with the B5's..Then short a wire between GND and pin 10 in the Diagnostic plug to by pass the ECU and see if it idles at 700-850 revs at full temp. If not, you mixture is out, and the air bypass is the screw under the cap on the throttle. CAREFULLY - Clockwise is richer (lowers the revs) and anti clockwise weakens the mix (increases the revs at idle) You will hear the air start to 'wisk' thru the manifold when you start to get it right....After this, the computer will run your car correctly.
I chewed the ear of my Mazda dealer / repaired today, and he finally ADMITTED they had known that the coils cause this fault in many many many MX5s and have replaced TONS of them with all the symptoms described in this forum.... but are encouraged to blame the fault on the cars been just old and encourage the owner to purchase a new engine as the fault could be 'Anything' (yeah right). I am being 100% serious that he said this..
Good luck =)
My car is in the garage (again) at the moment, still for that problem. I have already replaced one coil that completely failed, BUT not the other one!
With some luck I can finally have it fixed.
Because people I have the same problem, I have a Mazda mx3, It doesnt start, well sometime it starts and then it dies, I hit on above 2 - 3 Rpm and it dies, I dont know what the problem is, We changed the gas tank and we charged the battery also. But we havent figured out what the problem is.. Can SomeBody help me.
Thanks. Alrassam
Could be the fuel pump, or a bad fuel filter.
On the spark side, how old are the spark plugs? My Miata also ate through spark plug wires every 30k miles, that may be the most likely cause if the wires are older. Beyond that check the ignition coil, too.
I bet it's your spark plug wires.
I have a MX-5 California -2001 and, guess what? It starts first thing then, after about twenty mins or so it starts to lose power and stops!! No engine light, no smell?? Have changed the puel filter, crank sensor and also had the coils renewed today and on the way home stoped for about ten minutes then wouldn't start again, after abou a half hour wait it started and got me home- I'm tearing (whats left of) my hair out. I don't know what else to change, I'd like to change the car but if it won't start I can't sell it!!
Any experts out there please cuz Mechanics don't seem to know whats wrong.!!!!!!!
How old are the plugs and plug wires?
Does anyone have the solution? Please e-mail: M_Maxey_2000 at yahoo dot com
Ah, the good ol' Italian Tune-up.
http://forum.miata.net/vb/showthread.php?t=274730
Down the page some is even a photo of where to find the CPS if you don't know where to find it already. It's SUPER easy to replace and will probably cost you about $80 - $100 for the part. Undue one bolt, slide out the CPS, slide in the new CPS, tighten bolt ... you're good to go.
You can pull the CPS out, give it a good cleaning, chill it with another cars A/C or another way, stick it back in and see if that temporarily helps. It might but you probably just need to get a new CPS. This problem is so common it's unbelievable. They need to recall the car over it. I just don't think there have been enough complaints. If you would like to file a complaint with the NHTSA then you can either call them or file a report here:
http://www-odi.nhtsa.dot.gov/ivoq/index.cfm
Hope it works out for you.
Cheers,
Paul
I need more ideas...
I misspoke when i said I replaced the fuel pump, I did not. I replaced the filter. It's still hard to believe that's the culprit because I can rev it and accelerate just fine until the engine gets warm and then it fails. Is it really the fuel pump?
Where is the idle air control sensor on a 99?
