Toyota Tacoma Starting/Stalling/Idling Problems
I have a 2000 v6 Tacoma. Three days ago I could only get it up to 60mph. Then it started running fine. I drove it about 100 miles an no problem I drove it a litte the next day with no problem. The third day I could only go about 40 mph. I changed the fuel filter and it ran fine. I went out to start it and it would not start. It has spark. I also unhooked the fuel line and it shot gas every where. Hook the gas line back up and nothing. It will turn over and not start. Need some help
I took it to the dealer a few months ago, and of course they said there was nothing wrong. I read in a few threads in this webpage about the same problem with 03-04 Tacomas (see message #1976 at the Toyota Tacoma: Problem and Solutions), and it was somehting about the "fuel suction assembly". Does anyone know of any TSB's regarding this problem for '06 Tacomas or does anyone know what could be wrong?
I have had a tune up, fuel system flush. They checked the coils. Still nothing. It's at the shop now and the bill is growing! Can any one help?
My pickup (4 cyl., manual, 235k) runs fine in cool weather. But in hot weather, after running for a while, it often won't re-start after being parked briefly. It will turn over but not catch. A couple of mechanics haven't been able to spot the trouble.
This has been going on for a couple of years & I just deal with it. With about a five minute wait and another attempt it usually starts OK.
Ideas??
Thanks for your time,
Shadetree41
good luck. replaced fuel pump and all ok.
good luck.
In the beginning of diagnosis, I found that a ground wire on the right turn signal will turn to power when the blower motor is turned on, (this is when the truck stalls also). So I know I have a ground shorted to hot. The only thing I have left in the complete circuit is the ECM, that is the only place that the blower circuit and other circuits could possibly be related to eachother. Help me Please.
SKPK
Of course I can never get it to happen at the garage...
On a warm or hot day, after it has been driven for a while, it often won't start again after it has been parked for a while. This is not an issue in cool weather.
It does "turn over" (the starter is running) but the engine does not catch and start. It's hard to say for sure, but it seems like if I flood it a bit while cranking it over, it will SOMETIMES catch and start. So maybe it is a problem related to heat and the fuel pump.
I, too, have had it at the mechanic with no success. Open to suggestions.
To double check it, when it won't start unplug the sensor (electric clip) and it should start, it will trip the check engine light, but it fires right up. Once it was running I plugged it back in and it still worked. The part is $45 to $70 depending on mfg or store, anyone can replace it without tools. good luck
2.4 4 cyl manual
I did the "pull positve lead to batt while running and see if it stays running test" it did but when I tried turning on a/c and headlights the engine died.
Any ideas?
