Visitor Agreement.
-Frank P.
Ed
I am not sure if it is a good idea to add in lo range gear to a turbo forester. The turbo will not kick in until 4000rpm. The car will not have too much torque at the low range. Actually I even do not feel adding a turbo to Forester is the best thing to do... twin turbo will be a much better idea. WRX Wagon is still a better choice. Not even mention it has a big mod potential...
-bear
Otherwise what has been stated above is for the most part true.
Gene
Ken
Just wondering. It's been a slow afternoon here at work.
One more thing about the turbo. Turbo engine has a lower compression ratio. It has less torque than a NA engine before the boost comes. The car will not behave like a 2.0L NA commuter car at low rpms. It is not a VTEC.
As for the sales numbers go, I know Carr in Oregon is the No.1 dealer in the states. Stevens Creek is No.3. Van Bortel in NY is No.5.
-bear
I am wondering if Subaru will ever put a second low pressure turbo to Forester then this will definitely make it a killer car. H6 engine may be too heavy for the car so a sequential twin turbo 2.0L or 2.2L will be the best solution. well... keep dreaming.
-bear
What's holding back the H6 in the Forester is probably a combination of emissions and cost.
Ken
Bob
The turbo has sold well in australia for several years. Reliability has never been mentioned as an issue here on Subaru Turbos, even when used on Police Pursuit cars. Interesting point though that they are not sold with the Dual Range transmission fitted to other Foresters. The torque curve is not appropriate for serious off roading. Much better for highways and fast dirt/mud
Cheers
Graham
Bob
Funy thing is that the PT 4wd over here w/Hi-Lo range had 1.8Ts
-mike
PT's 1.8 turbo has a low pressure turbo which kicks in very early. It is alright to fit it into the low range system. Same for VW/Audi's 1.8T if they choose to do so.
-bear
-mike
Might try that for the Subaru windshield. Ya never know.
I just bought my 1999 Forester on Saturday, and am happy except for one thing I noticed. Seems the Door Ajar light doesn't go off all the time. This weekend, on several occasions, I had to go around the car and try closing all the doors again and again before the light would go out. The doors all closed fine, just seems like the computer isn't sensing them properly? Is this a "known issue" of any sort, or do I need to talk to my dealer?
-mike
SubaStates? I've never been to Colorado (hope to someday), but Vermont is simply swarming with Subarus. Seriously, you cross the border from Upstate NY and instantly the roads become narrow, houses become quaint, and the big SUVs all become Subarus. Aside from that, Vermont is just plain wierd.
YetAnotherDave
I'd like to see the 217hp in the Forester XS Premium, at least, for about the same money, maybe $300 more.
But a 2.5l LPT would be even better. I'd be willing to pay an extra grand for that.
Especially when you consider it could be "chipped" to produce serious power. :-)
-juice
If it's one of the four doors, then only the main dome light will be on.
(This is assuming that both lights are set to the "Auto" position.)
- - Elliot
I got the loaded-to-the-hilt XS Premium with leather, with packages 1, 2, and 3 plus premium sound package 2, for a total sticker of $27,310 and I paid only $25,097! They had one on the lot with 1.4 miles with every feature I wanted in the color I wanted - Platinum Silver Metallic (looks great with the dark gray bar across the trunk, C pillar, and mirrors). After all that, I even got them to throw in a side cargo net and wheel locks, too!
Let me just say for all you lurkers out there, this is a wonderful car. Having driven a '99 Forester for the last 3 1/2 years, the improvements are obvious. Nothing inside or outside the car hasn't been tweaked in some way, whether functional or cosmetic. Despite being the same powertrain, it still felt smoother, peppier, and quieter.
I can list only 2 minor complaints for things I liked better in my '99:
1. The coin tray is now smaller and is too narrow to fit my coin dispenser. (Boo hoo. The armrest extension is now much larger, and it fit fine inside there. I actually like it better there!)
2. The tub that fits inside the spare tire that is handy for filling with ice and such is now divided into two halfs, so you can't fit anything large in it. I had stored a small air compressor in that space, and now it doesn't fit. (Solution - I never used the tub anyway, so I took it out. Problem solved.)
That's it. Those are the worst complaints I could come up with. I LOVE this car.
For those of you that are interested, below is a list of differences/improvements between my 1999 L and my new loaded 2003 XS Premium. In case you're wondering, I didn't type this list in just for your reading enjoyment, rather this is the list I made to quantify the vast number of changes so I could convince me wife to let me trade in my '99 for it!! It worked, so might I suggest you use this as a template to do the same to your significant others?
1999 L vs. loaded 2003 XS Premium; in no particular order:
1. Heated seats
2. Heated mirrors and wiper defroster
3. 6 disc changer; Weather band radio, 12 FM presets on radio
4. Improved audio quality (speakers are better)
5. Automatic climate control
6. Cupholders in center console
7. Interval rear wiper; Variable interval on front wipers
8. Seatback map pockets
9. Improved drag coefficient (better fuel economy; less wind noise)
10. Larger front brakes; Rear disc brakes (improved stopping and feel; less fade)
11. Increased seat travel, height adjustment, bolstering and lateral support
12. Seatbelt pretensioners and force limiters; active headrest anti-whiplash system
13. Dual mode trip odometer (A & B settings); trip and lifetime odometer both visible
14. Larger back seat with much more toe room
15. Center 3-point seat belt and headrest
16. Leather seats
17. Slightly larger cargo capacity & greater clearance under cargo cover
18. LATCH/ ISO-FIX anchors for front-facing child seats
19. Vanity mirrors in both visors
20. HUGE sunroof
21. Antennae built into window
22. No annoying slats and ripples in roof (MUCH easier to wash and wax)
23. Side head and chest airbags; front 2nd generation dual-stage airbags
24. Stiffer, lighter hydroformed chassis (better crashworthyness & fuel economy)
25. Illuminated ignition key socket
26. Illuminated power window controls in all 4 seats
27. Daytime running lights
28. Oversized side mirrors
29. Security system pleasant beep instead of loud chirp; all doors open with double-click
30. Quieter tires and improved sound isolation
31. Upgraded aluminum wheels
32. Leather-trimmed steering wheel - soft and comfortable to hold
33. Padded armrests on doors
34. Increased leg room in front seats
35. Air filtration system
36. Electronic Brake Force Distribution (EBFD) - shorter, safer stops
37. Rear limited slip differential - improved AWD performance
38. Remote fuel filler door
- - Elliot
-Frank P.
Steve
I don't remember the details, or even where I got the information, but by changing a few DIP switches, I enabled a feature that locks your doors when you turn the car on and unlocks them when you turn it off.
I believe the OEM keyless entry for Subaru is still Code-Alarm/Chapman, but the system has likely changed since '99 and I don't want to tinker around with it unless I actually get some documentation.
Anyone have any ideas if this can be done? (I believe this is the same system in the 2001 and newer Foresters.)
Elliot
-Frank P.
-Frank P.
In the three days I've been driving my Forester XS, here's what I've observed with the Auto Climate Control:
In order to get the temp down quickly, it starts off in recirc mode and really blows like crazy. As the temp comes down, first it lowers the fan speed, and then if it thinks it can maintain the temperature, it will disengage the recirc mode.
Yesterday, it was 87 outside, and it never turned off out of recirc, but this morning (75 degrees, it did.)
If that's a problem to you, don't worrry - you can use every feature of the climate control in manual mode as easily as a regular climate control. So if you're stuck in traffic and need it in recirc, simply turn on recirc. But then you will need to manage the fan speed and temperature yourself, of course.
- Elliot
Elliot: yes, I know I can switch to manual mode but then I wonder why to pay for a feature I don't use?
You see, I'm already mulling over whether to get X or XS version of 200X Forester, when my baby Silvius hits 100K mi...
Like Frank, I copied your list to show the wife when it comes time to justify the upgrade. ;-)
-juice
The Foresters have a "theater style" dome light that stays lit for about 5 seconds after the door has been shut if the car is running, and about 30 seconds if it is off. They gradually dim to off in about 3 seconds. How long is yours staying on?
I'm inclined to agree that you simply have a bad switch somewhere.
-Elliot
Well, look at it this way, with all of the other improvements and upgrades from the 2002 to 2003 at almost the same price, think of the automatic climate control as a "free" bonus and you won't feel bad about paying for an XS! (I think it's almost worth it just for the 6 CD changer and the heated seats.)
Besides, what I meant was you can use it in manual mode when you disagree with it, but in normal conditions outside of your commute, you can still enjoy it in auto mode.
- Elliot
Now that we have 2 Subies, we don't have that problem any more.
-juice
It's correct that the ACC mode defaults to Intake, except at system start when there is a large difference between inside/outside air temps so it switches to Recirc. I don't know of any way to change this.
I too hit the Recirc button often when following a pungent vehicle. I must admit I haven't paid the system a lot of attention, but have never noticed that the auto feature disengeges from the fan and temp controls when manually switched to Recirc. I believe (it's hard to be certain because the system works so well, so unobtrusively) that choosing Recirc manually simply controls that one parameter, leaving the automatic system to continue to sort out the fan and temp settings.
I would expect the Forester system to behave similarly.
That being said, I also have to admit that I prefer the Intake setting, so unless there is a particular reason to choose Recirc, I do leave it alone. The above description applies to three other cars with ACC I have owned, dating back to 1982.
Steve (with Bean)
-mike
Bob A.
Yak & Thule make some adapters that fit on some existing racks. Not as strong, but would a little shorter than using their towers. But that's probably the same as the Subaru round bar adapter you mentioned.
Steve
Anyway, I was wondering whether I caused any permanent damage to the transmission, or is it already too late? if the transmission fluid is already burnt did I already screw up the transmission. I probably drove about 400 miles (long commute), not very aggressivley, until i noticed the problem. There does not appear to be any leaks anywhere else on the transmission except for a small one around the filter. And does has anyone know where to get a new transmission filter and drain plug gasket for a 2001 forester? I checked a couple of autoparts places but they don't stock it, i think because it's too new. Is it the same as the previous model years? I'm afraid to take it to any quickie lube place anymore, does somebody knows a good subaru mechanic in So Cal?
If so it will be fine. I did something similar with my XT6 AT last year, after I added the fluid it was fine, took it to get it flushed out and what not, and it's been running 15K since then w/o problems.
-mike
2. Leather vs. cloth. Any comments?
3. I'm planning on getting the tow hitch. I noticed it is Class 1. The subaru bike rack only holds two bikes. Yakima has some 2-bike racks and some 4-bike racks, which they say can only hold three bikes for a Class 1 hitch. Is there no subaru option for 3 bikes?
4. Rear window dust deflector. Seems to ship as pre-installed equipment on many at the dealer. Is there really much advantage to this option?
I am considering an XS Premium with the following options. Any suggestions/comments?
Silver or black. (gray interior)
Possibly leather,possibly rear window dust deflector, possibly differential protector, trailer hitch, possibly bike rack, popular package 1 (bumper cover, cargo tray, splash guards), popular package 3 (air filter, cargo net, armrest).
Any idea where I can see pictures of a silver XS premium w/monotone?
burnsmr4
Dealer installed aftermarket alarm, I know several people who have this feature on their vehicles. Or it could be a result of GM INFLUENCE on Subaru, since most GMs do that.
-mike
Options:
1) We have the rear diffy protector because we camp alot. We go off-road, but not off-trail (a distinction I'd like to introduce to the general language. "Off-road" is so diluted that it's meaningless these days...) Not really a necessary item IMHO, unless you expect to encounter unforeseen obstacles with some frequency. Deep snow alone doesn't justify the expense, if you ask me.
2) Personal preference thing. We don't like leather because it's hot in the summer and cold in the winter. It does hold up better, and it's easier to clean.
3) We have a Draw-Tite class II hitch. Beefier than stock and cheaper too. Perfect fit. Bought it through Sportsrack. 7 bolts @ 58 ft lbs plus a little futzing around with the charcoal canister - about a 1/2 hour to put it on. Doesn't change the car's ratings of course, but guaranteed not to fail because you'll be well within its limits.
We went with a SoftRide Access LT bike rack for it. Fits 4 bikes, very versatile because you can get other components for it (ski's snowboards, even a grill for tailgating). Has a patented system for keeping the bikes level when you pull it out to gain access to the hatch, and for loading the rack if you're short (my wife is on the petite side). Bought it at REI, price competitive with Yakima and Thule. Bought a Yakima lock set so that the lock matched all of our other Yak stuff. Much easier to load the bikes than on the roof.
4. Seems to help. Had it from the beginning so can't really tell, but others have reported an improvement in keeping the rear glass clean after adding one.
5. Options close to what we got. Looks good to me.
Hope this helps, sorry for the long post...
-brianV
