Crossover SUV Comparison
19091939596142
    When hauling 6 people, I'll bet you'd be very glad to have the extra torque and power.
  • zman3zman3 Member Posts: 857
    I'm curious; is the Acadia/Outlook/Enclave transmission in any other GM vehicles?
    No.
    Is that true? The exact transmission with the same gear ratios, etc may not be, but aren't all GM (and some Fords) 6 speed tranny's based on this same architecture? The 6 speed is showing up in quite a few GM vehicles now. I think it depends on what is meant by the same transmission.
  • vad1819vad1819 Member Posts: 309
    "The TaurusX will give you the same headroom and greater legroom than the Acadia......."
    I can agree with headroom but not with legroom. The number that you see on web, shows min legroom, it because 2 row is adjustable (slide forward), plus TX much tighter inside (shoulder space). So, we were agreeing in this forum before, that the Acadia is biggest CUV today.
    "I'm curious; is the Acadia/Outlook/Enclave transmission in any other GM vehicles?"
    General Motors and Ford Motor Company teamed up in 2002 to create a new automatic transmission design. The 6-speed transmission was developed after each company contributed US$720 million to the effort. It is a compact transaxle designed for transverse engine applications in cars and light trucks.
    Ford claims the 6F is designed to handle 300 hp (224 kW) and 280 ft·lbf (380 N·m), while General Motors rates their 6T75 to 315 hp (235 kW) and 300 ft·lbf (407 N·m).
    The first application of the technology is the 2007 Ford Edge and Lincoln MKX crossover SUVs as well as the Saturn Aura sedan and Saturn Outlook crossover.
    Later:
    GM:
    2007 Saturn Aura XR
    2007 Pontiac G6 GTP
    2007 Saturn Outlook
    2007 GMC Acadia
    2008 Buick Enclave
    2008 Chevrolet Malibu LTZ (LY7 V6 Option)
    Ford:
    2007 Ford Edge
    2007 Lincoln MKX
    2008 Ford Taurus
    2008 Ford Taurus X
    2008 Mercury Sable
    I think the IIHS should re-test the Taurus X.
    The front offset crash test in particular is likely to produce different results than with the Freestyle.
    Think about it - new engine, new engine mounts, new transmission. Plus, a CVT was replaced with the 6F automatic. Those are very significant changes to the front of the vehicle. In a 35mph impact, all those would be factors as the crash energy displaces all that mass.
    There is no way, no how, the exact same results would be produced.
    I'm not saying they would be worse, or better for that matter, just different.
    On top of all that, the IIHS places a lot of weight on the availability of stability control, in fact a car can no longer earn a Top Pick without it.
    I realize IIHS' budget is finite but still, when major powertrain and changes are made that move that much mass around, a vehicle should be re-tested.
    Will the 2009 Honda Pilot be the new CUV standard that all other are judged?
    Probably.
  • bobw3bobw3 Member Posts: 2,989
    I've hauled 7 people, plus stuff on the roof without any problem, so I don't see why I'd need more torque and power carrying less ;)
    So if it's showing the minimum for both Acadia and TX, then we're comparing apples to apples and the legroom on the TX is still greater.
    Correct, but unless you're trying to put 3 in the 3rd row, the added shoulder room isn't needed. The TX's 3nd row is plenty wide for 2 people, as is the 2nd row. That's why I said that if you need to carry 8, then the Acadia is better, but if you're only carrying 6, then the TX's added legroom outweighs the shoulder room that you don't need if there are only 2 people in each row.
    Touchee, and you brought up valid points, but those are the exceptions.
    The Highlander is the only one to give you a full-sized backup cam without a GPS. Even then, it's only on the Sport and Limited models, the base models don't offer it. So you still have to spend more, it's just not packaged with a GPS.
    Good catch, though.
    The CX9's in-mirror backup cam is very nifty, I've seen some aftermarket ones, but again, that screen is fairly small. I'm sure that and a portable GPS would do the trick for me, however.
    I've seen a simple $99 backup cam but you have to hard wire it for power, and I wonder how durable that would be.
    vad: which $1000 Pioneer system are you referring to?
    I ask because I looked, and their $999 system is the Pioneer AVIC-D3, which had several important trade-offs I could not overlook:
    * it only has one single CD/DVD slot, which limits your music
    * that also means GPS maps or music, not both
    * it was not compatible with the steering wheel controls I have for the radio
    * backup cam not included, though it is an extra cost option ($150 to $250)
    * that price does not include installation
    So with a backup cam option plus installation, you're talking $1500 plus. At that point you're better off going factory. Much better off. Factory would give you:
    * multi-CD changer
    * GPS and music simultaneously
    * steering wheel audio controls would still work
    * backup cam included under your warranty
    In that case the Pioneer's value erodes quickly.
    To top it off I found the Pioneer interface not very user-friendly.
    I doubt it because Honda considers the Pilot as a true SUV, in competition with the Explorer, Yukon, etc, and not the CUVs listed here. Honda doesn't even market a CUV. It has the Odyssey which is their people-mover for those who don't want the Pilot SUV. Ford and GM have CUVs because they DON'T have any minivans in their lineup, so they HAVE to have a CUV to market to those who don't want an SUV. Toyota and Honda don't have that same problem.
    I test drove one and it did feel a bit more trucky than some of the newer models.
    Interestingly, the sketch shows an even more macho truck-like concept. I guess we'll see soon enough.
  • albookalbook Member Posts: 1,282
    I doubt it. With so many new entries into this new and slightly unstable market, I don't think HOnda really has that much more to offer. I thought the HIghlander woud become the new benchmark, but that was before we saw it. That's not happening. I think the lambdas and the CX-9 will continue to be the ones to beat.
    The Acadia's 3rd row is wider because the Acadia is 4" wider than the TaurusX. I own a Freestyle and it was parked beside an Outlook and looked a lot bulkier. And the height of the TaurusX is mostly at the rear, which is why it looks like a station wagon more than an SUV, like the Acadia. And adding unnecessary power is just a waste. After 60,000 miles on my Freestyle, I have yet to find it lacking in power, but I do like getting 30mpg on the highway if I keep the speed at 65mph.
    Not only is exterior width wider on the Acadia, but the Ford's is signifigcantly narrower. Some like the extra power, and many felt that the FS was underpowered. For deven feltit, so they added more power for the freshining.
    If you need to carry 5 plus cargo (in the cabin) then the Acadia is the way to go.
  • nxs138nxs138 Member Posts: 481
    Honda has been tightlipped on the new Pilot, so it's impossible to know if it will be better or worse than the new crop of crossovers. If it offers the same tech packages as the MDX and as much interior room as the Acadia, then you might have a winner.
    I was being sarcastic. That transmission is used in several of GM's vehicles.
    You who are very concerned about mpg should know that rooftop carrying luggage can cut down tremendously on mileage. I'd much rather have my things with me inside the car. And with luggage for seven, the Acadia is still comfortable on a long trip (or so I've been told).
    Anyone else think this looks just like a Hyundai VC?
    To me, that's an advantage to the TX, since not being so wide makes it easier to maneuver, better in parking lots, entering my single car garage door, etc...I don't consider extra exterior width an advantage when I don't need the added interior width to meet my needs...and the folks that I carry are height/weight proportional, but I imagine that for folks with extra personal width, extra car width would be a benefit ;)
    sorry it's. have delete it. wrong picture
    But you only really lose about 2 inches in the second row, and the third row is still much more comfortable than in the TX.
  • freealfasfreealfas Member Posts: 652
    "There are definitely several FS owners who have been fooled into thinking it's a real CUV"
    as opposed to several fools who think it's not.(just an innocent witty play on words as opposed to being intended as an outright insult)
    I find this debate comical. I also would like to pose the question to the naysayers of T-reX/FS CUV status. You all freely consider the cx9 a card carrying member of the cuv club but it has a less useful third row by a long shot, gets poorer mileage, and less cargo area. using your own(loosely termed because there is so little) logic I'd argue it's nothing more than a tall "wagon" as well. the crux of your perception seems to lie in the fact it is based on the 500/Taurus platform hence it can't possibly be a CUV. I have yet to hear a thoughtful & rational explanation as to the "thinking" on this as opposed to blatant opinion.
    as for wagon being a "new bad word" in the "industry"(there you go again you insider you with your finger on the pulse of all that is automotive) the "wagon' really hasn't been "in" for quite some time and surprisingly so considering how much more competent they are than SUV/CUV's with little sacrifice in space depending on what you are comparing. They also make so much more sense than the sedan counterparts, the europeans really embrace them as opposed to here, again, not sure why, maybe they are on to something???
    BTW, can you PLEASE stop forcing you OPINION on the rest of us that the FS/T-reX is "just a station wagon"... if it walks like a duck, acts like a duck, quacks like a duck, ....hmmmmm... must be a duck...
    wondered what took me so long... didn't you???
    True, Honda has a good minivan, but they are also smart. They follow the big market trends. They see that the new big thing is the CUV. Actually they saw it in 2003 when they brought the original Pilot out. The market for CUVs wasn't as big though, so they had to tailor to some of the needs of SUV owners. That's why the styling is trucky.
    It will have the Acura's toys, but it won't have the size of the Acadia. They already have a minivan, so they don't need a CUV as big as one. Plus, buyers are use to that size Pilot, s Honda probably won't let it grow too much.
    That's true, but the TX has greater than or equal to luggage space behind the 3rd row as the Acadia. The space behind the 3rd row of the TX is like a minivan, which has a well about a foot deep to hold the 3rd row when it's folded back. Plus there's a few more CuFt under the 3rd row that you can access when the 3rd row is up, which is about equal to what's under the Acadia's cargo area under its floor. That's why originally the Freestyle was listed as having 21CuFt behind the 3rd row, because it includes the well area and since there's nothing covering it up, it really is useful for tall luggage.
    Granted you could fold 1/3 of the Acadia's 3rd row for added luggage space, but it would be a tight squeeze to have two adults in the 2/3 portion of the Acadia's 3rd row.
    Plus if once a year I need to put a few things on the roof, the MPG lost there is more than made up by the better MPG the rest of the year.
    So you can slide the 2nd row up 2 inches to make the TX equal to the Acadia's 2nd row, and then you'll have 35 inches of legroom in the 3rd row of the TX as compared to the Acadia's 33 inches, so how is the Acadia's 3rd row more comfortable with 2 inches less legroom? Again, unless you have a requirement to squeeze three people back there. For two adults, I'd rather have the extra 2" legroom that each passenger back there can use, than a few inches more width that's not necessary since in the TX, 2 adults won't be touching shoulders anyway.
  • volkovvolkov Member Posts: 1,306
    IIHS may allow manufacturers to crash at their own facility as per their protocol and submit all data and documentation if it's a refresh. They review same and re-assign ratings as required if they are satisfied with the testing. New vehicles are only crash tested on site.
    For seating 2, I found the rear in the TX better. Must be body proportion/shape.
    He's back.
    If you really like the FS/TX you should be concerned about the truth, not perception- as someone else said. You should be concerned with the fact that the FS is a versatile spacious wagon, not that it tries to act like an SUV. And the CX-9 is very much a CUV. There is no rule that says a CUV is only a CUV if it has a large third row. And it has more cargo space than the TX (let's get our facts straight now).
    Well. since you've obviously been listening to others blatantly oppinionated statements(i haven't made any about why the TX is a wagon), here are some real ones. I has carlike ground clearance..It doesn't really sit up high, and is shorter than most CUVs. This is just my oppinion here, but there is nothing the FS/TX has that a conventional wagon doesn't have.Third row? Wagons have it. All wheel drive? Wagons have it.Carlike groundclearance? Wagons have it. Heck, Ford just might have been feeling so, as they decided not to differentiate the FS from the 500 anymore, and called both the Taurus! The hiegt difference is only about 5 inches between the two.I think that's about all the logic there is. But then, I think that is enough.
    I know. If I keep letting out all these secrets I'm going to get into trouble.
    How do you know wagon has been "out" for a long time now? There are about 50% less wagons now then there were in 2005 made by American auto makers. But I never said anything about the actual vehicle being out of style. I was refering to the name "Station Wagon". I can't think of one station wagon on the market today called station wagon. The now deceased magnum was exactly a station wagon, no doubt. But they called it a "Sports Tourer." DOn't forget 5 door, and Sport Combi. Why are CUVs doing better? People like to sit up above the road.It's command seating. Also, they give more cargo space.
    You must be referring to the fact that I have said that in many responsess to others lately, because I haven't forced my oppinion that the TX is a wagon on anyone.I've jsut said what I think.
    Not true. The Touureg has SUV towing and gas mileage. SUV, right? Nope. CUV. The TX might walk and quack like a duck, but it doesn't act like one. No high ground clearance. But that doesn'tmatter. The TX has other virtues. being SUV like isn't one of them.
    The break was nice- but I'm always ready for game time.
    Perfect! Except for one little detail- the TX's seats don't slide.ALso, it's just as comfortable in both of the second rows. If you don't think so, slide the Acadia's second row back an inch. You'll still have more room in the Acadia's third row.
    Oh- they'll be touching shoulders in the TX.The Acadia is especially nicer if you only have to seat 6. There is more leg, and should room.
    So I'm fat now? I see we've got jokes. :)
    Well the Acadia doesn't handle much bigger than the TX, and manuvering isn't any worse. Also, the TX is much less space efficient with it's width. It's narrow inside. I'd like to have the leg room and the width, and the Acadia give you this.
    Incorrect...the 2nd row seats of the TX slide fore and aft. I'm still wondering on the definition of comfort where less legroom equals more comfort?
    And the two adults sitting in the 3rd row of our Freestyle weren't bumping shoulders.
    I would definitely llike to have the luxury of keeping my luggage inside the car, and keeping wind noise down.
    True- by about a cubic foot, but there's not room under that third row for much. So what's really the benefit of having the well? Yes- taller luggage, but the Acadia's floor is wider, and longer.
    I'm not picking on you albook (really! :) ), but I actually believe it'll be the other way around. Honda won't be allowed to tread on Acura's toes by getting all of its toys. Instead, the Honda will probably be a little more roomy to compete with the meat of the class.
    Look at the TL versus Accord. The Accord STILL doesn't have things like memory seats and HID headlights, but it got a lot bigger.
    It'll be interesting to see what Honda actually does with it!! :)
    Not behind the 3rd row, which is the important one to me when using all 3 rows for people.
    I'm sure you're not talking about the TX, as it's 199 in.
    And there is nothing the FS/TX has that a CUV doesn't have. A CUV has many definitions, one of which is a cross between car, minivan and SUV, not just a downsized SUV.
    But who cares what the label is...but if you're going to call the TX a station wagon, name me one other station wagon that can hold 7 adults and luggage?
    Ok this real number from Ford and GM website:
    Head room (in.) TX GM
    First row 39.4 40.40
    Second row 39.7 39.30
    Third row 38.6 38.40
    Shoulder room (in.)
    First row 58.5 61.90
    Second row 58 61.10
    Third row 50.8 57.80
    Hip room (in.)
    First row 55.5 57.80
    Second row 56 57.90
    Third row 45.9 48.30
    Leg room (in.)
    First row 40.8 41.30
    Second row 40.4 36.90
    Third row 33.4 33.20
    Behind first row 85.5 116.9
    Behind second row 47 68.9
    Behind third row 15.8 25.5
    So you can see 2 nd row leg room in TX more only, but hip room In Acadia 2 inch more so it makes almost equal. That's it. TX smaller car than Acadia.
    And don't play with numbers. Move back or aft . it's all depends. Acadia has much smother ride and quiter inside. Today is better car then ford. May be Flex will be better.
    How is the TX less space efficient. Effeciency means making the most out of the usable space. In other words, being the biggest on the inside in comparison to the exterior dimensions. Just being big all over does make a vehicle efficient.
    Correction...more width but less legroom.
    At 6'4" 195lbs, I'd take the legroom every time. :)
    I don't have a rocket box, but I think you're overstating the mpg hit a bit. I drove my unmentionable rig on a 31,000 mile road trip hauling a canoe on top all the way. Canoes have a nice shape to them, but that's still a lot of windage up there. My mpg hit was around 1 mpg, based on my mileage spreadsheet.
    BTW everyone - the nice break is still on - game time is not going to include personal comments. As always, stick to the merits of the cars, and we'll do fine.
    31,000 miles? You mean 3,100? Or did you drive around the WORLD?
    Was worried everyone would still be in a "too much turkey stupor". This site is nothing if not entertaining. It's great when people emphasize the subtle point I was making without even trying.
    Let me make it obvious. Every CUV is really just an AWD wagon with some minivan interior ergonomics sprinkled in. There is nothing more to the species. It's a marketing term hatched to fool those people who wouldn't be caught dead in a wagon or "the mv-word which must not be spoken". Just in case, we'll add some bulgy sheet metal styling to disguise the truth.
    It's cool with me if you prefer the SUV styling and it's perfectly okay to make vehicle purchase decisions for any emotional reason you choose. Looks, image, cachet, sense of luxury, sporty handling - whatever. Thankfully, many members here have the insight to know why they made their choice. On the other hand, the "My vehicle is a CUV so it's better than your station-wagon or minivan" is patently ridiculous and merely identifies you as a marketing hacks dream.
    Me too...and if you had the Acadia and TX both with their 3rd rows up, you'd get equal or more stuff behind the 3rd row of the TX. Based on your comments, it doesn't sound like you've ever looked behind the 3rd row of a TX to understand what I'm talking about. There's the space under the 3rd row, plus the well behind the 3rd row. But it's easier just to find some photos online then explain it in text.
    If you look, the amount of ground clearance varies quite a bit amongst CUV's. At "carlike" you'd disqualify more than TX.
    well said...
    We took a year off to celebrate the Millennium (the epic Quest). More road clearance would have been a plus.
    We're soliciting funds to pay for out next road trip btw - the last one is just about paid off, LOL.
    I'll have to check that, because it didn't slide in the FS. FS has more second row leg room in inches than my friends '98 Town and Country, yet his second row seat is more comfortable, because it is taller.
    My nephew and I sat in the third row and we were touching. I'm pretty big, but he's not fully grown and we were touching.
  • aviboy97aviboy97 Member Posts: 3,159
    That is because if you want those extra toys, Honda wants you to purchase the higher profit Acura brand to get them. If you can equip a Honda very similar to the Acura counterpart, most everyone would save the extra cash and buy the Honda.
    This is why a company like Mazda offers things like Xenons and memory seats because they do not have a luxury line. They tried to start one in the mid 90's but failed. The Mazda Millenia was to be their first luxury vehicle under their luxury brand name Amati. Lincoln does not count. That is Fords luxury line.
    Remember also, Acura is the American luxury version of Honda. If I am not mistaken, Acura is not sold any where out side North America. Us Americans need a status symbol in our driveway....
    Everything you've said here is correct, I believe.
    A lot of posts, but the bottom line is that even if the FS/TX isn't quite as big or has quite as much ground clearance as some of the other CUVs, it can't be dismissed as not being a competitor. Compared to the Acadia the TX is smaller. Compared to a Veracruz or Highlander, the TX is bigger. If size is all that matters, then if you're going to dismiss the TX, then also dismiss the Highlander, Veracruz, Pilot, CX-9, and any other CUV that doesn't match up, but then what is there to talk about ;)
  • agt2046agt2046 Member Posts: 16
    NO. Acura is sold outside of NA maket.
    http://www.acura.com.cn/acuranewsite/index.html
