Ford Explorer Gas Gauge
in Ford
I bought a 2004 ford explorer about 2 months ago and I have already had it in twice for different things. Now I just got it back last week and my gas gauge went out(it only reads 1/3 of a full tank), and also I am getting a loud pitch whistling noise at 2200 RPM from the engine.
I have read several forums and noticed alot of people having problems. My question is has anyone had the gas gauge problem, and or the whistling problem and had them fixed, and what did the dealership tell you was wrong?
I want to be alittle bit educated when I go into the dealership to explain my problem.
Mark.
my wife had the gage go down to nothing after she filled up
HER 2004 EXPLORER XLT and the check gage light came on...
after a bit of driving the gage went to full
but then she noticed the check engine light came on...
took it to the dealer and this is what they said...
It is sulfur contamination...
they sell a kit to fix it that cost like $300
and labor to put it in is another $300...
WTF!!!
3 YEAR OLD CAR WITH UNDER 30,000 MILES
JUST 2 MONTHS PAST THE FACTORY WARRANTY!!!
sounds like I/we are getting hosed...again...
seems to me this is a bigger problem and should be a recall issue...
kind of ironic that they already have a repair kit to fix a problem that they are claiming is natural wear and tear...
any help is great
Tony
Intimidator17@msn.com
fixed it myself...cheap!!!
I bought a bottle of Chevron Techron
synthetic fuel system cleaner
and filled up with 93 octane gas...
I swear I didn't drive 5 miles...
I drove for 5 minutes...let it sit for a few hours
then drove it a few more minutes
and the check engine light went off
and has not come back on since...
over a hundred miles and good to go...
I went back and bought more cleaner for all my cars...
it was buy one 12 oz bottle and get one free
at advance auto parts!!!
I spent like $35 total and like 30 minutes time
to fix a $600 problem...
If I have to do that every year until I sell it I will...
not to mention everything else in the fuel system is getting cleaned and might improve mileage and performance!!!
Ford's $600 solution would have only turned the check engine light off...
I am also replacing the fuel filter this weekend...
$7 for Purolator filter..Ford wants $17 for Motorcraft!!!
they are probable made in the same plant in China!!!
Thanks again
Tony
I've notice since 2 weeks ago that my ford explorer sport trac 01 is making a whistle sound around the gas tank area, it only does it when the engine is running, if I turn the car off it stops also if I have the key switch on (engine off) it stops.
Help please!!
Anyway, our fix was the vacuum hose to the fuel tank was not properly installed, so the dealer had to remove the fuel tank and fix it. Ford called it a service adjustment and therefore not covered by warranty. I am arguing with Ford at this time, and have already filed a claim with the Federal Trade Commission.
I have a posting elsewhere about the Extended Service Plan too.
:confuse:
The morning after Memorial Day, I went to work and again my "check gage" red light was on and so was my "check engine" light. Instead of heading to work, I went to a Ford Dealearship and have them diagnose why this is happening. Mind you, the gas gauge was working just fine as I arrived the dealership but my "check engine" light was still on. The service advisor came back to me after almost 2 hours of waiting at the lounge (thank goodness for the ESPN sports channel) and he told me I need a Fuel Pump Module and it will run me $1,064.37.
Shock as I was about how much it will cost me for them to repair it, I declined the repair and went straight to my workplace. I was skeptical about the cost of repair so I am seeking a second opinion from anyone who can give me some light to this sort of problem. Thanks in advance for your comments.
