Dodge Dakota General Operating Questions
                    followed all the directions in manual to disable horn honk when locking doors with key fob ...BUT doesnt do it??? its a 06 C.C...Help???.Poppa
Recently however I have a couple of problems I need to fix. One is due to the cold weather and in the morning it will start fine, however as soon as I kick it into drive it just turns off.
The second problem is I was driving it yesterday, and when I get out of the car I see some white smoke/steam coming from the radiator.
I'm not big into cars and don't know much about them so dont kill me for posting these questions, I'm sure I could have posted this on any car forum but I figures I'd do it on a forum where people know the car I am talking about.
My best guess is I need an oil change and maybe need some new coolant? Please help me out with these questions, this car has been driving me nuts with problems!
kcram - Pickups Host
If you can provide more information perhaps I can help.
Best regards,
Dusty
Dusty
I do 10,000 miles per year regular maint.History of repairs started with the current problem when I drove into Dodge with curent problem spitting , backfire I was told catalictic converter was clogged i told them to run diagnostic test anyway, told it was fine. @ 2 weeks later same problem I was told PCM was bad , it ran good for about a month same problem , I replaced the parts from first post .Its eratic cant put my finger on it.
Thanks trk37
Ignition System - Cross Fire/Ignition Wire
Problem solved had to reroute ignition coil wire and put conduit on coil and spark plug wires. I found it in a Service Bulliten on Edmunds for 97 Dakota. Basicly the ignition coil wire cant be with-in 1 inch of the spark plug wires . Maybe the Dodge Boys should use Edmunds.Com.
I do know that with some vehicles you are better off getting rid of them as inherent problems make them not cost efficient.
Thanks for any info.
Tom.
*Heater core
*AC Condenser
*Clocksprings
*Lower & Upper Ball Joints
*Throttle Position Sensor
*Distance Sensor
*Differential noise & failure (AAM axles)
*Shift problems caused by poor electrical connections at the transmission (42RE, 46RE)
*Intake manifold gasket (3.9 Magnum motor only)
Both the 3.9 and 4.7 engines are bulletproof. If you have a 4.7 engine the automatic is the 545RFE. This transmission is very tough and reliable and among the best on the market. Chances are you'll have trouble with the transfer first.
Unlike the Tacomas of the same vintage, Dakotas metal and anti-corrosion protection is superior.
Of course maintenance quality means a lot when determining long term reliablility.
Best regards,
Dusty
I have an 88 Dodge Dakota.
There may have been other equipment differences as well.
Dusty
Dusty
Help!!!
Well, the 2001s had a different instrument panel and my memory is not recalling anything. When you operate the switch, what happens?
I can think of two possibilities: it may either be the switch for the fog lamps, or for the heated mirrors.
I don't know.
Dusty
You could see if this is possible.
Well, it rains, and now I need to find someway of plugging up the holes to prevent water from splashing in. Any Ideas anyone?
Just bought my daughter a 2001 dakota r/t with a 5.9 v8. So far we have had 2 issues that I was able to find the answers to on this forum - so thanks!!!
But am just wondering if anyone out there can give me some info on this truck in the way of how to maintain it, and any possible issues to be looking for.
Again I'm glad I found this forum I'm sure I'll be referring to it over and over as issues come up.
Mod's soon to be added dump hoist kit, front and rear receivers, quick mount winch, pivoting truck crane, 2 battery kit, a belly side generator and air compressor. It will be a work truck.
-Will 4x4 make that much of a difference?
-Should I go with the 3.9 or the 4.7?
-Gas mileage? I'm getting out of a 4 cyl. Accord. Need truck convenience
-Is the rear a big issue? 9.25 vs 8.25
-What about mileage concerns: 120k to 145k
-Is the lsd a major concern? 3.55
-Are there any mechanical issue I can expect for truck in this age range?
I will primarily be doing city driving and some honey do things. I will also be using it to carry bikes on the hitch from time to time.
However, it will be my daily driver.
Thanks in advance to anyone who can share some insider information with a truck newcomer.
Would either the F150 extended cab 4.6 or Chevy Silverado 4.8 be a better choice?
changes that i will be making however is pulling the engine and mating the transmission to a 100 hp electric ac motor, 10 deep cycle batteries and a 6000 watt diesel generator under the hood. yes it will all fit. it is also getting a dump conversion. already it has a 1000 lb electric hoist. and surface mount tie downs outside the bed.
so far total invested in this truck and all supplies so far has totaled $1100. and is a daily driver.
so don't under estimate these little trucks. they will gitter done! :shades:
I needed new front rotors at 12,000 miles, and the head gasket went at 19,000 miles. I was on the hook for the rotors because it was past the 12 month warranty period for the brakes. The 7 year/70K mile power train warranty took care of the head gasket.
The driver's side power seats don't work on occasion. They'll go months without a problem, then will stop working for a week or so.
Gas mileage has averaged 18 mpg in a mix of suburban and highway driving. I consider this pretty poor for what's advertised as a mid-size truck that doesn't weigh a lot more than a Camry.
