Chevy Astro Heating/Cooling Problems
On my 99 Astro I get great airflow at all climate control mode selections, except the driver's side feet. The passenger side gets has good air flow at the feet. Any suggestions?
Took it back to the dealer who put in a new control (The one with 3 holes attached) now I get all kinds of air to the various areas and I can get the A/C to work BUT absolutely nothing beyond a luke warm(cold) air when the heater is turned on. Living in Canada we need a properly running heater in our vans!
Now the dealer is suggesting the thermostat may be stuck and wants to replace it (of course at my cost)
Could this also be a vacuum problem?
Now it has stopped blowing at all regardless of the setting. The heat/AC controls work. I can switch between heat and AC. I verified this by watching the compressor turn on and off and also the rear AC works fine.
Is this the infamous vacuum issue and how can that affect the blower motor and not the other stuff?
Anyway I replaced some of the vacuum lines and the blower does not stop when going uphill anymore. However the blower works on every speed but high. Is this the resister pack problem?
