Visitor Agreement.
It's great to have tires for different purposes, but I'm not sure my wife would even understand the concept.
-juice
My likelihood of heavy snows is only slightly greater than yours, juice. I'd have to live up in the Poconos before I'd consider dedicated snow tires. I also figure that it'll be easier to deal with if I forget or get too busy to switch back in the spring or if I trade the car before they wear out.
Ed
-juice
Any info appreciated.
Larry
Overfilling the crankcase is a big no-no. Not only do you run the risk of the oil spilling out from the filling spout from thermal expansion, you also develop foam in the oil from the rotation of the crank.
I'd seriously question the ability of the dealer if they can't find the "F" mark on the dipstick. Plus, if you know the capacity is 4.2qts, why would you put in anything more than that amount?
Oil changes on the Forester are easy. Just keep a record of receipts for oil and oil filters, keep a log book of when you changed the oil and you should be okay.
Ken
Did Larry's dealership guys put in 5 quarts for sure in the first place?
bit
Ken
Cheers
Pat
Does any one have a favorite oil filter brand? I'll probably stick with the Castrol GTX oil, and have always been partial to Fram filters. I really like Hastings filters, but they're hard to find sometimes. The selfsame dealer also told me that any filter besides Subaru's runs the risk of voiding the warranty. I know Purolator makes the Subaru filter (the one I took off had Subaru, English, Japanese and Purolator on it). I ran that comment past the folks at Fram and they were really, really unhappy that a dealer would say that about their filters. They suggested I might want to file a complaint with the FTC.... but that's more pain than I want to get into right now. Sorry for the long, windy comment. I've some more questions but I'll save them for later. Thanks everyone.
Larry
Since I was making the regular to synthetic switch, were they using most of the 5th quart to flush out the old stuff or what? I had the same experience as ifdal with them insisting on 5qts.
burnsmr4
I have 03 Forester XS. The first oil change (1.8K miles) I performed with a "Fram Tough" oil filter and Penzoil syntetic oil (10W30). 4 months/3K miles later oil is clean as the day I change it. The next oil change, I will do on Christmas Eve with a same oil filter and Mobil 1 syntetic oil (as folks over here recommended). My car parked outside and in a cold mornings it has a smooth start compare to the "old" original factory filed oil. Leo
Greg
Greg
Picky, picky, picky.
-James
http://minimopar.net/oilfilters.html
I usually use OE Subaru filters or just get the equivalent Purolator filter.
Castrol GTX is supposed to be very good among commercialy available dino-oil. I'd use it if I were sticking to dino. However, I currently use Mobil 1 synthetic.
I don't know why the dealer would use up 5 quarts. Did you ask them? When I am feeling a little rushed for time, I do sometimes add a little oil while the drain plug is undone to help flush out the last little bit.
Ken
Greg
From K&N website:
The Magnuson-Moss Warranty Act, passed in 1975, prohibits a manufacturer from conditioning its warranty of a consumer product upon the consumer using any article or service (other than one provided without charge under the warranty) which is identified by brand, trade or corporate name, unless expressly authorized by the Federal Trade Commission.
So Larry, unless your dealer gives the filter to you for free... for sure you could go to FTC, which is why the Fram folks suggested it. That law is tricky though, because if the warranty is bumper-to-bumper then technically, Subaru could void the warranty for using wrong wiper-blades.
i admit i haven't read the fine print of the Forester's warranty to see how it deals with serviceable parts.
http://www.z28.com/amsoil/important_articles/castrol_mobil_pao.html
Around where I live, Mobil 1 and Syntec are the same price so I just get the pure synthetic stuff.
Ken
texan5
For the oil, the boxer is actually less sensitive than most in-line or vee configurations to overfilled crankcase oil. Don't worry about them using 5 quarts, though 6 would have me concerned.
FWIW, I end up using about 4.5 quarts to get mine full.
Pat: lots of us are anxiously awaiting a new turbo Forester, probably in June? Hopefully a 2.5l light-pressure turbo with about 200hp, as some rumors suggest.
-juice
Crashton
Anyway, that aside, was hoping someone might have a little experience with this problem and narrow it down for me:
Our '98 Forester is acting a bit funky lately. After its fully warmed up, I'll come to a full stop at a light and, when I step on the gas again, it stumbles and tries to stall before catching up with itself and surging forward. I've managed to get the car to do it at will now. I sat in the driveway yesterday after getting back from running around and I held my foot on the brake, kept it in drive, and gave it the slightest bit of gas. It sat there running extremely rough (seems to be right around 800 rpms or so - any more or less and its fine).
So, any thoughts?
Oh, and there was one day when my wife said it wouldn't start, but, after that day, I have been using it every day while she takes my car and I have yet to have a starting issue in the last 2 weeks.
So far I've replaced the fuel filter and that didn't help.
I also wondered if maybe you have some blockage in the fuel injectors or perhaps something other than fuel is in the tank (water?). Some injector cleaner (I use Techron) may help, but it could be as simple as replacing a dirty fuel filter too.
-Brian
Has anyone had trouble with the Forester Clock (the old style with the flourescent display)? Mine is getting intermittently dimmer. I could replace it with a time/temperature module I have on hand, but I want to keep things stock because I would like to sell next year and buy a turbo. If anyone has any ideas on what the problem is, it would be appreciated.
Has anyone replaced the Forester brake pads with aftermarket pads? If so, what did you use and how well have they performed and held up? Mine are about 70% worn at 71,000 miles, so I will need replacements soon because of anticipated high mileage accumulation in the next few months.
Headlights: My headlights were aimed very low upon delivery. I reajusted them upwards. US cars are often adjusted so that the center of the low beam hits the ground about 75 feet in front of the car. This is less than one second of driving time at 60 mph/100Kph. Because the orginal Forester has a very sharp upper beam cutoff, the lights can be aimed quite a bit further out without blinding others. The foglights were aimed into the ground, and the dealer re-aimed them during the adjustment period. They are still not very useful, however. Now if we could just get the drivers of most cars with foglights to keep them switched OFF when there is no fog so we don't get blinded by them...
subearu - fuel was my initial thought, which is why I replaced the filter. Bad gas shouldn't be the problem at this point since we have been through probably 4 or 5 tanks since this problem first surfaced. Plus, I always use injector cleaner with every oil change. A vacuum problem is a definite possibility and one my father suggested I check out. I've just never been good at tracking down vacuum problems.
1. MAF sensor
2. throttle position sensor
3. vacuum leak
Now why no CEL...??
Other possible causes ...idle speed control....coolent temp sensor ....EGR(cause of many difficult to solve problems)
FWIW...had a similar problem on a Chevy V8 TPI...the stalling led me to the TPS which was incorrectly set. Setting it to the correct values cleared the problem.
Also, on a totally unrelated subject, has anyone tried the Subaru pet grate for a 03 Forester with a sunroof? I need something but the $134+ non-refundable accessory price tag from the dealer is a little daunting if I don't like it.
Larry
1. This is still the worst clutch I have ever had, it still shudders like a [non-permissible content removed] when it is damp out and the car is first run in the morning.
2. Has anyone else noticed how easily the body panels dent on this car..ouch!!
3.Thinking of replacing tires and sway bars soon..any info from you guys would be great.
4. I dont know if you all have ever played the ps2 game called gran turismo 3 but it is the best racing sim I have ever seen, there are 8 subarus in the game that you can buy and mod. I got the wrx japan sti model and have modded it up to 485hp and it is so fun driving it in this game. Check it out!!!
Have a safe holiday everyone!!!! Mike in CT.
filter. You can buy those at most parts stores.
I use the Purolator PureOne filter. It is supposed to be Purolator's premium filter.
Chuck
That would be a problem only if the beams had no spread. The traditional aiming of headlamps is more or less optimal for both distance viewing and close up as well as being considerate of oncoming traffic. Keeping your headlamp lenses clean will resolve most issues.
Mike,(mrluther), I replaced the factory 13mm rear sway bar initially with a 17mm since I carry quite a few heavy loads from time to time. I have sinced again replaced it with a 20mm and now I'm satisified with that. I know it's not allowed to "sell" on Edmunds but I still have the 17mm.
lakepop - FYI, there is no idle adjustment on these. All computer controlled these days. Really frustrating for those of us who learned on non-computer controlled cars ... but a fact of life nonetheless.
Old sealed beam lights had the pattern determined by the built-in reflectors and lenses. Now, each car manuafacturer has its own design that is often developed more for cosmetic purposes than performance. This can lead to problems. I have driven many types of cars, and there are very few that, IMHO are safe to drive with low beams at 65 to 70 mph when the headlights are aimed to factory specs.
The sharp upper beam cutoff on Subarus and many European cars allows the lights to be aimed further out without blinding oncoming drivers. That upper cutoff limits scatter in the forward direction, except to the extreme right where it is set up to illuminate road signs.
I'd like to hear other people's experiences with sleeping in the car. I'm talking about two adults with some gear around. Can you get reasonable night of sleep? What's better: making bed of the front part of the vehicle or getting back with leveled rear seats?
Basically, what I have in mind are those nights in the mountains when it suddenly drops below freezing mark or bear make the appearance around the camp site (and that's quite common where we usually go).
And, I don't mean to start a war here but how good Forester really is off road. Not climbing a rocks, but taking us places where we start hiking or canoeing, forest roads and stuff.
Thks,
kid
as far as "offroad" (IMHO offroad=no previous tracks, i.e. a desert wash), i'd say a stock forester will get you to most places where there is a reasonably non-rocky two track road. i'd shy away from deep mud ruts and hardcore desert driving (boulders, etc.) as well as places where you need to crawl (oh, the low gearing we miss!). for peace of mind, i'd put some protection in place of the plastic under the engine and a diffy protector. also, it wouldn't hurt to do something to the gas tank.
finally, how "good" the forester is off asphalt will depend on your driving skills and risks you are willing to take. check out Subaclub for ideas.
i know, long post, can you tell i'm on vacation?
;-P
Lou, Once and Future Bear Bait
didn't I mention it's for me and my wife
Cheers,
kid
I also have the clock problem. I actually just ordered a new one as a replacement.. Cost $47 with shipping. Sounds like a bad design of clock if others are having the same issue.
I also have a gear shift on my 1998 Forester that is squeaking and rattling. not sure what to replace on that one? Anyone seen that before.
Even with the issues, I have had 182,000 pure driving fun miles...
Myself or someone I've known have had:
drain plug loose
oil cap missing or loose
tire presure wrong
oil/grease smugged on carpet or seats
screws lost from air filter housing (lube place would not replace)
bent dipstick
wiper blades installed wrong
oil splashed in engine compartment
deaf ears @ customer service dept.
Bob L.
I know, it's bad.
Greg
An annoying thing about those places (I used to do it 15+ years ago) is that they charge the nineteen bucks - then try to upsell you with more fluids, new air cleaner, windshield washer fluid at $3.00 a pint, PCV valves, etc... that your car may (or probably doesn't) need.
But the worst thing about them is their speed! When motor oil drains out of your engine, the last bit to drip, drip, drip is the slowest-moving crud-filled sludge. At a Quik Lube, the stream hardly slows down, and they've got the drain plug hammered back in and they're filling up the oil again to get you out and the next sucker in!
Great advice I got years ago was to change the oil myself, and let it drain for hours. Overnight is fine too. You get the worst of the crud out of the engine; and save the bother of salespeople trying to nickel-and-dime a $20 service stop into a $50 service stop.
I've got someone on the hook for my car; then I get the Forester XS, five-speed. Yippee!!
1) They almost never use a crush washer on the drain plug and overtighten the bolt
2) They constantly try and upsell you with unecessary items
I've also noticed that places like Jiffy Lube often charge more if your vehicle is AWD/4x4. There's absolutely no reason why a Subaru should cost more than any other passenger car.
Stay away from quick lube shops. It's just a matter of time until they mess something up.
Ken
