Kia Sportage Heater AC Climate Control
My 2005 Sportage is very difficult to keep from getting fogged up. When the temp is below freezing I can never see out the second row windows or the rear window. I notice no difference in the air quality when I push the button to recirculate cabin air or leave it in the default position for fresh air. The dealership could find no problem with the mechanism but I have a feeling the recirculate air button is on whether the light is illuminated or not. Any ideas?
In the Pacific Northwest, where we bought our Sportage 4x4, I didn't need to use the A/C because of a higher outside humidity level. Give it a try and get back to us, OK?
YOu mean the blower motor? I cannot see how it could be covered with ice, please explain...
....One thing is not clear: does the air flow change during that event? Ice forming on the AC evaporator could be a factor, meaning the detent valve being set at too low a pressure and causing too low a temperature, hence icing....and it would then restrict the air flow...then it might indeed be a "common trouble" with that series of vehicle, as the dealer said....with the consequence as he describes about taking off the dash...but is that a fact...I do not know, anyway, it seems that changing the motor did not solve anything, did it?
....when it works, do you have the feeling that the air is VERY cold..? that is, colder than you have experienced with other ac equipped vehicles. That is a tricky question, not very precise as a "feeling"...but if it verifies something you might have tought of, it would point in the direction stated above. It would be a gross mistake from the manufacturer then ....
I'll ask the question to the local dealer here...just to see their reply...also, will check for any report in CONsumer's report and other agencies...
What is the correct R134a charging quantity?.
How best to replace a temperature sensor?.
How does it look? (pic or drawing).
Not sure what your symptoms are but the problem I had was with a clogged cabin air filter. You would find it inside and on the left wall of your glove compartment. As soon as I switched out the filter the problem was history. Good luck, Don
