Dodge Caravan Instrument Panel
I have a 92 dodge caravan the insturmental cluster is out. The spedometer, oil pressure, battery indicater, RPMS, Fuel gauge, are all not moving unless I go over a railroad track then they seem to come back on. What could be the problem? Checked fuses, wiggled the wiring and still nothing. Please Help!
jamie
Driving down the road late afternoon to softball and hear the power locks engage (but already going 30+ MPH) so I then try pressing the keyless entry because I thought I remembered that it is disabled when driving, it doesn't work. Next thing I notice all the gauges mpg, rpm, oil and gas flatline, but the car is running fine. A few seconds (up to 30 or so) later everything comes back on... then it happens again. Oddly enough this has not happened to me in the morning. Any replies are appreciated.
Hi everyone! I have been over in the Jeep Liberty CRD forum for the last year, but I also have a 2006 Caravan. When I bought the van, it had a dead battery (it had been sitting on the lot for over a year)....the van jump-started just fine, but the guages jumped all over the place....most other electronic devices acted the same way (going on and off)....it was found that the battery was defective....replaced the battery, and everything has been normal ever since with no problems and no re-occurances. Just FYI, but you might have your battery retested or look for any loose connections along the way.
Twocycle2
I have a 92 Dodge Caravan that has instrument problems. I have tried 3 different clusters and all do exactily the same. The instruments only work when the headlights or parking lights are on. When the instruments are inoperative, the windshield wiper delay functions also don't work. Turning the lights on while driving causes the door locks to activate also... The local repair shop gave up after 4 weeks of messing around.
FIRST: Instrument panel, including all gauges, will flatline and then return when it feels like it. The common forum answer seemed to be a bad solder job on the instrument panel.
THEN: My Hi-beams stopped working, wipers are intermittent, Driver side interior dome light may or may not turn on, usually a few seconds after door is opened, then turns off immediately.
FINALLY: Now I have a P1698 OBDII Error Code and the torque converter is not engaging (van starts fine, but stalls when put into gear. If I rev the engine at the precise moment I can get it into drive, but seems to be in limp mode, as it doesn't shift at high rpms). Oh, and I now sometimes have no LO beams either.
CONCLUSION...?: My guess is that the tranny is not bad. Rather, since the tranny on this van is electronically controlled and has given me NO issues prior to these electrical problems, I feel everything is related to an electronic issue. I've checked for secure connections on the PCM and PDC, but that's the extent of my abilities. If I knew how to read a wiring diagram I would hope to find that the instrument panel, lights and TCM all meet somewhere, and that this would be the culprit. I don't want to have it towed to a transmission shop only to find out that it was something like a bad BCM all along.
ANY help would be GREAT!
What can I do to repair the bcm I have or do I have to go to Chrysler and pay $700.
Any help would be appreciated!!
Joe
http://www-odi.nhtsa.dot.gov/ivoq/index.cfm
I encourage all to place a their complaint here as it is most definately a manufacturing defect that is causing our woes.
The Chrysler Corporation needs to be held accountable for this problem, as well as many others I'm sure. :lemon:
The good news for you is that the repair for your dash is typically VERY cheap. Pull the panel, find the failed solder connection and resolder it.
Best Regards,
Shipo
Let's see how long this works. I've seen some strange things in my life, but never anything like this. Thanks Shipo.
I understand through reading this post that the body control module (BCM) may also be a trouble spot, but figured I would take the cheap way out first. I The BCM is located somewhere behind the fuse panel in the lower left forward cabin, right above where your left foot would rest.
By the way, two dodge dealers I went to never heard of these electrical problems...
Plausible deniability? Perhaps, though with the frequency of the problem, it does not seem plausible.
solved the problem by replacing the back circuit board. replaced it from a $30 instrument cluster i got from a pick & pull in sacramento.
now it's working. the only catch is the odometer now reads in miles, not in its original kilometer reading.
