2007 Outlander XLS Remote Car Starter
...Has anyone installed a remote starter on the XLS (bypassing FastKey)? If yes, what brand/model?
Read here: larrys1, "New Mitsubishi Outlander Owners Give us your report" #151, 16 Jan 2007 2:58 pm#150
As one forum user responded:
I have been told its impossible.
Because the Fast Keyless system looks for a code built into the chip for the keyfob.
There is no way to replicate that system, so there is no way to remote start
From what I hear, Lexus and Mercedes owners have the same problem.
Why Mits choose to not have a remote start option on this car is beyond me.
I also asked if it were possible to remove the FASTkeyless system, and was told by MMA, that its intergrated into the ECU, so no luck there
If anyone comes up with a way,
Im all ears
What's the model # of your Compustar autostart btw?
I learned after the install that if I use the tiny key in the FastKey rather than just trying to turn the knob...the car doesn't have to shut off. It then works like any other auto start would.
http://www.compustar.com/products/2W900FMR.htm
It can work 2 different ways with the smart key. You can start the car while away from the vehicle. The smart key entry will still unlock the door when you are near. Then you have the choice to either kill the start by pressing the brake and restart the car....OR WHAT I DO...is pull off the knob over the ignition and place the small key into the ignition and turn the ignition to the on position. This way it works like any other remote start system. I hope that answers your questions. In the future, there may be a better way to make it work, but for now, I'm happy it at least works!!
i am trying to get a remote start installed, but no bypass
list for the fast key? Do you have the part# or brand of
bypass they used on yours?? or did you have to give up the
little key in the fast key fob??? Any info would help alot
Amy
I have a call into my installer to find out what type of module was used. I'll let you know as soon as I hear back. I did not have to use a key for the install.
Linda
Any news on this?
Remote start is a requirement for my wife. This small detail, is actually gating me from buying the Outlander XLS. My dealer says remote start won't work with the XLS.
Jonathan
Good Luck. It DOES work!!! and it is FANTASTIC!!!
