Chevy Silverado and GMC Sierra Air Bag Questions
2003 Chevy Silverado 4X4 V8 4.8 Ext Cab
I'm looking for some initial tips to get started on replacing my airbag clock spring. Bare with me, by initial, I also mean some "obvious" tips on where to get started. I have someone with Chevy expertise, but an Airbag clock spring replacement isn't something he's done before, so I wanted to check with all of you on what I need to do before, during, and after the install.
I had just bought a hanes manual (it's at home, I'm at work). Also, I don't expect anyone to provide me with a 20 page diagram/literature, but more of a summary, and things to check for.
I have seen another post about the clockspring on another
forum. Is it you?
Never seen one of those posts before!
The truck came with cloth seats. They were able to hook up all the of electrical except for the airbags so the airbag light is on. The adapter/plugs for the wires were changed between 02 and 05 and we are concerned about the airbags deploying by changing the adapter to make it work. Also there is a concern that the airbag sensors in the seats are different between the leather 02 seats and the cloth 05 seats... any ideas or suggestions to get the air bag light off and insure the airbags are in working order would be appreciated because the truck is for sale and hard to sell with the air bag light on
Actually the best place to start would be with the parts department at your local GMC dealer. Ask them if the plugs are interchangeable and if the sensors would cause any problem. They can look up the wiring diagrams of both the '05 and '02 and give you a better answer.
There are other forums where you could post this question and perhaps get better results. Unfortunately, I would be in violation of the TOS by posting it.
Seems I'll need to check the harness and sensors tomorrow. But this hasn't run my battery dead.
The real issue is why they put this expensive stuff in such a vulnerable location? I WILL be re-locating my sensors, probably inside the frame rails.
