Isuzu Trooper Engine Misfire
I am trying to fix a problem with a '01 Trooper Limited 4WD. The vehicle has 75,000 miles and started to sound rather rough. My wife had the vehicle checked at a shop and was told the EGR valve was bad. I replaced the part as well as a new set of plugs, reset the OBD codes and the car runs a lot better. I am still getting a P0300 code (multilple engine misfire) and the check engine light blinks only when the car is moving. It does not blink when the car is not moving even if the same RPM level is reached. What is causing this misfire?
The other known occasionally >60K miles failing part on the 01 Trooper 3.5L engine is the intake manifold gaskets. These are thick composite insulating gaskets, and they can sometimes crack allowing air into the engine. Air input into the engine at a gasket leak bypasses the air filter and engine computer monitoring. This can cause damage from dirt sucked in and poor engine performance because the computer cannot adjust the fuel mix properly to account for the extra air. The replacement gaskets are supposed to also be better than original so the problem will not happen again.
Any ideas what to check next? :confuse:
Is the loss of power extreme when it smokes? That might favor the not firing scenario.
Paison I think, had a failed catalytic converter slowing down the air flow and that caused power problems.
HTH One guys opinion.
The 5 plugs are still out and I haven't tried to restart it since I replaced the o2 sensor.
Also, where is the connector for the code reader ( i looked )and the location of the crank sensor?
Early Troopers had the plug tucked behind console where it meets the dash. Carpet may be over it. Later Troopers had it in the LH kick panel behind the trim. Try a search, may help on both questions. Include your year, model and trans when posting, makes it easier to be specific good luck.
Could be a coincidence that your battery went bad too. I'm not enough of a mechanic to begin to tell you where to start troubleshooting. Plugs and wires or the coil maybe?
-mike
K16PR-P11
PK16PR11
RC10PYP4
found this on another site: "If you have a 2000-2004 Isuzu, make sure you only use Denso K16PR-P11 spark plugs. The 2000-2004 engines have the GM/delphi "ion sensing" ignition system where the spark plugs are used as a sensor (when they are not firing) to measure the electrical resistance of the gasses in the combustion chamber. Other plugs may cause the ECU to register a code (misfire code: P1340). Also, it has been noted that some 00 trucks came with champion plugs from the factory, which cause knocking, due to to ion sense coils.
If you have 1998-1999, the suggested plugs are NGK or Denso or Champion double platinum plugs"
HTH
Manual:
K16PR-P11
PK16PR11
RC10PYP4 (Champion I believe)
Bill
firewall
5 6
3 4
1 2
fan
