Smart Fortwo
Now you have everything you need to change the oil! Put a little drain pan under the drain plug and drain the oil then using a filter wrench(I used one that tightens as you turn it) loosen the filter and install the new one putting a little oil on the o-ring seal and hand tighten securely. Remove the carpet and engine cover on your Smart Car on put in the required 3 1/2 quarts of Mobil 1 Synthetic 0-40 w oil and your done. Start the car and make sure you have no leaks. I have changed oil in different cars in my day but I must say this is one of the easiest cars to change oil in have ever seen! It is may be a 15 minute job.
Dennis
(synthetic is too "slippery" and won't adequately clean the fine grit and gunk out)
Technically you don't need to change the oil. You need to change the *filter* so that it isn't half-clogged with these particles. And yes, the oil that comes out from the first change usually has grit in it that you can actually feel if you rub it between your fingers.
Dennis
http://www.reuters.com/article/pressRelease/idUS130408+07-Apr-2008+BW20080407
If you read it carefully, the reality is that Mobil 1 may or may not be what the factory puts in the car. However, synthetic is definitely recommended. The smart takes only 3.5 quarts for an oil and filter change, and the recommended interval is 10,000 miles. I would never let MY car go 10,000 miles, but maybe you would.
The engine is the 2008 smart is made by Mitsubishi. The filter is a Mitsubishi filter. smart puts their name on it and charges over $20 for it. Yeah, right. There are many alternatives. None cost over $8.
Dennis
Why would you get the SmartCar over a Toyota Corolla, Prius, Civic Hybrid/Regular Civic, or MINI?
I expected the vehicle to get at least 50MPG- as small as it is.
IIf you folks run out of gas can you pick it up and roll it backwards a few times to let it go forward again?
-Dean
the smart is much less expensive than Prius, Civic Hybrid, or Mini. Comparably equipped, it is less expensive than Civc and Corolla, although the gap is a little smaller.
One would get a smart because it is less expensive, and gets better mileage. Also, it has side airbags, stability control, traction control and anti lock brakes all standard. The Passion model which is under $15K has climate control A/C, power windows, locks, heated power mirrors, CD with MP3 and Ipod jack, alloy wheels, a totally see through polycarbonate roof, and an automatic transmission than can be shifted manually with paddles on the steering wheel or with the floor shifter. The body panels are plastic, and all the panels can be swapped in an hour for about $900. If you have black and want red, you just swap panels. Options include heated leather seats, rain sensing windshield, 6 disk changer with sub, etc.
If you commute alone or with one other person into a tight urban area, the smart can't be beat. It is a niche car, not a general purpose car.
There is a 12-18 month waiting list for the smart. You can have a wide choice of Corollas at any Toyota dealer.
A great page all about oil.
Of note is the section down at the bottom where it talks about magnetized oil traps and larger filters.
"The small oil filters fitted to engines these days run with quite a high back pressure, and the bypass valve trips at about 3500rpm. That means that your oil is not being filtered when the engine is spinning faster than 3500rpm. As the oil filter does its job and starts to clog up, that rpm value can be lower."
Since the tiny filter and engine in the Smart runs at 3500rpm a lot of the time, changing the oil early is a good idea. Metal bits in an engine of any kind are "A Bad Thing" and cause excessive wear on everything that they touch. While the original oil may physically last 10K or more itself, the engine will be full of grit and grime long before then.
http://www.noria.com/learning_center/category_article.asp?articleid=89&relatedbo- okgroup=ContaminationControl
Grit of any kind - be it sand or metal powder and bits drastically hurts the longevity of engines, especially the smaller they are. That's why it's hard to find good working motorcycle engines past 10-20K miles. The Smart's engine is on the very bottom end of the scale. 700-1000CC engines are already at numerous disadvantages to begin with.
DC isn't using special oil or pretty much anything. What you're getting here is the same engine that Mitsubishi sells in their second smallest cars in Japan - dropped in and sent on its way. As such, it needs old-school methods to combat early wear/changing oil.
Go ahead - the oil change is simple. Change the oil at any time under 1K on a Smart. Rub the oil between your fingers and around the bottom of the collection pan. It's eye-opening.
Well apparently you can run lower octane in the engine with a very slight drop in MPG. But look at it this way, around here premium has always been 20 cents more than regular. At todays prices that means that premium is less than 5% more than regular. With the Smart being rated at 33 city and 41 highway with premium that would equate to 31.5 city and 39.1 highway for regular. So the slight increase in the price of premium will not wash out the extra mileage the car gets.
It might be a wash at a dollar a gallon but not at current and any foreseeable price.
Thus far, the only issue that has cropped up on my '06, is that I recently discovered that my A/C dropped the gas. Guess I didn't cycle it often enough over the winter, and luckily our summer weather has yet to materialize, so I am not that bent. I intend to recharge it sometime in the next week or two...
Last I looked a yea ago, there was a site to go in to order a Smart and pay a $99.00 deposit. Has anything changed and, can anyone help in cutting time out or simply respond to what to order. I prefer the top model with all options. Any thoughts out there? Pete
Dennis
Prices on eBay are going up. When the smart first hit the shores five months ago, before gas spiked and awareness of the car was raised, you could snag a Passion for $15-16K or about what sticker + destination + fees was. Now they are $18-19K. There have been a couple with thousands of miles on the odo go for over MSRP. I think they are going to be like the Prius/Insight/Civic Hybid, where if you can get your hands on one, the depreciation is very low. I read a post from a guy the other day who sold a Honda Insight with 50K miles on it for more than he paid for it new.
Sam in Anderson, SC
Another problem right now is that the factory can't build any more cars. The one and only smart factory is actually in France, even though smart is a Daimler vehicle. France has very restrictive labor laws, and it is not easy to add extra shifts of workers. Since there are only 25-30,000 allotted to the US, and the waiting list of ordered cars is well over a year, I doubt they will consider importing the diesel for a couple of years until they get the dealerships sorted out and figure out how to squeeze more vehicles out of the factory. Why bother at this point?
There is also a version that shuts off the engine at stoplights and starts it when you step on the gas. We can't get that one, either.
There is also an all electric smart undergoing testing in the UK. It is supposed to be available in 2010, but the details are sketchy right now.
http://www.informedforlife.org/demos/FCKeditor/UserFiles/File/1MasterSCOREr.pdf
It is a deathtrap on wheels. You can't repeal the laws of physics with clever merchandising.
Govern yourselves accordingly.
Also you need to check a little closer yourself, the smart scored 131 mostly due to it's weight being factored into the frontal impact score, so sorry your argument is dismissed (it is the chevy HHR that has a worse score below it for 2008 models BTW)
Scott
The informedforlife.org is a credible organization headed by an engineer who got tired of seeing the highway carnage caused by unsafe vehicles. For a summary of the founder's credentials, refer to the "About Us" section. The scores are comprehensive, objective and unbiased and, unlike other highway safety analyses, take into consideration all known safety factors pertaining to a vehicle. The data is updated when more current information becomes available and as of this date was updated only yesterday, June 28th. These factors in my book makes their data the best available in determining the comparative safety standings for cars.
The weight of the car in a crash is very much a factor in determining whether it is safe or not and correlates closely with driver and passenger morbidity and mortality statistics. Unfortunately, in the real world the car won't be driven on roads shared only by vehicles which are its size peers but by all vehicles, including those weighing 3,000 to 4,000 lb. and above.
The data is not meant to "scare people" as you state. It is meant to inform them and keep them alive should they suffer the misfortune of being involved in a motor vehicle accident. Just because you prefer the most dangerous car in the survey doesn't mean that everyone does. People should have the complete facts before them in deciding on a vehicle purchase. Informedforlife.org provides a valuable service in providing the most complete picture presently available of whether a vehicle is safe or not compared to its peers. Try not to be so defensive. If you wish to ignore the facts, that is up to you. As for me, I would rather have all the safety data available before making a decision to purchase one vehicle over another because in the final analysis it is safety which is the most important feature of any car.
Is everyone supposed to ditch their older small cars which test even worse than the smart? Are urban cars to be forbidden? Should motor cycles, scooters and bicycles be outlawed because they are so much more unsafe than the smart?
Safety is NOT necessarily the most important feature of any car. It depends on who is doing the shopping. You don't want a smart. I get that. Now please shut up.
Sam
Scott
Dennis
Incidentally, I wasn't denigrating anyone. That is more your style.
Dennis
http://www.smartcarofamerica.com/smart_car_of_america/front/the_smart_car_saves_- - a_life.html
