Volvo S60 Maintenance and Repair
I own a 2004 Volvo S60R with 75k miles on it. I'm very happy with the 3 year test drive to date except for one thing; the bi-xenon headlight low beams aim too low. I'm not sure if they have always aimed too low or if it happened following routine maintenance at my Volvo dealership. I've had the Volvo dealership check the lights and they said they were at spec. By the way, the high beams work great. Does any one have a similar experience? If so, any possible fixes - please advise.
Somewhere on the net I did find a service bulletin from Volvo to their mechanics that specifies the fix, however most folks shy away because if the procedure is not done absolutely correct will can really screw things up. I myself chose to deal with it.
If this does not fix the problem, there is a manuel solution to fix this. Here are the pics I got from another owner :
http://s60r.fadainc.com/pics/adjust_headlight_switch.jpg
http://s60r.fadainc.com/pics/adjust_headlight_wrench.jpg
my 50 cents
I thought of replacing with an HID xenon headlight kit but they are not legal in the US and I don't want to go there.
Bob
S60 OEM XENON BALLAST
