Volkswagen Beetle Engine Problems
![hottaco69](https://secure.gravatar.com/avatar/535a4d26053db71edb176c83afc3aeed/?default=https%3A%2F%2Fvanillicon.com%2F79730bf3eede7434fbebc19644e4eb51_200.png&rating=g&size=200)
in Volkswagen
Every now and then the car has these sort of "hiccups", where I feel the fuel isn't getting to the motor sufficiently and the car begins to have spurts of speed and then will cut off and then on again. At the beginning, the motor would just shut off and as soon as I would turn it back on it would be fine, but now its getting out of control; I'll be driving and all of a sudden it will feel like some one pinched the fuel line and I will instantly loose 10 MPH and then it will go back and forth. I notice this happens usually when I have the AC on (set to a low or 1). I have taken it to 2 different VW dealerships and they have both said the same thing, and have found nothing wrong with the car. I am going crazy because no one can tell me what the hell it is or what the F$#% I should do. I hope someone could help me in this matter, PLEASE.
Cheers,
Bico
P.S. Nothing has been done to the car, and has all of its stock parts
Cheers,
Bico
1
Hope that helps.
Kin >a woman <
Car will turnover, fire up and immediatley shut down. No diag lights or inidcators. Getting fuel as I hear the main pump humm for a second when the door is opened. After start atempt there is a continuous high pitch whine sound from under the hood. Not load and would have probrably missed it if hood was down. This sound lasts for 5-10 mins after key is out and doors closed.
One ONE start only I get the three beep signal but could not reproduce (just to keep me guessing I guess). Checked oil thinking MAYBE it was very low and a sensor would not allow it to start. That did nothing.... The high pitch sound that I still hear seesm to be running enough to be draining the battery as well. Any ideas?
Brian
Another interesting point is the fuel feed lines (coming from behind the coolant overflow) I believe these are 4 of then that plug in (so to speak0 vertically, smaller plastic pipe inside of them (hope that is good enough description) sem to be out a little and not plugged in tight, and pressing down does not push them in and lock or stay down in any way. When pushed or slightly moved I hear the motor spin up to prime the fuel line again.
I will say this is another in a ongoing HUGE amount of repair work the car has needed. Other problems include one of the automatic fans completly breaking part inside the engine compartment (how I dunno). Ful pump (the one in the tank) once, O2 sensor X 2, Sunroof coming off tracks when closing andjamming. Driver window breaking aprt in door when closing window (not I was not closing it with a hammer). AC going to warm when engine idles for more than 30 seconds (may be due to the fan mentioned above allowing it to overheat and take damage). Thats all I remember off top of head, but there is 4-5 more major problems I have dealt with. I am thinking righjt now about getting it fixed and trading in on a non VW car. If not for extended warrantly would have had it sitting in d5riveway since I could not afford to have all the work done.
Brian
Brian
Cheers,
Alberto
Anyone looked into a recourse to these problems? This treatment of customers should be illegal! Any other product that acted this way for so many customers would no longer be for sale!
I called VW a couple weeks ago and they could do nothing to help me despite having a check engine light on right after having service done! I can barely turn the GD thing off and on again without a problem! ARE YOU LISTENING, VW?
I need some help here about my 2001 VW beetle 2000cc.
I'm having a problem within the air flow, I tried to scan it using my scan pro, and its shows:
Trouble code 16795
Secondary air injection system : Incorrect flow detected.
Right now I dont know what I should do with this
problem.I tried to erase it but it still show up.
Can somebody tell me what is the problem and which stuff causing it? And please tell me too how to resolve it.Or it could be better if you can explain to me clearly. with a picture or what else.
Thank you so much, and really2 appreciate it.
Andy
hose(?) that comes off the main air intake was cracked/melted(gummy)and the little vacuum hose that connects to the fuel rail was also melted and craked, I sealed them with tape and the Check Engine Light went off and the car was working OK until yesterday that the CEL came on again and I found out that the rest off the hose cracked too, What are the names of those hoses?
It has a 5 cylinder engine with Turbo.
It is not a Turbo S.
I have not been able to find a listing of this combination and I would like to know more about specs and performance. Is this a standard model or something special? Where can I find detailed information?
good luck! :confuse:
Has anyone else had this problem?
Charlie
Our local mechanic can read the codes; he's reset the codes and then the car doesn't stall any more. That happened last week, the car was fine for a few days and then it wouldn't start again. This has happened several months ago; the mechanic resets the codes and it's fine for a while. I need to find out why the codes are screwing up though. This isn't rocket science. Either something electronic needs to be replaced or.....
Also my engine light is on all the time, but the car is fine; I just make sure it always has the proper amount of fluids. Thanks for any advice!
I am looking for the sequence the VW Beetle uses for this and what the service codes are. Mine is a 2002 turbo.
Thanks in advance.
Brad
My problem? After removing & replacing CD changer to free a stuck CD, I inadvertently shorted the radio circuit. The "Fuse Card" inside the fuse box door doesn't indicate which is the radio fuse, so I pulled each fuse and found all were okay. Discovered there is also a fuse on the back of the radio (of course the manual doesn't tell you - they want you to go to the dealer.) I borrowed the radio removal tools from a friend's auto body shop, removed the radio & found the 10 amp fuse was blown. Had to remove the three plug-in connectors for the radio wiring to get the fuse out. Replaced the fuse & connectors & all was fine (I thought.) Went to start the car & it turned over but didn't start. I immediately thought of the fuses and found I inadvertently put fuse #29 in slot #30. Put it back into #29 and the car started & runs fine, but the check engine light is on. What the f...! Can't get to a shop to check the codes for a few days. Any ideas anyone?
Also, since replacing the radio fuse, it works okay but no longer shuts off automatically when the key is removed from the ignition. Also, the CD changer won't recognize discs. It goes through the magazine check but won't play - says "Disc Error" even using commercially made discs. I've read that solving one problem creates others but I haven't had that experience - until now. Weird! Any advice will be appreciated.
Sincerely,
Punchbuggy-yellow (A.K.A. Happyvolvo.)
After driving it a couple of times it overheated. It melted and blew 2 plugs out near the motor and that let water spray out onto to motor.
The mechanic replaced the timing belt and the water pump.
I drove it a couple of days and it overheated again.
I knew the folks we bought it off of and they said they hadnt had any problems with it. It hadnt been driven since winter. Now after owning it 2 months we have only got to drive it about a week tops. Its overheating again. I have a thermostat ordered from VW and we will replace it this week. The fan is running fine. Any ideas what else it may be.
I am so aggrivated.
We also had to replace the a/c compressor. We bought a used one and it was fine until one of the lines blew. This is the only used part we have put on it. The compressor is fine but the line is going to cost 272 plus labor..
I have installed new plugs, runs a little better but still stalls at times
Thanks in advance.
Lately tho' the past week or so it has been cutting out on me when I'm going round roundabouts,sitting at lights and turning corners like i have stalled it..and I know I havent! Have to put the hazards on and restart worried that someone is gonna go into the back of me...by the way it is a new battery
Has anyone got any answers?
Please help Sarah
