BY
That's all that was mentioned. It sounds like they are simply points of contact who speak FOR the club when the hosts need input regarding changes, new topics, etc. I also think that the hosts don't police those topics like they do over here, and need a member to keep an eye on the discourse.
I am willing to do it too (even though I won't be an owner for another week-and-a-half, or so).
Why don't we give a couple more days for other interested people to volunteer and then we can decide as a group? If nobody else volunteers, then BYM (if you're still willing) and I can do it. OK?
Does anyone know how those dimming mirrors work?
Spiritman
Also spoke with the salesman who I test drove with last week. He told me they have no more Rendezvous' in stock and that the next shipment is all pre-sold. I think this vehicle is H O T.
CWJ
Well, we finally got some sunshine today (after almost a whole week of rain and overcast) so I took a test drive of RDV #1 (white/moss green). I drove it to my house and took some photos that do the green SOME justice. I'm very new at this personal web page stuff, so if I can e-mail the pictures to one of you, could you post them?
P.S. The moss green looks MUCH better in person than in any photos. During my 20 minutes with the car, I got a lot of admiring looks and a woman jogging by as I took the pictures said, "that's a nice car!"
MY OPINION: I don't believe any other car has a dimming feature for the outside mirrors... either automatic or manual. I think they would have to mount a sensor somewhere and then have mirrors similar to the interior rearview mirror (provide an image from more than one angle). It likely is not done right now because the sensor would be very fragile and likely too expensive to replace/repair.
GO RAIDERS!
R5
I am considering purchasing either a Rendezvous or a Toyota Highlander.
Any input would be greatly appreciated. I am nervous that both my selections are 1st year models and I have always been told to avoid the first year
Steve
My other need is for a way to play MP3's thru the sound system with the option of the 6 CD stacker....seems I heard of a MP3 player that transmitted an AM signal that you would tune to a certain frequency to hear it.....I had one to play my records 30 yrs ago so its not particularly expensive or new technology.....we have the 12v outputs to power such a transmitter if one is available.
Spiritman.....12 days since I ordered but whose counting
There is a light sensor on your rear view mirror, right under the mirror and to the right. You'll see two indentations on the bottom of the mirror, one of which has a light that turns on when the dimming mirrors are on, the other is the sensor. By measuring the amount of light coming into that sensor and comparing it to the light being detected via the Auto Headlamp light sensor (located on the top center portion of the dash, right next to the light that flashes when the vehicle is off), the CPU can then determine if the light coming into the rear view mirror is brighter than the surrounding light, and dim the mirrors appropriately.
The "Electro" portion of Electrochromatic refers to a substance placed in a layer of the mirror that gets darker as voltage is applied to it. How dark it gets depends on the voltage applied. By using something like this as compared to auto dimming sunglasses, you have much more control as to when the mirror gets dark, as well as how dark it actually gets.
If you want to try an experiment, go into your garage, turn on the RDV and shine a flashlight on the rear view mirror's light sensor, and you'll see the mirror go dark. Now if you take it into the bright sunlight, then mirror probably won't darken, or won't darken much, as the surrounding light being detected by the headlamp light sensor will also be bright, and the CPU won't detect much light difference between the two.
Hopefully that sheds some "light" on how the mirrors work.
BY
Here's a link to something that might work...
http://www.akoo.com./products/ks110_how-it-works.cfm?CFID=27168552&CFTOKEN=60930609
Good Luck!
BY
I realized that when I enabled my personal webspace, I forgot to enable FrontPage 2000, so it only accepts HTML. My website should be up later tonight.
I've always wanted to learn how to do web page authoring but up until now, I've been intimidated by the technobabble. It's actually pretty simple as I was up and publishing after about 1 hour of study/practice.
I'll follow the instructions here but I may ask for help on how to post pictures here, as I know there are several different methods.
On a side note, was it you, CWJ, who said that the passenger side view mirror aims towards the ground when backing up? I test drove RDV #1 today and it didn't do it. Maybe it only comes with the memory option (which RDV #1 doesn't have)?
Brian
http://www.mclaugh.com/gamera/gamera.htm
CWJ also sent me a couple other pics of the early sketch and prototype of his RDV:
http://www.mclaugh.com/gamera/RDVConcept.jpg
And
http://www.mclaugh.com/gamera/RDVEarlyPrototype.gif
http://www.mclaugh.com/fedlaw1/fedlaw1.htm
Enjoy!
BY
PS. Fedlawman: Good luck with the web page! I'm sure it'll be more extravagant than my basic pic ones have been so far!
Regarding RDV #1, I'm sorry for the quality of those photos. I am disapointed that the moss green isn't clearer...only the rear shot looks good.
P.S. I'm just figuring out how to add backgrounds. I'm afraid it's nothing special yet.
I have seen the passenger mirror tilt down in reverse and back when in drive....and it returns to normal after a short pause if you don't start moving backwards....I beleive this is a programmable feature altho it didn't tilt down enough for my taste.....only had a short time checking it a another dealers though.
The new Motor Trend has a positive review of the RDV with comparisons to the Ford Explorer Limited and the Toyota Highlander.....I saw the Highlander when I first went shopping and thought I would get one until I saw the RDV and thought the RDV blew the highlander away in all respects.....mostly design in and out!
Spiritman
This is kinda fun!
http://www.fototime.com/inv/1D2D1AA98E123F4
BY
http://members.home.net/fishkin1/images/brianrdv.jpg
Drew
Haven't read the rest of the posts yet, I've been out of town for the last few days.
CWJ
Lots of people commented positively about the RDV; several people we didn't even know pointed to the car as we drove by; it seemed they obviously knew something about the RDV.
Go 9ers!
John B.
CWJ
Drew
mmeehan: I assume you edited the photos to get the "gold look"; as cwj said, you'd need to touch up the wheels as well; and perhaps the rear Buick Badge on the tailgate too??? That may be a bit much.
cwj: I believe it was you who said your front seat belt got twisted around - - funny thing, on my drive home from campout, I noticed the same thing on mine... Seems odd. And it doesn't seem like it's easy to fix. Was it easy for you to fix yours?
Brian (fedlawman) - Thanks for your kind words on Gamera's look. I appreciate it. You may recall that the first Rendezvous I drove was exactly like RDV#1, so I know about what you speak when you say that the photos do not do the Moss Green justice.
CWJ
Where is the power? GM really messed up when they mated this multi-ton truck to a 3.4L V6... How about the 3.8L? Or even the new 4.2 I6 from the GMT-360 trucks (GMC Envoy, Olds Bravada, Chevy TrailBlaizer)? This things claims it can tow 2000 pounds stock... I'd like to see it try. One hill and you're gone... that is my biggest complaint about the car, is that 185 hp just doesn't do it justice! Then again, I came from a 99 Trans Am WS6 that was pushed to over 400 hp so dropping down to 185, I expected a significant power loss - but this is just pathetic!
Next is the styling... I think it looks nice... the curves and geometrical shapes work well together - except from the back... if you look at the car from the rear, it looks like a completely different vehicle... It's narrow, oddly proportioned, and looks as if it'll tip on the first turn. Also, what's with that exhaust pipe? We're they joking when they put it there they did? It looks like a dog that put it's tail between it's legs... I would have liked to seen either side exit pipe, or maybe a dual setup, like the Acura MDX, which, although rather outdone, looks nice.
The one things I really like about the car, and that gets the most attention/compliments, is the interior. It's probably the first GM interior that actually *SAYS* something about the car... fun, new, exciting, yet refined. Maybe real aluminium should have been used on the accents on the dash, doors, and gauge pod, but it pulls the faux look off nicely.
The sound system, for being a stock system, isn't bad at all... certainly sounds better than the "Monsoon" system in my old Trans Am. I will be removing the entire system in favor of something a lot better, but for now it sounds alright...
Lastly, the tires/rims... I've gotten mixed feelings about these since picking up the car... They look nice, but the fender wells and wheel arches are just BEGGING for some 17" rims with nice, lower-profile tires. Obviously the Rendezvous isn't made for off-roading - which is completely acceptable for me... I don't plan on doing any "muddin'" in the car, and I doubt anyone else in the 18-24 bracket like myself plans on it... but GM really should have offered a little better wheel/tire package with the uplevel CXL... alomst every other luxuary SUV offers AT LEAST 17" rims, with some moving up to 18" and beyond (Mercedes offers 19" on ML430, BMW has 19" Sport Package), I think it's time GM, and especially Buick, catch up...
Other than the aformentioned foibles, I think Buick has outdone themselves with the Rendezvous... Tiger's "toy" has proven to be an acceptable addition to our family (now consistening of the Rendezvous, and a 99 Buick Park Avenue Ultra - I really miss my Trans Am...) But for our needs, the Rendezvous fits in perfectly...
Anyone know of these subwoofers canted rearward? Quote from Buick site.
Spiritman
As for GM's new I6 engine, there is no way that such a long engine will fit underneath the hood of the short nosed Rendezvous. The pushrod 3.8L V6 may though, as would the nice DOHC 3.5L V6 in the Intrigue. Perhaps in the near future?
Drew
Can you shed some light?
CWJ - I just had to tell you. After getting another look at Gammera, I love the colour combination. I'm sure it's a trick of the eye, but the greymist cladding looks almost plum, and it's fabulous.
Mmeehan - What ever happened with your "check traction control" light?
Brian, if that's OK with you, I'll go and make the arrangements (whatever they entail) tomorrow.
Drew, can you tell me what I need to do?
Brian
Spiritman
In my car, a loaded CXL with the 1SE package, among others, the setup was as follows:
1" tweeter/6 1/2" component system up front
6 1/2" full range in rear door
6"x9" sub woofers in the sides of the cargo area
6-disc in dash changer
I don't know about an amplifer or the wattage of it, but I had the "500 watt" monsoon system in my Trans Am and after some test, that 500 watts was only at peak, all channels, with about 10% total distortion... most good amps will have WELL below 1% THD...
The 6" sub/4" full range system is ONLY available on the Aztek and NOT on the Rendezvous...
But you have to agree - for what the Rendezvous was made for, a more luxurious rim would have fit quite well... I'm not talking rollin' on 'dubs' (20" rims... damn that rap music :-), but something in the 17" flavor... maybe 245/60 series... like the rolling stock on the Envoy, or even the 255's on the Bravada... What do you think?
The other reason the wheels look small on the RDV is because the vehicle sits high above the wheels. To pull off your desired look, you should probably lower your RDV about 1" (1.5" in the rear, since it appears to sit a little higher than the front).
Of course, it sort of defeats the purpose of owning an SUV...like the drug pushers that drive around in lowered Lincoln Navigators with 40 series whitewall tires on 14" wire wheels. Uggghh!
Brian, I'll pass this onto Karen, the host of the owner's club message board. The owner's club area is basically an area that is specifically for a vehicle. This current discussion topic will still be the area for general discussions (it will be linked to the owner's club area), but the owner's club will also have a "Meet the members" topic where you can all introduce yourself, as well as a Photo gallery topic where you can post the pictures of your ride to your heart's content :-). Sound good?
Drew
Thank you again for the further kind words on Gamera's look. However, the lower cladding is the Dark Bronzemist, not the Graymist you mentioned in your post. Does that difference explain the effect you were trying to descibe, or was the reference to Graymist just a typo? Regardless, I'm sure you've noticed that there are a lot of red highlights in the Sedona Bronze. On an overcast day, it's just the (I think, very classy) brown car about which others have been less than enthusiastic. However, on a sunny day, all those highlights come out and the color comes alive. I bet the Indigo Blue does much the same thing in its own way.
I second the nomination of the two Brian's as sponsors of the Owner's Club. Both of you have just the right temperaments to be excellent hosts.
Finally, thanks for chiming in on that other board. You made a fine cavalry patrol to my circled wagon train.
CWJ
Sounds good to me. I may not be too available this week as I'm on vacation and not on the computer too much, but I'll probably be checking in at least once a day.
Off to go work on the lawn mower now...
BY
Drew
