Ford Windstar Engine Problems
I Have a 2000 Windstar 3.8 6cyl, I recently had a code P0507 which read engine running lean. I replaced the intake gasket along with a few other gaskets, no more code. My question now would be when my engine is idleing it hesitates sort of a misfire, also when I'm driving it feels as if it has a misfire. Does anyone have a clue as to what this may be? Mechanic says plugs are good.
thanks.
thanks.
what's causing it?
It's a 98 Windstar with 3.8L motor.
Thanks for any information. S. Dechant
Thanks.....Dave.
I found that this site has good pictures on it.
http://community.webshots.com/album/201931518cScpNK
Like others on the net, this is not too bad a job for do it yourself. 4-5 hours. $5 can of intake cleaner, some rags and a bent paper clip to open the ports. Don't know why mechanics want $500 to do it. :shades:
I'd either scrap it and buy another vehicle or put a used engine in it...you could surely buy a newer and lower mileage windstar for way under $5000. You could also consider a rebuilt engine, but that would also likely cost more than the van is worth...but not by as much as a $5000 new engine.
Thanks for the advise!
teneubec
It might be worth close to that $200 as scrap metal.
The problem is that i need to let the car heatup 5 min on bad weather, i've got no Kickdown on hightway, and on the street if i press the gaz pedale, the engine don't give me any boost, or power, it seem that the truck can't breathe it seems that the cataliseur is the probleme or the senseur, i want to change those part, 2 Catalytic on it.
Would that solve the power and the kickdown.
I had problem with the catalitic then decide to simply clean it up in a way, i then change all the sparkplug, and still car doesn't have engin power, it's like the engin can't give me full power.
I know it's a old car and i cant do Kickdown, the transmission is not 100% perfect, the problem is really about power, even on PARK, if i press the gaz pedal, engin wont run smooth, and increase to 4rpm, i can barelly get to 2rmp.
What could be the problem ?
Could it really be about the catalic would it be the best solution to remove them, since they cost a bundle to fix.
I try to punch a hole in them ( sorry i dont have the proper term )
I notice i've got one Catalic sensor or two that are broke, would this prevent the engin to give his full power ?
On the hightway, at 100 or 120 kl, car run smooth, little bump sometime, but overall engin is smooth, but i cant accellarate like any other truck.
Any suggestion
Thx
Sam
on the stop sign the idle is very low and the car want to die and oil light cams on
when i put on park is ok
i replaced idle sensor
still same problem i send to the mechanic i put the code reader and the codes are
1- p0401 2- p1538 bank 1 3- p1537 bank 2
i replacet bank 1 and 2 still same problem
in the start when car starts is ok after 5 minutes driving starts the problem
any idea
I need some answers and don't want to replace the pan and find out it's not worth doing. There must be some sort of test or explaination for this. This van was running fine and is in mint shape as well. It'd be a shame to scrap it for the wrong reason.
If you have any ideas, please contact me.
Thanks, Steve
Please....some one help.
Anyone out there have the same problem?
gworley
thanks for the reply. My Windstar also lopes when I start it and then dies if I don't press the gas pedal. I can let it sit for about ten seconds and pump the gas and it will be ok for about two days. No check engine light at all though.
My WS was idling rough so I got a tuneup and oil change @ 100K miles. A couple of weeks later the oil light came on; I checked and I was almost dry.
Took it back to the mechanic who said I need a valve cover kit.
Took it to another mechanic today who agreed with the first guy's diagnostic code (vacuum seal leak?) but he says I'm losing too much oil for the valve kit to fix the problem.
Expl: I put in 2 quarts 3 days ago and today I've lost a quart of it.
Mechanic #2 fears the problem is in the motor but won't know until taking things apart (costly).
Does anyone have any advice?
I will let you know how this all turns out for the idling problem.
Good Luck
