Mitsubishi Diamante Timing Belt
givio
Member Posts: 2
Can anyone please help...I'm a US Soldier stationed overseas in Germany. My first problem...I am trying to find out what parts must be changed when changing the timing belt. A mechanic told me that there are more parts besides the belt itself that needs to be changed. I'm not sure what parts the mechanic is talking about. My second problem is that they don't make Diamantes here in Germany. I have to order all my parts from the U.S. Does anyone know of a good place to order parts from. I Love my D...I refuse to sell it for a more practical car. Plus she drives nice on the autobahn. I appreciate any help. Thanx
I will say that when you replace the timing belt on the 3.5L, if that is which engine you have, you should replace the tensioner along with the belt, you should really consider replacing the idler pulley and water pump.
More often than not, if you don't replace the idler pulley and water pump when you replace the timing belt, you will end up replacing them later, which can be a royal pain.
To give you an idea of what parts are involved, Here is the parts breakdown.
Now that I have the info I can order the parts. Is there anything else that I should know. Once again thanks a million
GOD bless!
and am looking at what to do. Givio....where at in Germany?
The following websites are surprising helpful for parts ordering.
http://www.advanceautoparts.com/
http://www.autozone.com/home.htm
I have a problem that my car is idling and the machines in England cannot read the data to correct the idling. If you know of anywhere in England I would appreciate it.
Many thanks
The front 3 plugs are easy to replace.
To get to the back 3 plugs, you must remove the upper intake plenum. Just remove the bolts (Several hoses must also be removed and the throttle-body intake hose must be slid off the throttle-body.) and pivot it backwards over the firewall and secure it there while changing the plugs. Use an new gasket when reassembling.
It's not too bad, maybe an hour.
http://www.rockauto.com/
Any one know where could be the problem ?
Manufacture suggest replacing water pump!
Also look at your tensioner,it may need replacing also.
Make sure you adjust the timing belt tensioner correctly,or it will cause premuture
belt failure!
It sounds like someone set the timing using the #4 plug!
