Toyota Tundra Real World MPG Numbers
The dealers say that the 5.7 V8 gets 14/18 MPG on all of the cab sizes. Can anyone tell me what they are really getting out of their 5.7 tundras? Most importantly what is the highway mileage, i know the city is going to bad.
I have your page bookmarked for future reference as well.
I drive A LOT! I'm averaging about 1200 miles/wk now mostly driving in TN and KY. 75% of my driving is on Interstate running around 75 mph. I have not reset my fuel calculator in about 1500 miles and it is exactly on 17.0mpg. For the first 3000 miles it would avg around 16. If I stay off of the Istate, I can avg 18-19.
17MPG is definitely a real world number if you drive like you have some sense. Hard take-offs are a killer. I have refrained from this completely since gas went to 2.50/gal.
I just checked out fueleconomy.gov. Under the 2008 testing procedure, they have the 5.7 pegged at 13/17, combined 14. So the new test may in fact be closer to reality than the old one.
14 to 15 average, 18 to 19 on the highway/freeway.
The average fuel mileage calculator seems very accurate and you become conscious of the current fuel mileage calculate graph, although I wish is was digital numbers rather than the bar graph.
I have read on some other sites that mileage improves overtime.
I get my tonneau cover next week, so we'll see if that improves the mileage at all.
About 55 of those miles are on the I-15 freeway.
I drive between 65-75 miles per hour.
I have had my truck for less than 2 months and have around 6000 miles on it.
I have been averaging about 15.5mpg!! (Not 20!)
I even went so far as to reset my trip gauge... freeway drive conservatively at 70mpg or less trying to coast and not put any foot into the gas and I was able to bring the mileage for the 50 mile drive on the freeway up to 17.8mpg.
I think the more realistic driving pattern is around 15-16mpg on this truck.
I love my Tundra... it is not Prius.
If you want a truck like this ... know that you are getting a truck that is a truck and with that you get Full Size Truck gas mileage. Despite the creative 15city and 20highway sticker they placed on it in the dealer lot.
You won't ever see 20mpg and they must have had a downhill with the wind at the back of the truck day of testing at the Tundra facility on the day they made that sticker. ha ha!
Note: This Truck Rocks!!
TOYOTA- no 4Runner, no Tacoma is going to pull 5,500 all day long without being severly taxed. Your mileage would be single digits because the motor would be in it's power band the entire time pulling. The Tundra would do it easily with a drop in mileage of maybe 3-4mpg.
NISSAN- I wouldn't do the Frontier. I've read posts where towing yields 8-9mpg. That goes back to that little engine working it's heart out. (I am referring to the V6)
DODGE- I'm not a Dodge fan but my brother has a 1/2 ton and that thing pulls/tows with the best of them. He gets around 10mpg when pulling a 6,500 trailer loaded. Now you throwing a 2500 Cummins diesel into the game is like Jerome "The Bus" in a pee wee league football game, no contest.
As to whether I will try to shoot for 22.0 (currently the best i could pull off with real effort, and not likely to be reproduced as a rule) or just set the speed to 55 and get 18-19 MPG is going to take some time to work through.
Either way this truck dominates my companies old 2001 Chev silverado HD in the fuel department. It would rarely yield more than 350 miles on the same tank, often less.
Love the truck, and i really can't fault anyone for only getting 15-17 on the highway because its a lot of fun hammering past the other half tons (did it a fair bit in the demo) but i am not ragging my engine till its been broken in.
Regarding the new 5.7 liter Tundra in towing:
Because the intelligent variable valve timing achieves >90% of peak torque over >60% of the RPM range, and the peak torque of 401 ft-lbs exceeds that of Ford, Chevy and Dodge (including the Ford F-250 and Chevy 2500 diesels, see the latest Consumer Reports write-up), the achievable mileage while towing any given load up to the vehicle's limit should be superior for the Tundra relative to its competition.
Towing 2200 lbs with either my 2000 Tundra SR-5 or my 2006 Limited, I tend to forget the trailer is even there.
Franko
In our “Double Nickels” scenario, we towed a Sea Ray 220 Sundeck completely empty, and covered its bow and cockpit to reduce drag. We made sure the boat and trailer were level with the truck, and checked that all the tires were filled to their recommended psi. We also never drove faster than 55 mph on our test route.
In our “Speedy” scenario, we kept the same setup, but drove 65 mph instead of 55. This change in speed will answer whether it’s worth resisting the temptation to travel at the rate you are accustomed to when not towing.
In our “Does It Matter?” scenario, we really messed with our rig. First we dropped the air in the Tundra’s tires to 25 psi, down from their original 35 psi. Then we took off the Sea Ray’s covers, and even latched the door separating the bow area from the cockpit for some extra wind resistance. Finally, we added 500 pounds of weight to the boat, in the form of a dozen 5-gallon buckets filled with water. The 220 Sundeck has a 50-gallon fuel tank, so this weight is the equivalent of driving with a full tank of gas and 200 extra pounds of gear.
The Tundra’s computer confirmed what we experienced on our test route. In our “Does It Matter?” scenario, we achieved only 8.0 mpg, compared to 9.3 and 11.1 mpg for our “Speedy” and “Double Nickels” circuits, respectively. The actual numbers showed the trip computer was being a little generous, however. Our data, based on gallons burned and the miles we traveled, showed only 7.3 mpg for the “Does It Matter?” loop, 8.1 mpg for the “Speedy” scenario (an 0.8 mpg or 11 percent improvement), and 9.9 mpg for the “Drive 55” setup (a 2.6 mpg or 36 percent improvement).
Any info"
Franko
I towed my snow machine the other day and the digital read out was at 16.4 mpg. Not bad for towing a 600 lb. trailer and a 400 plus pound sled in 4x4 through slushy snow. Also of note I plow my driveway and my neighbors down the road with my new Tundra. Believe it or not the fuel economy did not suffer much. Even with the truck in 4WD the whole time and the steel blade Fisher attached to the front.
Worst I have seen was 13.2 mpg, but that was enjoying the 381 HP. Hope get´s better when further broken in, currently at 2500 miles.
Worst mileage: 15.3
Best mileage: 21.2
Average (over the past 13k miles). 19.2
I have a K&N Air Filter in it and change the oil every 3k with Castrol 5w30. Usually use Texaco or Chevron fuel if it is available.
3000 miles
Just completed 360 mile trip all highway with a few on & offs Avg speed 70 mph.
19.4 MPG
Cold Air Intakes, RAM Air Hoods and CAT Back Dual Exhausts.
Do your research and you won't sacrifice your quiet ride but, you'll have a very noticeable HP increase and higher mpg only if you can keep your foot from the thrill of stomping on the gas.
The 2000 consistently gets 16.6 on E90 and 18.0 on 100% regular gasoline. I do a reasonable amount of off-roading in the CA Sierras with it (my GO-TO truck). A 6,000 mile trip in 2006 yielded 17.7 mpg overall while working a ranch for two months of hauling and towing, and I cruised cross-country at 95 mph for over two hours (w/no trailer) during the trip.
The 2006 has averaged 18.3 mpg overall since purchase on regular E90 gasoline, but is getting better mileage as it ages. I use full synthetic oil in both trucks.
I'm happy.
I broke her in with my first 800 mile road trip with 500 miles on the clock back in march. Got 18.7 all highway, going no faster than 65-70 mph, with no heavy throttle application. Incredible when I consider my 04 Dakota Quad Cab with 4x4 and 4.7 almost never beat that number and the truck was 1000 pounds lighter, 3.55 rear end as opposed to the Tundra with over 100 fewer horsepower.
Of course I haven't driven it like that or seen that mileage since. The other day some idiot stopped in front of me on the merging lane with 65 mph traffic flying by. I just floored it when I saw a small gap and the next car flying towards the on ramp never even got close to my rear end. Can't drive a truck that's capable of that for ultimate mileage, no matter how hard I try.
The sweet spot for fuel economy seems to be not going over 70 pmh on the interstate and keeping the truck at an avg. speed of 40-50 mph on numbered routes that allow such speeds. If I get stuck in traffic all bets are off and fuel economy suffers as you would expect. I also tow with my Tundra quite often getting up to the 10,300 lb. max. rating. My fuel economy when towing around 10k lbs. avg.s 13.1 to 14.4 mpg. Which I think is reasonable given the amount of weight being towed.
