Pontiac Grand Am Clunks and Noises
My 1999 Grand Am front end roars when driving down the road regardless of what speed. Does anyone else have this problem and what can I do to fix it?
now here is what i dont understand. the car does not start ticking right away, it warms up first then it slowly fades in until its very loud. i know it is coming from the rear of the motor. so i removed the rear valve cover. i checked all the roller rockers to be sure that they were all tight. i did notice that there is a little play from side to side on a few of the rocker arms. from front to back there is zero play. push rods also feel tight. so could this tick be caused by the slight side to side play in the rocker arms or is that unlikely?
other than this noise the motor runs perfectly fine. but this ticking seems to get overwhelmingly louder and louder as the car gets hot.
the check engine light is on and diagnostic says it is the camshaft position sensor. (i suspect its a faulty sensor tho since the engine runs fine)
anyways please reply back with some ideas. Thanks
ohhh, the engine is a v6 3.4L Its actually a 3400 SFI. it comes in a few different GM cars
Ironically the problem seems to have started when I had the front driver side wheel sensor replaced. I am now being told it might be the carriage bearings. Has anyone mentioned that before?
did re placing the carriage bolt work?
If it's engine when does it occur?
I just hate my car, I wish it would blow up.
