Replacing Struts on a Special with PHG
                                  in Chrysler
                    Has anyone changed there struts with an after market type? I have a 2000 300M Special with PHG and I have searched and searched and the only replacements I can find are from a Chrysler dealer.
The Special came with 18" Z-rated tires at introduction in '02. In '03 and '04 you could get the smaller 17" V-rated tires. Besides those items, the Special has larger antiroll bars, lower suspension, ground effects all around (front and rear fascia have the ground effects molded in), signal mirrors, projector beam xenon headlights, stainless steel braided brake lines (don't know if other Ms have that as well, though), stiffer brake calipers, quicker steering ratio, recalibrated Autostick shifting, 6850RPM redline, 150MPH speedo, faux carbon fiber interior trim, and different stitching on the seats, just to name a little bit. There is a lot of other stuff that came standard on the Special that was optional on other Ms.
Now if you have all of that, you have an M that someone cloned into a Special. There were NO Specials prior to '02.
As one of the previous posts mentioned, the best source for help on these cars is http://300mclub.org
and by a sister car site
http://www.dodgeintrepid.net
There are lots of How-to instructions and maintenance tips. The 300M club does have a small charge for access to certain areas, but you usually save at least that much on the first maintenance procedure you do yourself.
http://answers.edmunds.com
Once you've posted your question, you can check for feedback by returning to that link and clicking "my answers profile."
MODERATOR /ADMINISTRATOR
Review your vehicle
