Scion tC Brakes and Rotors Problems
                    I have a 2006 TC. I have seen a post with a similar situation when the brakes get hot, they squeal when putting them on with 2 out of 5 brake pressure(5 being the full pressure). It goes away if I brake it fully.
Any follow-up and advices? I have been to the dealership couple of times with the problem, and they said it is normal and fine. Pretty upset and getting annoyed with the noise during the summer. Thanks in advance.
Nevin
Nevin
wom-wom-wom-wom + grindygrindygrind
I'm going in Monday, but if anyone reads this & has any ideas, please let me know.
The Tech :mad:
Then I replaced her brake pads all four tires... she had nearly 60k miles. It did nothing to eliminate the noise either.
I looked under the car the chassy is in good shape dry and clean.
You only hear it when you are going down the road. windows closed especially.
I read here that others have had the rotors checked and it did not eliminate the problem either.
Im being told to go to my dealer for them to inspect. Im thinking now they have no clue.
The only real problem I would worry about is if something is dangerously wrong.
Not sure we arent talking about that. With this being a Toyota Brand I would start with letters of complaint or concern to Scion directly.
Lets see if we can get enough interst on their part to look into this issue.
Let me know if anyone has heard anything since these last responses. Thank you.
I suspect a bigger problem that Toyota does not want to address at this time but I am not letting up on this. I have reached the end of my patience with this problem and will not stop until THEY fully solve it. I bought almost every car I have owned brand new and GM lost my business due to many problems I had with their products and I will happily add Scion/Toyota to that list. Its time Scion step up and get this problem fixed as I found out I am not the only one. I am a very loyal customer ONLY when I have good experiences, soon I will be purchasing my wife her 4th brand new Honda CRV since the first 3 have been absolutely flawless/problem free. I owned a 2007 TC that was fine until a semi decided to take me out and totaled the car so like a good loyal customer I went back and bought the 2008, at this point I will never buy another Scion/Toyota product. How they handle my situation at this point will be the deciding factor if I ever buy another, its up to them at this point.
I will post back here and let everyone know what the case rep tells me (within 24 hours) but I feel I will get the usual "take it to the dealer and let them look at it" response. I will keep everyone posted. If your having the same problems, make that phone call.
-Paul
paul@americanpopdigital.com
I work with Scion, see full disclosure here - http://cmp.ly/4/qrbca1
I am 100% happy with how Toyota handled the situation but the dealer not so much. If anyone here is having the same problem go right over the dealers head and call Toyota directly and have them open a case for you, one call from corporate to the dealer will get them to "figure" it out. Toyota has kept a returning customer by stepping up to the plate, the dealer most likely not.
My first thought was the master cylinder was bad so I just bought one and replaced it however now the brakes are even deeper.
I unplugged the antilock brakes which helps a little bit but now the speedometer doesnt work and check engine light is on.
any help or imput would be greatly appreciated...I'm trying to avoid going to the dealership as much as possible.
