Visitor Agreement.
With no Fit/Jazz at your Honda dealer though, you're forced to leave Honda if you want a small wagon.
-juice
The 5 speed is actually geared lower (numerically higher) than the automatic. So a 5 speed will rev higher than the auto. The 97-01 models were geared even lower than the 2002+ vehicles.
I know everyone says car is most efficient at lower speeds ( less wind drag ) , but.......
I bet you'll get far better mileage at 55mph vs. 70mph in the same gear.
-juice
What really amazes me is the minute difference in miles per rev from 40 to 80, only about 5% difference throughout the range. So as long as you cruise constant speed without stop and go, you get about same mileage.
Knowing that you folks responded promptly and accurately leads me now to the nearest Honda dealership to work out a deal on a CRV EX automatic.
I can still remember the '99 CRV engine(it was an automatic) sounding like it was about to throw a rod right out the side of the engine. But then again, I never heard of that happening on a Honda, they're engines are so durable.
Again, thank you everyone for your responses.
It is true that the rev/speed ratio in your data set is smallest when the speed is 70. However, I suggest that you make a graph of rev/speed vs. speed. You will see a VERY jagged graph! I doubt you can conclude anything useful from that.
A more meaningful graph, IMO, would be to plot revs against the square of the speed since the work done by the engine is proportional the rpm's while the kinetic energy of the vehicle varies as the square of the speed. This graph is monotonic and more or less linear. (Actually, we're talking power but energy is a convenient quantity.)
I'm guessing the transmission is in second at 40, 3rd at 55 and shifts into 4th overdrive at or below 70 mph. Wind drag for each gear is lowest at the lowest speed for that gear, highier as speed increase in that gear, explains the jagged graph. Thus we get best fuel economy as transmission first shifts into overdrive.
Is it really worth it?
JM2C
Still glad I got the CRV instead of Escape because the fit and finish is way above Ford.The Ford would be more fun because of power though.
I currently own an '86 Nissan Stanza Wagon (one of the orginal mini-SUVs) and its rear door swings up. I guess I've gotton used to it after 16 years.
Thanks again for your comments.
As long as we're weighing in with opinions on the subject, I actually prefer the right-side hinge. It may block the curb at loading, but it's more convenient for the driver. The handle is on the driver's side and it swings away from him/her. If it were hinged on the other side, you'd have to walk around the back of the vehicle and step aside each time you open it.
imyodaddy - No one has shown any kind of proof (statistical or annecdotal) that the UK built CR-V is inferior to those built in Japan. In fact, one could make a case for the UK CR-Vs being better as all the initial production problems were found with the units built in Sayama.
I changed the oil in my mother's 02 Civic EX Friday and the owners manual says to use 5W-20 ONLY. It says you can subsitute 5W-30 but, to change it to 5W-20 at the next oil change.
I then read the manual in our V and it says the same thing.
I have always used Castrol or Mobil synthetic oil at what ever viscosity the engine called for. Neither of these manufacturers makes a synthetic 5W-20.
Wha't this all about? Seriously, how much difference can this make?
I changed the original 5w-20 at 4550 miles and replaced it with Amsoil 5w-20 full synthetic. Amsoil offers numerous viscosities but I opted to stay with what Honda recommends. What ended up being and unexpected benefit was, immediately following the oil change, my city/highway mileage has consistently increased 1.8 to 2.2 MPG.
Reed
02 CR-V EX Auto
As I understand it, many Ford engines require 5W-20. I ended up buying a 5W-20 synthetic blend. But, was irked by the lack of a full synthetic at any of my local automotive stores.
Ford sells a ton of cars, and if they have engines that require 5W-20 (and have for a couple of years) why isn't there any readily available 5W-20 full synthetic on the market? I found a ton of non synth oil. And why can't you subsitute the 30 for the 20?
By the way, you can't just look at engine rpms and calculate gas mileage. You're overlooking the throttle position, which is very important.
Say you approach a hill in your 5 speed. You floor it to maintain your current speed, and the whole time speed and engine rpms are constant. But you're using a LOT more gas to climb that hill.
Same goes for carrying extra weight (full payload vs. just the driver), or overcoming cross winds, coarse pavement, a flat tire, etc.
If you're cruising at 55mph, it's easy to maintain that speed even with very little throttle. If instead you drive 70mph, you'll need a lot more throttle to keep up on hills, plus maybe a little extra throttle to overcome the extra drag. So I doubt mileage would match the same trip at 55mph.
-juice
http://www.mobil1.com/index.jsp
I like to use Mobil1 and many of their statments completely refute what most people will tell you.
Check out the FAQ sections under many of the headings at the top of the page.
And then there is the Amsoil site
http://www.performanceoiltechnology.com/ford5w20.htm
Hmmmmmmmm.......
I cannot speak for Ford, but Honda's car and truck fleet is not even close to the minimum requirements for CAFE standards. The CAFE standards are based on average fuel economy. The rundown for Honda trucks would be something like this:
CR-V (auto) 24 mpg
CR-V (manual) 23 mpg
Ody 22.5 mpg
Pilot 19 mpg
But CAFE standards also take into account sales volume. This prevents manufacturers from offering one completely undesirable model with good fuel economy, while the rest are guzzlers. CAFE regs will slap a guzzler tax on a manufacturer that fails to meet the 20.7 minimum. If they sell too many of the gas guzzlers, they get fined.
But Honda sells way more CR-Vs and Odys than Pilots. They probably clear the 20.7 line by more than 2 mpg. The idea that they need to scrape for every 10th of a mpg seems ludicrous when compared to the fleet averages for DCX, GM, and others who sell even more big trucks without using 5W-20 oil.
In fact, domestic manufacturers favored forcing a percentage increase in fuel efficiency for that exact reason - Honda would have more work to do. Of course that discriminates against those who are doing well now, so I doubt it would ever become law.
-juice
Frankly, I dunno why Toyota didn't do it. They've been making huge improvements in their SUV fleet. The new RX330 has better fuel economy than some of the mini-utes. The RAV4 and their minivan are no slouches, either.
Toyota is a true full-line manufacturer, Honda really isn't. They lack a big and a small pickup, and full-size SUVs.
Even with cars, Toyota has the Avalon while Honda stops at Camry-size.
Any how, Honda should be proud of their CAFE numbers, and that's why they're in front of Congress. I bet Suzuki easily surpasses CAFE standards, too, but they also don't sell large vehicles.
-juice
Look at it this way, the CR-V helps Honda sell more Pilots. The Forester hurts Subaru and forces them to sell more Imprezas and/or use up past credits. Yet they compete directly and get about the same mpg!
They've been borderline but have just made the cut, even with AWD. Their powertrains are efficient for their given displacement.
But even Subaru caved in and calls the new Baja a truck. It just wasn't feasible to meet the 27.5 and still make a profit while every competitor uses the truck loophole.
In fact I bet the next generation Forester is certified as a truck for that reason.
CAFE is done all wrong, anyway. The truck loophole was intended for work vehicles. All passenger vehicles should meet the same standard, but of course the lobbyists will never let that happen.
-juice
I'm not sure trucks require bumpers at all, you could get a Toyota pickup without any rear bumpers, at least a few years ago. I'm still not sure you can call the RAV4's bumperettes real bumpers.
FWIW, Honda may certify them as trucks, but at least they make sure they meet car standards. So they're using the loophole without cutting corners in safety terms.
-juice
I look at it this way... Chevy and Ford sell more big trucks than anybody. They also have the fewest (percentage-wise) car-based vehicles to compensate for those big truck sales. If they can meet CAFE standards, Toyota should be clearing them fairly easily.
JM2C
As for Subaru, I expect Juice is correct. They have to meet the higher car standards and, while their engines are efficient, the AWD systems lower their mpg ratings. That means they don't raise the average as high as the fuel sippers of many other fleets. For example:
Accord 28.5
Camry 27.5
Legacy 25
Reclassifying the Forester as a truck would go a long way toward giving them some breathing room. A) It's rated low against the 27 mpg car standard.
I think Dodge was struggling a bit, but that's no big surprise given even the mid-size Durango gets low teens mileage. The PT Cruiser helps them because you can remove the rear seats, so the feds call it a minivan (another ridiculous loop hole).
Subaru needs to bring its AVCS technology from Japan. It's closer to BMW's VANOS than it is to Honda's VTEC, but it helps with emissions and fuel efficiency, so that'll be what keeps them over the CAFE minimums. They'll soon be selling more turbo and H6 engines, so eeking even the tiniest bit of extra efficiencies will become essential. For 2001 they were exactly at the 27.5 minimum, but they probably have some credits to use up.
-juice
I'm sure Honda would want to group Acura/Honda together, so that the CR-V and Element allow more MDX sales.
I really miss the Automotive News subscription I used to get at my old job - it had great information like that. They'd publish CAFE results for all the manufacturers. I also wish I had a photographic memory!
-juice
http://www.autonews.com/
The Edmunds Maintenance Guide
door area, you name it. if i hit the right bounces it drives me crazy. anyone else have these problems, if so how do i correct them.
I have a 2002 CR-V EX Auto with 8100 miles. 4000 of those miles was a recent trip which included several trips off road and some snow. I have yet to experience any of the creeks and rattles you have but I might suggest that you allow someone else drive your V while you ride along and closely investigate the location and source of the noises.
Good Luck......Reed
I payed $130, by the way. Feels high, to me.
