Midsize Sedans 2.0
1339340342344345545
  • crkyolfrtcrkyolfrt Member Posts: 2,345
    edited January 2013
    Long post..touches on CVT vs conventional auto..maybe not to all's taste?
    Well, they did risk continuing to use a troublesome auto in their Odyssey.
    Who knows though, maybe their idea of a CVT is an improvement over their usual auto attempts...probably is. The Civic also had issues with its auto. Did the Pilot and Ridgeline have the same issues the Odyssey had?
    But when Honda gets something right, it often is something that competitors will try to emulate. (variable valve timing and then later variable intake track lengths as a good example)
    I think coast-ability, at the right times, is probably still one of the most difficult instructions to make a CVT work with.
    But if these transmissions are so hardy and capable, why did Audi have a relatively restrictive horsepower cap on their first versions? Shortly after, Nissan did too if I recall.
    I maintain these transmissions probably do work in a superior way in order to satisfy EPA ratings (and don't ever under-estimate the importance of the almighty EPA numbers and crash stats) but in the hands of a generally aggressive driver, or even most owner's real world, can't do nearly as well as a conventional auto. That's why the impressive numbers tend to fall off quite dramatically unless really babied.
    The one thing that I think a CVT can excel at, providing the mfgrs get 'em dialed in right, is allowing near optimum engine rpm's at practically any speed you want to go. The final drives are geared so tall on all cars now that we see sub 2000 revs even when we talk about 75+ mph. And on the other end of the scale, if you have a conv auto in manual mode and let it lug right down (as a couple random examples..a Cruze 1.4 l turbo 6 sp auto or Jetta 2.5 6 sp Tiptronic) in 6th gear at less than 25 mph, on level ground with one or two people the tranny actually will let you cruise along at revs just barely off idle...like quite literally 1100 rpm. And the instant fuel use gauge gives numbers right off the chart. All until you either accelerate a bit or find a grade or headwind. This is something that can be accomplished with predictability in the right hands with the 6 sp conventional auto...but can be done with not nearly as much deliberate driver involvement...(read, the masses) with a properly dialed in CVT. All that is required though is a non aggressive light foot. But don't confuse non-aggressive with indecisiveness which can be a real fuel user in a CVT. And this gets back to why when being driven so gently and at times you want it to coast, it makes it that much harder to program all that into a CVT because the variables are...just that...constantly varying..
    And this is why many 6 sp sticks will EPA at fewer mpg than the autos, but is because of generally lower chosen final drive gearing. You give the stick guys that SAME final drive as the tall autos have and then you would see even better hwy figures. And one of the reasons is there is less reciprocating mass with most standards than what I imagine a CVT has, and certainly has way less parasitic losses than the conventional auto.
    I have been down at the road the past couple weeks cutting a huge red oak for firewood. Been there a lot and see (and hear) the actual cars that go by my rural road. I am just constantly amazed at the number of drivers who couldn't hold a steady throttle if their life depended on it! You know the ones....they are either accelerating or decelerating, with no in-between...just constantly dialing in throttle, then letting off, then dialing CONSTANTLY! You hear them go up the road all the way doing that until they disappear. Is that the way they were taught? Does it not occur to them that it is ok to just hold the throttle steady? It makes me embarrassed on behalf of my local community drivers. Anyway...these are the idiots that should use CC mandatory whenever the roads are dry and definitely should steer clear of all CVT's..
    I guess you missed this part of my post:
    ...and 38 mpg with a 189 hp engine on the Mazda6 (vs. 38 mpg with 182 hp on the Altima).
  • pegasus17pegasus17 Member Posts: 536
    edited January 2013
    It will be interesting to see if the Mazda 6 lives up to its EPA highway number of 38 mpg in real world driving. Too early to tell.
    If you peruse the Altima forum, many are complaining that their real world mpg is nowhere near what they expected. Plus there is a recall (or TSB) on some Altima CVTs in the 2013. That is surprising since Nissan has been using CVT's for quite some time.
    extract (not me):
    "Just finished my 3rd month driving 2013 Nissan Altima 2013 2.5SL and my car has been consistently delivering 18 MPG or Below. Monitored MPG manually several times. Bringing back to the dealer for the 2nd time. Also recieved a safety recall from Nissan (campaign# PC186). CVT belt slips during driving. There is already another safety recall (campaign# PC182) that has to do with power steering rack bolts and tranverse link bolts issue.
    Problem after problem with this 2013 Altima and the year 2013 has not even started yet."
  • m6userm6user Member Posts: 3,181
    Mazda has had a good track record with attaining their stated EPA numbers in real world driving. Both before skyactiv and with the two skyactiv models the 3 and the CX-5. In fact, from what I read about the CX-5 is that most testers and owners are getting at least the EPA numbers if not better. No real reason to automatically doubt the new Mazda6 just because Hyundai was caught cheating(oops I mean making several mistakes over a long period of time on several different models). Obviously, someone getting 18mpg in a car rated at 27/38 is having a major problem of some kind. I've read lots of good reports on the Altima as well so that one needs to be sorted out some before condemanation is in order.
    Odd on the Altima numbers... CR got some great FE numbers on the Altima 2.5, especially on the highway where they got well over 40 mpg in their tests. Someone who's only getting 18 mpg must be doing a lot of in-town, short-distance driving.
    I know it's not a true mid-sized sedan (for those people tracking such things here), but my Sentra--which has a mid-sized interior at least--with the CVT has done very well in real-world driving over 3 years, exceeding its EPA numbers. But that's MY real-world driving, and I drive with a light foot and have learned to milk that CVT for all it's got. Not everyone will be able to drive that way, or want to.
    for Backy:
    What an intelligent statement you've made in the past:
    "What a huge difference speed makes for fuel economy! Something for folks to consider when they don't see their Optimas or (Sonatas) hitting the EPA fuel economy numbers on the highway, but tend to drive at 70+ mph."
    Something to check on your wife's Sonata:
    FWIW, in my 2011 Sonata, the speedo reads 2 mph high. example: I have to drive an indicated 62mph to attain 60mph. At lower speeds, it still reads high. Confirmed with GPS, local radar, a pace car, and a few middle fingers for driving too slow. ;)
    Yeah, if I ever get the thing on a highway for more than a couple of miles, I'll check it.
    Of course speed affects fuel economy. Everyone knows that (or should know it). But I still think a car rated 35 mpg highway should be able to get better than 31 mpg cruising at 70... recall I said CRUISING. If you're kinda/sorta going 70 but passing vehicles, accelerating/decelerating/braking, some non-freeway mixed in... all bets are off!
  • tundradweller1tundradweller1 Member Posts: 74
    Have been shopping and test driving a few mid-sizer's:
    The 2014 Mazda 6 sport was a hoot to drive, the four almost has the torque of a V-6. Rather noisy on the highway (it was windy) and the sight lines are not great, small mirrors too.Still felt more like a sports car than a sedan, though you do feel every road irregularity.
    The 2013 Accord LX 4 cyl. - still looks like a grocery getter compared to most others.
    decent motor, handling was surprisingly sporty, CVT a little weird though much better than the Nissan Altima which I will avoid due to CVT issues and power steering whine with no dealer fixes.
    Ford Fusion, after all the issues with the first gen fusion transmissions and no fixes I'll pass. Recent recalls cropping up too.
    The wife has a 2011 Sonata 2.0 T - back to the dealership numerous times for front end pull (common) they FINALLY replaced both struts. Paint chipping off, partial re-painting etc. etc. Avoiding KIA/ Hyundai for now.
    Chevy, not even a consideration.
    The Passat, dated, under powered and worst MPG. High long term costs.
    The trend for car makers is to cram all the gee wiz gadgets into the vehicle. Trouble is what good is it if the drive train and peripherals are junk? I don't get it. Maybe I'm not a marketing guy, I just want them to work...for 200,000 miles.
  • aviboy97aviboy97 Member Posts: 3,159
    Sounds like the Toyota Camry is right up your alley.
  • benjaminhbenjaminh Member Posts: 6,744
    Thanks to TSX at www.vtec.net for these numbers:
    Camry 31,897 +8.2%
    Accord 23,924 +68.1%; PHEV 2
    Fusion 22,399 +64.5%
    Altima 21,464 -4%
    Malibu 15,823 +7.8%
    Sonata 13,247
    Optima 11,252
    Avenger 9,628 +69%
    Passat 8,856 +40.2%
    200 8,846 +26%
    The Camry continue to dominate, which is a slight surprise given that Camry was just rated Poor in the IIHS crash test:
    http://www.youtube.com/watch?v=ByPAhoeU6UQ
    But, the Camry offers a lot of bang for the buck, low financing, and the Toyota name. Also it seems like the other auto makers have been too nice to make an ad out of that video.
  • romil01romil01 Member Posts: 75
    The average consumer is incredibly ignorant and probably has no clue that the Camry performed poorly in this test. I think most Camry purchasers must blindly buy that car without any comparison testing. I don't think too many people in their right mind would actually choose a Camry over some of the newer offerings from competitors.
    Huge surge by Fusion in January. Honda may have to start protecting Accord's number 2 spot soon. So far Honda hasn't offered any financing on the 2013 Accord, but maybe that will change soon. The Altima is selling well, but seems to be faltering a little given that it's an all-new design. Passat is selling well too, but I think the VW factory in TN can make c. 12,000 Passats a month, and so they aren't selling them quite as fast as they're making them.
    edited February 2013
    tundradweller:
    Thanks for your observations. Can you clarify a little what you mean about that the "sight lines are not great" on the Mazda6? I thought visibility would be pretty good in that car.
    Several midsize cars have poor rear visibility, including, I think, Fusion, Optima, Sonata, Passat, Malibu, and Altima.
    The best visibility is found in the Accord, and that's one of the hallmarks of Honda's designs: Form follows function. Some people say it's not exciting enough, but it works better than some competing designs for providing rear headroom and good visibility. You also can roll down your rear windows on an Accord almost all the way. Try that on the others. Can't do that on any of these others, I don't think, except the Camry and Mazda6.
    My guess is that all of these cars will have very long lasting engines and transmissions. Probably all of them are designed to make it to 200k as long as all maintenance is done as scheduled and they are not used roughly. Will they all make it to 200k? Hard to say. Hyundai, Kia, and Honda now have direct injected engines, and I don't think many have yet gone more than 100k to test whether long term they have issues. In durability tests Ford's turbo DI engines seem to do very well. Ford engineers have strengthened several parts to make these engines pretty tough, and I'm sure all the others have too. Honda's CVT is new, but they've been building these for a while, and have apparently done a lot of engineering to design in long term durability. But with any new design there can be question marks. Anyway, I think we are all probably fairly safe for durability of engines and transmissions with all of these.
    I'm sure you've thought of this already, but if you want fewer gadgets buy a base model—you'll save money now, and potentially trouble in the years ahead.
    Even the base models of all of these cars are pretty lavishly equipped compared to midsize cars of 10 years ago.
    Hope you'll let us know what you pick!
    Granted the Mazda 6 has a smaller blind spot then the Sonata and yes the Accord so far has the best visibility. Chalk it up to the higher waist line, swooping roof designs of late.
    Considering I'm driving a 2004 Taurus SE that's approaching 200,000 miles, maybe color my opinions old school :shades:
    The Gadgets I don't mind and in fact embrace them (I'm rather digital for my age) I really like the touch screen on the 6. My comment was geared more toward manufacturers than my preferences. The safety features on the horizon look promising, some may even save the increasingly distracted from impending doom.
    I didn't mention Toyota because I just am not interested in the most recalled brand in spite of their huge sales numbers. I agree that some people just buy them because they are so popular. Ironic as they rarely make the top 10 in various car magazine reviews.
    These are heady times for car buyers. More competition, more options for the same money, better performance while returning improved mileage and safer vehicles. This is going to be fun!
  • Thanks Ben. The mid size sedan racket has got to keep corporate sales managers up at night. Particularly the VW man.
    I think the Passat looks fine; but you really have to lux-it-up to match the levels of equipment in some competitors. Why would I buy a 5 cyl engine with 30 horsepower and 15 torque's less than a four? MPG of 22/32 is ok, but that 5th cylinder is costing you at least 4 mpg hwy and 2-4 city based on competition. Also, it costs 26,800 for the Automatic. vs 20-24 for competitors. a 5 speed manual is std on the SE. (where is the other gear?? all competitors who offer a manual trans have 6 speeds).
    Again though, it depends on priorities I guess. It has a huge back seat and trunk. Fit and finish are excellent.
    You guys should know that I owned a 96 TDI so be nice! :D
  • I just saw a review of the 2014 Mazda 6. I really like the 2.2 liter TD with 310 torques!!! 310!!! From a 2.2!!
    Now that's more like it Mazda. Also, the new interior is awesome looking. The flat screen is integrated nicely and Automobile magazine raved about the seats. They look comfy in the pictures. YES I AM SAYING NICE THINGS ABOUT THE 6 BACKY!!! :P
    Lastly, I can't get with the silly grin front end. Beauty is in the eye of the beholder I guess.
  • "Several midsize cars have poor rear visibility, including, I think, Fusion, Optima, Sonata, Passat, Malibu, and Altima"
    So pretty much all mid-size sedans have poor rear visibility! :D
    Doesn't have the "silly grin" anymore. It was the Mazda3 that got all the hate for the grin as the 2 gen 6 didn't really have it as much. The new 2014 doesn't have the grin at all. Below is a quote from Augo Guide review which most other reviewers have agreed with.
    NEW BODY STYLE SWAPS SMILE FOR SERIOUS FACE
    It wears the second production application of Mazda’s new KODO design language, losing the smiling front end and exclamatory headlights for a more pronounced grille and sharper body style.
    Test
    cski wrote:
    "...I think the Passat looks fine; but you really have to lux-it-up to match the levels of equipment in some competitors. Why would I buy a 5 cyl engine with 30 horsepower and 15 torque's less than a four? MPG of 22/32 is ok, but that 5th cylinder is costing you at least 4 mpg hwy and 2-4 city based on competition. Also, it costs 26,800 for the Automatic. vs 20-24 for competitors. a 5 speed manual is std on the SE. (where is the other gear?? all competitors who offer a manual trans have 6 speeds)..."
    Agree with all of this. The Passat is a nice looking car. And I think VW has significantly improved quality and reliability. But to cut costs they cut some things that are now making them less competitive. I read somewhere that for the 2014 model year the Passat is going to have a more advanced engine, and maybe they'll get a 6 speed manual with that.
    For now, however, VW is blowing them out the door with 0% financing for 66 (!) months. Good deal on a good car!
    http://www.vw.com/en/models/passat/gallery.html
    KIA has some great deals on the Optima too.... 0.9% for 36 months, or $199 lease, or $2000 bonus rebate if you own a competing car!
    http://www.kia.com/#/optima/offers
    Not to correct you but the new Mazda 6 has a 2.5 liter. If you can find a dealership with one test, drive it. The gal that went with me encouraged me to stuff it into corners and rocket out of them. I was pleasently surprised. Being a Motorcycle nut I am ready for a fun car to drive. Now just waiting for some current magazine road tests. If the new 6 truly returns near 38 mpg it's a lock.
    Also regarding the 2.5 - 5 cyl. Passat, they have been making that motor since 2005. No wonder it does not measure up in performance and economy.
    Yes, it is not the as fuel efficient as some of its so-called 4 cyl competitors, but they do not have the smoothness (perhaps Honda's effort is close) and I doubt any of those higher hp/torque 4 cyl efforts from....Korea..as an example, feel as strong off the line. And I absolutely assure you NONE of the 4 cyl ones have as rewarding an exhaust note. And let's get some miles on those DI 4's before we further condemn that 5 cyl and its longevity/$ investment potential.
    As for FE being your primary beef..ya gotta pay to play/enjoy..
    VW 2.5 - 170HP 177 ft. lb. torque - 0 to 60 9 seconds - fuel economy 22/31
    Mazda 2.5 - 189 HP 189 ft. lb. torque - 0 to 60 7.6 seconds - fuel economy 26/38
    It may "feel stong" off the line but the numbers tell a different story. Already reading about VW dumping the 5cyl. for 4cyl. for next year.
    Cheers
    Not a bad engine, just outdated and outperformed by newer higher tech engines. Sort of like Windows Vista (i used it for many years without any major problems) compared to Win 7.
    If they were changing the engine this year, the Passat would still be on my shopping list. Can't wait for the 2014 model this fall; my lease is up in 2 months
    VW isn't exactly known for quality and reliability...I personally wouldn't buy one. Not to mention the Passat is a pretty boring looking car, both inside and out, when you stack it up next to most of the competition. Probably the only cars more boring in that class are the Camry, Malibu, and Legacy.
  • mf15mf15 Member Posts: 158
    Accord december sales 29,428,jan sales 23,924 ,while camry sales are up
    accord drops. Must be all about the buck, no honda finance deals,no cash poor lease support. December had for a short time 500 cash if financed.
    Seems that crash test results have little effect on camry sales,if the general public knows about them.
    I suspect honda will have to lay out some form of support soon.'
    Old Mike
  • wayne21wayne21 Member Posts: 259
    Perhaps many people don't worry so much about a new crash test as they do the new technologies in honda. Honda has a long history of transmission problems (well known to most, but denied by isellhondas) and coming out with a new CVT transmission (i.e. a first year effort) for the 4 cylinder probably isn't very soothing to many consumers. And the 6 cyl honda with its VCM leaves a lot to be desired, too. There seem to be no shortage of complaints over the 6 to 3 / 3 to 6 cyl changeover AND it also got a new transmission (a 6 speed). And if you want to have homelink (i.e. if you don't want to have a garage door opener on your sunvisor) you have to buy a 6 cyl accord as it's not an option on the 4 cyl. IF I were looking for a car I would forego the accord this year myself.
  • The Passat, like any car, is perceived differently depending on the observer. To some, the design is stately and classy, looking more expensive than it is. There is almost an Audi look to it. In any event, it doesn't tread into "dowdy," like the old Ford Five Hundred/Mercury Sable that preceded the 2010 makeover of the Taurus.
    VW's quality had been in place for a long time (with some exceptions) and reliablilty has improved. The TDI models have had great reliability at least since the early 2000's. The TDI Passat is a gem: quiet, powerful, economical. It is more expensive, but you will get that back on trade-in, even if you keep it 10 years.
    To my eye, the new Accord, though an excellent all around choice, is a more boring looking car. The only standouts really are the Mazda6, Optima, and Fusion. The Sonata was on introduction, but no one much looks at them for their looks anymore.
    None of the current crop is awful, although the 200 styling certainly borders on it. The Malibu actually has reasonably good styling. The 2014 will address the rear legroom complaint a bit. The Malibu is certainly is more attractive than, say, the Legacy, although that may be damning with faint praise. I note Consumer Reports rates the Malibu just a hair higher than the Fusion, although that could flip flop soon, as Ford sorts out some of the complaints with what is otherwise a nicely styled, great handling car.
    It will be interesting to see if the new 200 coming will be a game changer. It is supposed to take Chrysler styling in a completely different direction.
  • stickguystickguy Member Posts: 54,059
    I still think in this class, most people are more interested (or at least fine) with a simpler design (call it classy, understated, vanilla, or what not). Comfort, room, reliability, economy all are top items.
    sure, a flashy design gets a lot of attention, but it can get old fast, and will turn some people off. Especially if the style cuts into function.
    I personally think the Passat and Optima are 2 of the best looking in the class. And the new Accord also looks sharp now the Fusion is sharp, but I find the Sonota to be too overdone and awkward.
    What I am wondering is, how many of those Camrys sold in January (and other months) were fleet sales? There's tons of Camrys in rental fleets, e.g. Hertz. Accords, almost none. That, plus the fact Camrys are heavily discounted and Accords still going for premium prices for the all-new model likely account for most of the difference in sales.
    One other thing I wonder about... the new Civic is a pretty nice car and plenty roomy for four people. I wonder how many buyers go into the Honda dealership, see the high prices on the Accords, and gravitate to the Civic instead? Not as easy to do for Camry shoppers... the Corolla is a sorry excuse for a small car (yet still manages to sell pretty well). Similar thing could happen to Sonata shoppers (real good prices on Elantras now), Passat shoppers (Jetta is humongous inside for a compact car), and maybe Altima shoppers (new Sentra is quite nice inside and out and more roomy than before).
    ... but I find the Sonota to be too overdone and awkward.
    Well, first of all, there is no mid-sized car called the Sonota. There's a Sonata, and IMO it's still a head-turner, especially in Ruby Red (which my wife has). I give Hyundai points for at least trying to spice up the usually boring mid-sized family car class. The Optima is also quite sharp, in a different way than the Sonata--more European. The Passat? Well, if you liked the old Impala you'll like the looks of the Passat. Although the tail lamps are kind of Audiesque. The Fusion is quite a looker, although I'd trade some of the looks for more back seat room.
  • ivan_99ivan_99 Member Posts: 1,681
    Funny thing...
    I liked the Passat better than the Sonata and my wife hated the Passat. She used to work in law enforcement and said it looked like a police cruiser, inside and out.
    Yeah, maybe because a lot of those police cruisers were Impalas! :)
    People who like simple lines on cars would tend to hate the Sonata, though. The Passat, Camry, or Accord would be much more to their taste.
    I like the Sonata too ;)
    I lean more towards the Optima because of the more angular lines, but the Sonata really is a looker in the category.
  • bb49bb49 Member Posts: 25
    The bland dated and uninspired styling is precisely why Honda has lost my sale. Honda continues to make boring appliances. I just tried the new Fusion, the styling is just so much more attractive that placed side by side the Accord looks dated. I tried the rear windows in te Fusion, and they do roll all the way down.
    I like the style of the Accord better than the Fusion.
    But obviously everybody gets to pick their own favorite.
    Congrats on the car!
  • The following is for potential buyers who may be viewing this site:
    I also loved the Sonata when it came out. A neighbor came home with a 2011 black SE 2.4 with dual exhaust and fogs. We talked for 1/2 about it. 3 months later I bought the 2012 Optima version. ($24,260 EX base in Spicy red).
    I found that the Optima was more to my liking as well. It looks a lot like the Lexus GS 250/350; a great looking entry level luxury sedan.
    14 months later, I still love it. Not one thing has broken after hundreds of commutes into DC. I would recommend it to anyone.
    However, there are a ton of fresh faces to choose from in this segment. The Fusion, Altima, Mazda6, Accord and Passat should be seriously considered and test driven before making a decision on ownership.
    Happy hunting!
  • yoonnyyoonny Member Posts: 33
    We were perfectly happy with Sonata but I like to try different cars for a lease so I leased the Accord EX-L 4 cyl in December. After driving it for over a month, there are lots of little things that makes this car not as comfortable as the Sonata. Here are the things that you might not notice at first but becomes annoyances once you own it for a while:
    Accord annoyances:
    Storage space (door, center console, armrest) are all pitifully small. Sonata wins it big time here with its big storage spaces and little nooks everywhere.
    Short front seat bottom makes it less comfortable.
    Automatic headlights go on and off on a bright day when the car gets into slightly darker spots.
    Trunk is narrow and the wheel well takes away more space.
    No HomeLink for garage door - Are you kidding me for an EX?
    No light in the glove compartment. Come on Honda!
    Poor cupholder location - Sonata's forward location next to the shifter is more preferred.
    No place to put coins.
    Door armrest is useless as it is so low.
    Hanging accelerator pedal - Sonata's is attached to the floor which make it way more comfortable (per my wife).
    Keyless entry - No way to open all doors without using the remote from the driver's side.
    Rear seat leg space - The floor bump is much higher than the Sonata's.
    Accord positives:
    Memory seats - Sonata lacks this.
    Back up camera
    Nice steering wheel with nice controls.
    Clear instrument panel.
    Tie:
    Design
    Leather quality
    Interior space
    Driving dynamics (yes Accord seems better here but if you drive the way most family sedan owners drive, there is no real difference).
    Bluetooth/USB - Bluetooth in these cars are still not optimal.
    CVT vs. normal transmission - There really isn't much of a difference.
    Overall, the Sonata is much better "family" sedan. It is not all about how well the car drives, it is more about how comfortable the car is for a family. And to pay slightly more for Accord for what I think is getting less of a car adds to my vote for Sonata. We will just have to wait for this lease is up. Oh well.
    REF: 17464
    Thanks for the detailed post. My Sonata lease is up shortly and the Accord is #1 on my list. I will review your nits to make sure I don't have buyers remorse. As a second choice, i am looking at the optima with the convenience PLUS pkg (backup camera, high-tech mirror with Homelink). Optima has a $1500 price advantage for me due to incentives and that is why it's still a player. Need to do another test drive and look at some details i may have overlooked on short test drive.
    What have you found wrt fuel economy?
    A big reason I went with the 2013 Sonata GLS vs. an Accord late last year was cost. Hyundai had aggressive lease prices for a loaded GLS (every option including homelink mirror) and gave me a very generous trade in for my 2007 Sonata (beat up, but they have their own body shop so I bet they made out OK on that). All in all I saved $3,000 over 3 years on the lease with the Sonata vs. an Accord LX--assuming the Honda dealer would give me at least as good a deal on my trade as Hyundai.
    For what my wife uses the car for, she would notice no significant difference drive-wise but does appreciate the extra features on the Sonata such as the heated seats and trick mirror. And I think the Sonata is a better looking car inside and out than the Accord, esp. the LX.
    If the cars were priced similarly, I would have given the Accord a very close look. But at the pricing available back then, it was no contest.
  • fury63fury63 Member Posts: 31
    So I have around 7K miles on my '13 Fusion Titanium. And while I am very happy with it overall, the one disappointment has been the fuel tank capacity. The specs state a 16.5 gallon tank but I'll be damned if I can get more than 12 gallons in when the fuel warning light comes on (maybe 30 miles to empty?). Ford dealer initially said it's reserve. I've never seen 25% reserve (4+ gallons). I pushed back and they are in discussions with Ford about this but as of yet no conclusion. My last car had an 18 gallon tank so for long trips this becomes a pain having to stop more frequently - especially in the winter where I don't like to push it.
    Any other '13 Fusion owners out there experience this?
    I'm wondering if they installed the Hybrid tank - which I believe is 13-14 gallons - by mistake...
  • scwmcanscwmcan Member Posts: 399
    Actually it is quite common to have that large a reserve when the fuel light comes on, my Matrix has a quarter tank left in it for example. I think this is partly due to the in tank pumps, while it is okay to occasionally drive lower than the fuel light, it could affect reliability of the pump if you drive it at the bottom on the tank all the time, I think the manufactures are co erring their behinds and making it so the light comes on very early so they get your attention.
    Our 05 Nissan Quest is similar. It's about 21 Gallons and I can drive it below the E-mpty...but still it will only take about 16-17 gallons. I once drove so low I thought I'd run out...over a hundred miles more than I should have...and only put 18 gallons in (the most I've ever put in).
    I see it as a suggestion...next few days I need to fill up.
    The reason the fuel light comes on so early isn't so much about YOU as it is about the fuel pump. The electric fuel pump is located in the tank and is cooled/lubricated by the gasoline in the tank. The light comes on more as a protective measure for the fuel pump (to keep it cool/lubricated) than for you. The best thing to do is refuel when the light comes on in order to preserve your fuel pump.
  • akirbyakirby Member Posts: 8,062
    There appears to be a problem with some Fusion fuel tanks. One owner had his replaced which solved the problem. Ford engineer took the old one so I'm sure Ford is trying to figure out what happened. Common theory is a problem with the baffles. I've only had one fillup at 20 miles to empty and it only took 12 gallons so something is definitely wrong.
    Sorry aren't you confirming what the original poster reported? The to empty display on the car tends to be to the fuel light not to the actual tank being empty. Not saying there isn't something wrong, but it does sound to me that Ford is being cautious of the fuel pump due to issues they have had in the past ( and as many other manufactures are doing as well, see the other replies).
    Ford typically leaves 1.5 - 2 gallons in the tank when it says 0 miles to empty. And I think it's doing the same thing here. When mine is on E and I put in 12 gallons it moves off Full within a mile or two. It's not really getting full.
    i would stick with sonata as i feel like i downgraded and paying more money for accord. pretty foolish. optima price is really attractive and if it is similar to sonata, it should be a fine choice also.
    fuel economy is about even. i think you made the right decision. hyundai is getting more expensive but it is still much better value compared to honda/toyota.
