2001 - 2006 Honda CR-Vs
1218219221223224314
  • mikefm58mikefm58 Member Posts: 2,882
    Or the oil filter may have a small hole in it.
    Steve: just find out what's going on before you drive it. Have it flat-bedded to the dealer, or ask them to come out. I'd print a copy of that NHTSA report.
    Make sure they clean the spilled oil completely, too.
    Sabrina: may I suggest you open a file with NHTSA also? The more data they have, the quicker they can come to a conclusion.
    -juice
  • robmarchrobmarch Member Posts: 482
    I think it's a decent idea, especially if you have the foglights. One of mine already has a crack. I put the 3m film on the hood, but haven't gotten around to doing the lights yet, and paid the price with the fog lights :(
    any chance it was just spilled oil from during the change? sometimes as the engine heats up spilled oil can run off the engine (or burn off).
    if you clean up the puddle does it come back?
    is the oil level still at full?
    can you see where the drips are coming from?
    Let it cool and check the areas around the oil filter and the gaskets. Plus the area where the recall was performed. Those would be suspect.
    -juice
  • jmurman42jmurman42 Member Posts: 675
    It takes about 200 miles for the pads to fully find their perfect match on the rotors.
    Also, if the rotors have rust on them it will take some braking for the rust to be polished off.
    I had to read that a few times before I realized that you meant the CR-V may get side air bags and/or curtains for '05.
    I couldn't figure out why Honda would discontinue the CR-V (it's curtains!).
    Aww... you spoiled all my fun... =)
    Maybe no one else was slow on the uptake like me :-)
  • sabrina9sabrina9 Member Posts: 148
    I plan to file an NHTSA complaint ASAP. Now that I have seen how important they are, EVERYONE should do this when there is a signifcant problem (on any car). If Honda had given me a new CRV immediately (like they should have) I would have assumed it was just a fluke. It may still be, but thanks to the NHSTA, I have something to go on.
    LOL......I felt the same way too, but didn't want to seem stupid.....I read the link several times before realizing he meant side curtains...LOL
    Now the question becomes... will they be standard on all trim levels (DX, LX, and EX)?
    Will stability control be included on the CR-V? They mention it for "SUVs" and the Ody, but do not specifically mention the CR-V or Element. Toyota is putting it on their entry vehicles, and Honda tends to follow them. In fact, a form of VSA has been an option on Japanese CR-Vs since the first generation.
    I was thinking the same thing, Steve. ;-)
    It's a great idea that is long overdue. I believe Honda finally put ABS on the Accord LX, their volume model, last year.
    Meanwhile Passat has had traction control and side curtain air bags standard for years, and stability control and AWD as options (even on the 1.8T for 2004).
    So I'd say VW was the pioneer, but Honda will make it mainstream. Toyota has no choice but to follow suit, though they tend to make them a-la-carte options.
    -juice
  • theracoontheracoon Member Posts: 666
    The article Varmint linked to contained two phrases that stuck in my mind...
    ...add numerous safety features as standard equipment...to most of its cars and trucks sold in the U.S. by 2006.
    It says "most". It does not say "all".
    ...light trucks, such as the Odyssey minivan and Pilot and Acura MDX sport utility vehicles, would be outfitted with stability control systems...
    Since they specifically mentioned the vehicles based on the Odyssey platform, I doubt that the CR-V will get the stability control systems.
    JM2C...I could be wrong. :)
  • tambertamber Member Posts: 6
    I have been researching small suv's for what seems like a lifetime. I like the CRV...I am looking at a 2004. After reading so many neg posts here I am not sure. I have a friend who is very anal...and checks specs on everything.. He thinks The CRV is a good buy. But he is a Accord owner..So he is biased. This is my first NEW car! I don't want to make a bad mistake. I have to admit the cheap material seats was my only gripe. Now it seems I have more worries. Can anyone tell me some positive stuff...Or recommend a better buy? Thank you for your help in adavance!
    Tami
  • vman05vman05 Member Posts: 7
    Tami- I think you’ll find that that CR-V is a well-made, very solid vehicle as are most Honda’s.
    But if one would be right for you depends on your expectations and needs. If you don’t expect to be towing heavy trailers or boats, power wise it should be fine.
    I personally think that the interior looks great and is certainly nicer that any other small SUV’s in its class. I was wondering what you were driving before that makes you think the CR-V seats look cheap and poorly made? While they may be no match for anything a luxury vehicle would come with most people don’t find them too bad.
    I found the ride to be smooth and comfortable on most roads although as you may have read the Bridgestone tires that come with the CR-V certainly leave much to be desired.
    They are noisy and most people replace them with something better sooner or later.
    Overall I think you would be happy with one. Good luck.
    Tami - What are you going to use it for?
  • stragerstrager Member Posts: 308
    Tami - since you're in California, you may want to check out the Scion xB at your Toyota dealer, as an alternative to the CR-V. It has a huge interior, has Lexus-like fit and finish, is fun to drive, gets excellent gas mileage, and comes fully equipped with ABS, traction control, and vehicle skid control for less than $15K! Test drive one before you buy a SUV.
  • jsylvesterjsylvester Member Posts: 572
    My parents were looking at CRV's, both new and used. They ended up getting a 2002 with 18,000 miles, which was built in Japan. the new 2004 they were looking at were built in Leeds, England. Was production moved?
    The xB has about 1/3 less cargo room than the CR-V. It is actually more simliar in size to the Toyota Rav4, but a bit larger. I've seen the CR-V next to the Scion - the xB seems much smaller. I do like the ABS and stability control as standard. However, to fully equip the Scion, you will have to put the options on (each one increasing the price)...
    Not to put down the car or anything, but I don't consider it to be in the same vehicle class. Never hurts to shop around though.
    Also, I personally would wait until it was crash tested; I would be concerned about a vehicle that small.
    stevedebi, I agree that the cargo room in the CR-V is larger than in the Scion. But it depends on the buyers's needs and that additional cargo room is useful only if it's really going to be used. In the Scion, it's very easy to fold the rear seat to increase the cargo room. Being a Honda owner, I started shopping with the CR-V but ended up with the Scion because it was the perfect car for my needs.
    The seats in the Scion are hands down the most comfortable among ANY car or SUV I've checked out, regardless of price. And the leg/head room in the CR-V is definitely smaller than in the Scion.
    I'm not sure what options on the Scion you're referring to unless your're talking about cosmetic accessories like cupholder lighting. As I mentioned earlier the fully equipped base Scion xB (for less than $15K) has ABS, stability control, traction control, keyless entry, rear tinted glass, AC, 6 speaker CD stereo, power everything, what else do you need?
    As far as crash test results, the xB scores as high as the CR-V in Japanese Government test results, IMO. See below:
    http://www.nasva.go.jp/assess/html2002e/as105.html
    The Scion xB is listed as the Toyota bB in the above table.
    One more thing: the Scion is clearly not for people who want a lot of horsepower, it's got 108 hp which I find perfectly adequate for its 2500 lb weight.
    Thanks for all your input. This will be my peronal vehicle...no towing. Some trips up to Napa. I currently drive a loaded cougar. So hence, the thought of cheap seats crossed my mind. I went back and drove another. I actually looked at things with a much more open mind..and no..The seats didnt seem as cheap to me as the first time I saw them. I enjoyed my second test drive much better. I was pulled between CRV and the new Kia Sorento. The sorento is loaded with bells and whistles..which attracted me to it. But Bottom line...I think I would have a great buy in the CRV.
    Tami
  • aggie1995aggie1995 Member Posts: 318
    Kia has a great warranty.....though you may actually have to use it fairly often.
    Gas mileage will not be as high as the CR-V. So if gas prices in Northern California are as bad as I remember that might be an issue for you.
    If you don't need the space that the CR-V has to offer, check out the 2004 RAV4 it has an upgraded engine, and nice fit and finish.
    Good luck with your purchase.
    "After reading so many neg posts here I am not sure."
    this is a common reaction, but remember that people come to these boards for help with problems, so you're going to see more problems here. If you go to any car board, you're going to see a lot more failures than are actually out there.
    I have a 2002 EX auto with 35,500 miles and the only complaint I have is that I don't like the OEM tires that they are shipped with, which is pretty common in the honda/acura family. I replaced them at 30k without incident, though, so they're not a big problem.
    good luck with your decision :)
    Yep, it has more front leg room than the CR-V. But the CR-V is fine for me at 6'.
    I didn't consider the xB due to cargo hauling (it is our family car and we carry lots - I can fit 4 peope and lots of luggage), and lack of US safety testing.
    I should also note here that I had several Toyota Camrys during the 1990; each one suffered a huge MPG loss within one year, and the last blew the head gaskets at 48K. So Toyota had a strike against it to begin with. That, combined with the engine sludge controversy, made me wary.
    So, to each his (or her) own. Good luck with your xB.
    If you're not going to be using it for serious snow duty, hauling cargo, or packing it with passengers, then the Scion xB and Toyota RAV4 should make worthy alternatives. Actually, the Toyota Matrix would probably suit your needs.
    Based on what you've posted, I'd avoid vehicles like the Liberty, Xterra, and Sorento. While each has it's own charms, they are built to be used as trucks. IMHO, you'd be better off with a fuel efficient/economical car-based vehicle.
    The CR-V is a bit of a mix. It isn't as trucky as something like the Liberty, but it does have terrific cargo and passenger capacity. It sort of finishes second place in everything rather than specializing in any one area. Still, it sounds like you will be better served with a vehicle that is almost purely car-biased.
    I 2nd the nomination to sample an xB, they offer good value. Dealers have just 9 days' worth of supply (60 is the industry average) so you may even have trouble finding one.
    Also try a Forester (turbo if you really want power) and RAV4 with the new 2.4l engine.
    Then, if you buy the CR-V, you'll have no regrets.
    -juice
    Impreza TS or WRX wagons are pretty nice too.
    I was basically down to the CRV and Forester, with the RAV4 3rd, but down on the list due to the super expensive options.
    My wife, who drives the car primarily, fell in love with the CRV immediately. If the turbo forester was available then, things might have gone a little differently:)
    Dyno results peg the torque for the Forester XT at about 265 ft-lbs...and I'm seeing prices in the $23k and change neighborhood.
    -juice
  • tpannitpanni Member Posts: 9
    I bought an 02 CRV EX two months ago and did not consider the Scion. The first look at the Scion peaked my interest, but after giving it more thought, had I considered it, I would still have bought the CRV. One of my main considerations was safety at a time when the freeways are full of high center of gravity heavy SUV's. Buying a monster SUV is philosophically unacceptable to me. The CRV is the car based small (but spacious) SUV with safety features and crash test results that fit the bill. The CRV weighs 3,400 lbs to the Scions 2,400. Even if crash test results for the Scion produce 5-star NHTSA ratings, it's much lower weight (the other important factor in passenger occupant survivability) make it less safe than a CRV in vehicle collision incidents. The other issue is the 108 hp for a box shaped (I actually like the shape) vehicle. My previous car was a 4 cyl Camry Wagon and the power when passing and climbing was inadequate, something I am not going back to.
    I agree with an earlier post that more car alternatives in spaciousness and economy, such as the Scion, are very good for the consumer and for competitiveness in the auto industry.
  • kwhkwh Member Posts: 68
    If you order a CR-V, can you specify where the CR-V is built? I live in North Carolina. I'm thinking about ordering because I want a 2wd LX with side airbags - I've never seen one on the lot - one saleman used a locator and said there's none out there.
    Of all of the CRV models, that would be, by far, the least popular model.
    If a dealer orders one of these, it means he has to give something else up like a fast selling EX 4WD.
    And...no, you can't specify where it's built. I haven't been able to tell a bit of difference between them anyway.
    Kwh - The products made in the Swindon plant have won several reliability and dependability awards. If Honda did allow you pick where your vehicle was built (they don't), I'd probably ask for the English model.
  • taykinitezytaykinitezy Member Posts: 56
    varmint....for curiosity sake why would you choose the Swindon assy. over the Japanese? I ask because our '03 is a Swindon of which I was skeptical....although no complaints so far...thanks.
    In recent years, products made in the Swindon plants have been winning awards as mentioned above.
    The magazine "WHICH" (I'm not yelling, that's how they spell their name) rated the CR-V, Accord, and Civic at near 100% performance in a dependability study (simply asking, "does the car start?"). All three came from the Swindon at the time.
    Other studies (similar to JD Powers and CR) gave the Civic and Accord 1st and 2nd place in reliability a year or two before they started making CR-Vs.
    The Swindon plant was, for a long time, mainly an engine plant. Those engines were used to power several of Honda's most reliable products here in the US. Even though final assembly was performed elsewhere.
    In short, I have no reason to suspect the quality from the Swindon plant. The only reason people cite for not wanting an English CR-V is typically an old prejudice against English automobiles like Rovers, Jags, and the classic English sports cars. Given that the CR-V is made with Honda technology, parts, and quality controls, I don't buy into such prejudices.
    That bias existed because the English auto manufacturing sector invented intermittent wipers. Just not on purpose. Some times they worked, other times they didn't. ;-)
    -juice
    Yes, the English also had a random start feature designed to save fuel by forcing you to take public transit.
    I think some Jag X-Types still offer that feature.
    -juice
    Careful, I hear Lord Lucas rattling his saber. Wouldn't want to cause the grid to break down yet again.
    OK, sorry 'bout that.
    I shouldn't talk, the Cooper engine plant is in Brazil and look at the quality scores of those.
    -juice
    I've heard plenty of rattles in English-designed cars, but I never suspected they were caused by a saber...
    hehe, must be a Land Rover thing.... Nanuq would know.
    Wow, is he still here? I haven't read anything from Nanuq in a few years. I'll have to go visit the Rover threads.
    He had an old school Discovery, went off road a lot, too. I also haven't heard from him in ages.
    -juice
  • herzogtum71herzogtum71 Member Posts: 470
    Is it possible to get the 2WD CR-V with ABS? The Honda web site lists the CR-V specs in one place with ABS standard on the 2WD, and in another place it seems to say ABS is unavailable except on the top-of-the-line 4WD mode. Thanks.
  • andrelaplumeandrelaplume Member Posts: 934
    What the heck is this....I do not see it listed on Edmunds under Toyota...
  • inkieinkie Member Posts: 281
    I drove triumphs [spitfires & tr 7s and take it from me they were fun to drive when they did not break down which was unusual. I was constantly repairing everything. The only thing that was reliable was the shift lever. I was able to change and alter parts with american made materials and it was only than that I had many months of fun with these autos.
    ABS is not an option on the 2wd model (side airbags are). Not sure which screen has the confused specs on the Honda site. For a complete listing, take a look here.
    Andreaplume - Scion is a new brand name, but the company is Toyota. It's the same deal as with Lexus (which is a Toyota brand) or Acura (which is really Honda). Scion currently has two vehicles, the xA and xB.
    Inkie - Love the look of the Spitfires. I'd put up with all the problems just to have one of those.
    Scion is currently being sold in the USA only in California. (Or maybe it's available in all west coast states.) In 2004 it is supposed to be available elsewhere in this country.
    Thanks for confirming that ABS isn't available on the 2WD. If you go to http://www.hondacars.com and get into the 2004 CR-V specs, you can find the discrepancy. Under the heading "body-suspension-chassis features" it shows ABS only for the 4WD EX. But if you look under "safety features" it shows ABS as standared on all 3 models -- 2WD LX, 4WD LX, and 4WD EX.
