Midsize Sedans 2.0
17273757778545
    None of these cars have "above average" fuel economy, and I wouldn't make the final decision over 1 mpg anyway.
    I agree.
    For these cars in 4 cylinder versions, 1 mpg saves about $400 in 100,000 miles. That would mean $40-80 per year for most people, based on 10,000-20,000 miles per year. I think in CR tests almost every 4 cyl is within maybe 2 mpg of every other. So in most cases you are talking about a difference of $80-160. For me this is not enough difference to have any significant impact on my car choice.
    Anyway, the differences in purchase price can be more than enough to make up for any mpg deficiency, in some cases. I believe I would have had to pay $3000-4000 more to buy an Altima or Accord, rather than my Mazda6. If fuel costs me $800 more over the first 100,000 miles, I am still way ahead. As always, the calculus is different for frequent traders.
  • captain2captain2 Member Posts: 3,971
    IMO a lot of evaluations of braking performance is somewhat subjective anyway - meaning how 'hard' and 'linear' the brake pedal feels. My Toyota has a decidedly mushier feel to it than my Altima, for example, but they both stop in about the same distance.
  • zzzoom6zzzoom6 Member Posts: 425
    The Mazda6 seems to have an advantage in breaking in the comparison test done by Edmonds (I prefer to use comparison tests since the results are gathered from the same track on the same day which controls for weather differences). The Accord took 133.4 feet to stop, the Altima (previous gen) took 137.3 feet and the Mazda6 took 123.5 feet to stop from 60 to 0. If I remember correctly, most of the other comparo's had similar #'s with the mazda6 doing quite well compared to it's peers in braking distances.
    The Mazda6 seems to have an advantage in breaking...
    Now that's an odd thing to call an advantage :D;) .
    But why does their have to be a large dividing line? Why can't simple mathematical ratios be used?
    Multiply a factor (say .001 or whatever) by the amount of miles driven or any other criteria like the cost of the vehicle (.001 x 20,000 to come up with some "cost." You could do this for everything... that way 19,999 dollars won't differentiate more than it should from 20,001 dollars.
    and this may all be true, although it was MT that listed both the Fusion and 6 at 131 feet. As kdshapiro noted 'a sample size of 1' that probably makes no allowances for driver to driver differences as well. I guarantee you that I could get a car to stop in shorter distances when I was 20 years old, then I can now simply because I would imagine my reaction times have aged as much as I have. Nobody said that the 6 had 'bad' (or especially good) brakes, only that it is a stretch to assume that any car will avoid an accident when a different car wouldn't, when what we are really talking about about a lousy 10 feet or so of 'tested' braking distances - which BTW translates to 1/8 of a second of reaction time at 60 mph..
    While a good set of brakes is probably #1 on my list of REAL (and useful) active safety features, it is still only a part of what makes a dynamically 'safer' car, those other parts being power and handling. The trick, of course, being able to avoid an accident so that you don't end up with 538 airbags giving you chemical burns....
  • baggs32baggs32 Member Posts: 3,229
    although it was MT that listed both the Fusion and 6 at 131 feet. .
    Do you have a link for that captain? When I checked MT's site I found their test of a 2004 V6 Mazda6 and it did 60-0 in 127 feet.
    My experience with my former 6 agrees with what zzzoom is saying. It stopped hard and fast and did save my butt a couple of times. Once from an idiot and once from a deer on a highway. Both were panic stops where the brake pedal went as far as I could push it and the ABS didn't even have to kick on either time. The only time I experienced ABS in that car was in the snow or when braking going down a hill and hitting a pothole or bump in the road if anyone knows how that goes.
    you miss the point - your 4 feet, if indeed that is the case, is inconsequential - a Camcordima driver can properly say that his brakes 'saved his butt' quite correctly, that is what brakes are for! I would further suggest that if you don't get your ABS to kick in on what you regard as a 'panic' stop then either the ABS isn't working right or it wasn't really a 'panic' stop at all! If the 6 has a higher level of wheellock tolerance in its ABS settings, that would likely serve to reduce braking distances simply because of that and be (somewhat) unrelated to brake system effectiveness.
    I would further suggest that if you don't get your ABS to kick in on what you regard as a 'panic' stop then either the ABS isn't working right or it wasn't really a 'panic' stop at all!i>
    Oh they were panic stops all right. I credit the lack of ABS activity to a combination of hot asphalt and summer tires. The ABS worked just fine as I told you in the previous post (came on in snow quite often). I would wager that those same summer tires (technically they were all-season OEMs but that was a joke) increased my stopping distance in the winter. However, being that it was a stick I used engine braking a lot during those months.
    I know for sure that the ABS did not come on when the car pulled out in front of me but it might have come on for the deer. It was dark and cold and my family was in the car so a lot of other things went through my mind and the ABS could have slipped my mind. I don't recall it coming on then though.
    Believe what you want but I'd wager that all Mazda6 owners who participate here will back me up on the great brakes that car has.
  • luvmbootyluvmbooty Member Posts: 271
    Not hauling anything but maybe 3 kids and wife. Mostly doing city driving. I just like the thought of having both power and saving on gas. So far, it seems to me, to have power you have to give up on high mpgs or visa versa.
    I intend to buy within a year. Thinking of buying slightly used and would keep it for 5 to 10 years. Being that the case, even one mpg difference might mean a lot one day soon.
    Definitely want something with 4 cyls. Camry hybrid is out of my price range. The Sentra's size is just enough for my needs, but don't want smaller than that. No other small sedan with an A/T that size has 177 Hp, uses regular fuel, and has a new government mpg rating as high as 24 city/ 30 highway.
    My other car is 06 V6 Rav4 with 3rd row. Mother-in-law just bought the 07 V6 Camry. Took it for a spin. Great ride!
    I was impressed by the 07 Altima because it showed better performance with improved fuel economy, even if it's only a 1 or 2 mpg difference, you have to admit, it's still impressive. According to Consumer Reports, the 4 cyl Accord 0-60 was 9.0 seconds, the Altima's 8.1, V6 Rav4 0-60 in 6.7 (same engine in the Camry). The new government mpg rating for the Accord city is 21, the Altima's 23 city.
    Not saying that one car is better than the other, but the new improved Altima has caught my attention.
  • elroy5elroy5 Member Posts: 3,735
    First you say "slightly used" and then say 07 Altima. That would definitely be slightly used considering they are very new. Seems like there would be a very limited number of used 07 Altimas out there right now.
    If you can wait for the new accord to come out, you may like the improvements they may make. And if you don't care for it, you can use the new Accord as a way to leverage a better price from the Nissan dealers. It's a win-win situation. Unless you've got a serious itch, I'd wait just a little longer.
    One other thing...if you're going to have a driving style where your 0-60 times are important to you (in other words gunning it when you have a chance), you can pretty much ignore the EPA estimates cuz you'll probably end up getting much less than that.
    Since you liked the Camry, it sounds like you like a soft-ish ride. I've heard the Altima is on the firmer side so make sure that this is ok for you on the type of roads you'll be driving on.
  • falmouthfalmouth Member Posts: 30
    MPG for an 07 I4 automatic Accord is 24, not 20. It is 20 for the 6 cylinder which is much faster in the 0-60. A 4 cylinder Accord is def better on gas than a 6 cyl Altima.
    I never said it didn't did I? - if you want to consider a few feet of stopping distance the difference between 'great' (there are a number of primarily European cars that can get into the 110s 60-0) and merely 'good' then all the more power to you - keeping in mind of course that your 4 feet translates into about 1/20 of a second in time reduction it supposedly takes you to stop (from 60) as opposed to the other cars in this group. You do point out a real difference maker in both handling and braking prowess, however, those summer tires you are talking about. Or you could go even further and put in a good set of 'softer' ceramic pads, cross drill some rotors, and maybe rival those BMWs in brake performance.
    Brake performance has a lot to do with fade resistance and ease of modulation and much less to do with somewhat subjective tested stopping distances, which will vary from car-to-car (and driver-to-driver) in any case.
    I never compared the brakes of the 6 to the other car's brakes because I haven't driven any of them recently. So I'm not sure why you keep asking me to validate which brakes are good and which are great.
    You also keep comparing test results like they are some kind of fact and a 6 will always stop 4 feet shorter than an Accord, or whatever else, just because the tests show that. Unless two vehicles are tested on the same day at the same location then the numbers need more information attached to them. C&D now publishes weather data in their test results now, which helps decipher the performance data, but I couldn't find any for any of these cars. Environmental factors can vary results such as stopping distance by several feet. You can start getting into the measurements that equal lengths of cars when that happens and that IS significant.
  • benderofbowsbenderofbows Member Posts: 542
    Interesting article. All that damage at 5 mph.
    I'll probably be increasing my following distance on the way home...
    Even though C&D publishes weather data, they have for years been - and AFAIK continue to be- using a mathmatical equation to correct for atomospheric conditions relating to weather wrt to performance figures such as acceleration and fuel efficiency. I'm not sure this would apply to braking, obviously, but its worth noting.
    A reporter is hoping to talk with consumers who have participated in Saturn’s “Side-by-Side-by-Side” test drive program.
    Please respond to jfallon@edmunds.com before 4pm Eastern on Friday, August 3 with your daytime contact information and a few words about your experience.
    I don't think those adjustments apply to braking and I'm pretty sure MT still does the same thing too. I am rather certain that they won't do a braking test in the snow or rain though. That would be unfair because they probably couldn't do both for all makes/models, although it would be useful to the consumer.
    Summer tires will work well in dry conditions. If the conditions are slippery, what do you do? Change tires, or stay home? Wet or other slippery conditions are when the most grip is needed. Any tire works good enough for me on dry pavement. I want my tires to be at their best, when the conditions are the worst.
    Summer tires work well on wet and dry pavement, in most places it rains during the summer and they are designed for that. They are not designed for cold temperatures, and will become very brittle and hard and not grip the snow and ice. That is why 'summer tire' cars require dedicated snows in winter in cold climates, or switch to all seasons.
    If you use an all season ultra-high treadwear rating tire, you are already used to that since it is hard and doesn't grip particularly well all year round :P
    Its interesting as "traction" is stamped on the tire with a letter grade, but what it really represents is wet weather braking. It has nothing to do with how well a tire can start on something slippery or how well it corners, just wet braking. Whats more is like all the information printed on the tire, it is tested by the tire manufacturer, not any independent organization (at least for FE, the EPA does the testing).
  • jd10013jd10013 Member Posts: 779
    oddly enough, the interior room of the sentra is not much less than the altima, it might even be bigger. When nissan rolled out the versa, they bumped up the size of the sentra quite a bit.
    I agree with what you said captain a few posts ago when you were saying that brakes are one of the most significant safety features a car can have. This was definitely illustrated to me quite clearly when that idiot driver in the bmw made a very unsafe left hand turn into my lane when I was going about 50 mph... had I been driving the Accord, the data from Edmunds comparison test of midsize sedans indicate the girl in the passenger seat would likely have been hurt. Given that I stopped within a foot from the front passenger door of the bmw while I was in my Mazda6, the 10 extra feet that the Accord took or the 14 extra feet the Altima took to stop in that comparison test, that extra distance could have led to a very bad accident.
    I don't know why you keep talking about reaction times...my reaction times are the same if I'm driving an Accord or Mazda6, so the distance it would take me to stop would be higher in the Accord than the Mazda according to the car magazines that tested both cars on the same day on the same track with the same driver. Perhaps you're right about some cars slowing down my reaction time... the average midsize sedan would be a bit soft and boring to me and my senses might be dulled as a result and leaving my a bit sleepy and bored, thus a bit slower. Another argument for engaging cars like the Mazda6!!!
    The Mazda 6 has good brakes. OK, we got that. It also has average reliability, and not so great fuel economy or acceleration. We know that too.
    Has a LOT to do with the only thing actually in contact with the road, the tires.
  • kdshapirokdshapiro Member Posts: 5,751
    "had I been driving the Accord, the data from Edmunds comparison test of midsize sedans indicate the girl in the passenger seat would likely have been hurt"
    Just out of curiosity, have you actually measured a panic stop from 60. Your car might be in a condition where as an Accord might handily stop sooner.
    DING DING DING we have a winner. I am almost positive the somewhat below bar brake ratings on the Accord are due to tire choice.
    Likewise. I can induce ABS on dry pavement, so it isn't a lack of braking power that is the issue. It's the lack of grip from the fuel-economy-maximizing Michelins.
    Aftermarket tires will yield better stopping results, I bet.
    In my track experience, the Contour with stock brakes and stock tires seemed balanced, but when I started using the R-compound track tires (that happened to be 20mm wider also), the brakes started to get in over their head. I upgraded the pads and rotors front and rear, added stainless steel flex lines (they are usually rubber) and used a better brake fluid, and the braking improved considerably (more the fade resistance than anything).
    On street tires, I could invoke ABS at freeway speeds in a panic stop.
    I don't know what I am going to do with the Accord yet, since Honda put an oddball tire size on the the '07 EX, making upgrades more challenging with a 16" wheel.
    I get in the Explorer with my wife and we both get to work 10 minutes late. Only in very deep snow though. I drove the 6 in an inch or two of snow a few times and only had trouble getting moving on hills. The T/C helped but at times I had to start in 2nd gear.
    Braking was never a problem because, as I mentioned before, it was a stick and I used the engine compression to supplement the wheel brakes.
    That is one big reason why I always like to buy a stick equipped car. It's very nice to have in the wintry weather which lasts anywhere from 5-7 months around here.
    I like the fact that all Honda automatics that I know of allow you to lock into second gear, avoiding first altogether, just by selecting "2". All autos should have this option!
    Why would you say that? Now your comapring aftermarket on the accord to stock on other cars. its like saying my car is faster than yours after I installed a grand worth of aftermarket parts and you kept yours stock. Is it maybe, just a tiny tiny bit possible the brakes on another car are better than the accord?
    Possible? likely? whatever. Sure, other cars may have better brakes. Will it change the mind of someone who wants to buy an Accord? I seriously doubt it. The differences are not that great.
    Yeah, I'd have to agree the Michelins on my Mazda6 are a bit of a weak point. I have heard from many Mazda6 owners who have changed tires to other brands that cornering, braking, and wet weather handling improves considerably. OEM tires on most of the midsize sedans tend to be a bit too hard and do not emphasize grip as much as long wear. I do plan on upgrading to lighter wheels and better gripping tires in the near future and I can't wait to see the improvements in handling and braking.
    the following is quoted from motortrend in a midsize comparo (note the mazda6's lack of significant brake fade after repeated 60-0 stops):
    "We all agree the 6 has the most well-balanced, confidence-inspiring chassis--especially for navigating the canyons--of our group. It neither understeers nor oversteers when pushed to the limit, and its tires never scream "mercy!" While it may lack the brutish punch of the Altima, it more than makes up for it with quick reflexes and sure-footedness. Everything works together in harmony: the supportive seats, good driving position, broad gear ratios, quick steering, and unfailing brakes.
    We had a suspicion the Mazda 6 would be up to the task at the test track--and it was. The V-6 Mazda ran a 6.67-second 0-60 time with only a mild case of front-wheel hop. We just barely noticed the variable-valve timing and negligible torque steer kicking in somewhere in the upper-rev range when the quarter mile flew past in 15.13 seconds at over 94 mph. Standing on the brake pedal at 60 mph produced an impressively short 121-foot stop that grew only slightly after the fourth or fifth attempt. In the 600-foot slalom, a 63.9-mph pass puts it at the top of this test, as well as near the top of the sedan segment."
    they also tend to be a bit cheap. I think its one of those things where most buyers won't notice the difference, and the manufacturer can save a couple $$$
    Kind of irritated me that my brand new shinny altima came with $80 continentals on it.
    Yeah? Well it irritated me when I heard my replacement tires would be $700+ if I wanted the same kind.
    Lucky for me, i don't. I have Bridgestone Potenza G009s on my 1996 Accord, and will put them on my 2006 Accord when these Michelins wear out. Interestingly, I have 23,000 miles on the '06 and have very little wear to show for those miles.
    C/D has completed its long-term test on the 2006 Sonata LX. They ran it for 40k miles. Very interesting report, especially for anyone who thinks the Sonata is not competitive in the field, or reliable.
    Key stat: Cost of non-scheduled maintenance = $0.00.
    The report is not posted online yet, but here's a couple of quotes:
    If the interior of a mid-sized U.S. sedan looked this good, the Detroit Free Press would hail it as a worldbeater. Fit and finish and materials are terrific.
    Then there's that aluminum 235-horse, 3.3-liter V-6, which is as quiet at 70 mph and at wide-open throttle as a BMW 335i's and is way, way quieter at idle. It performs other BMW-ish feats, too, such as pulling the Sonata all the way to 144 mph, or, if you're caught on photo radar in Scottsdale, 147 mph... . All of that for a paltry $23,495 or $23,645 today.
    That doesn't sound paltry to me. Where can I read the rest of the story? (Since I know you only copied the good parts). ;) I'm sure you can find two sentences of "good stuff" in any car's review (even the Sebring).
    Ok, I normally don't do this, but I think I can be nit-picky for a second.
    A BMW is a sports car, not a lux-cruiser. Its supposed to be louder, more visceral, more raw. It would be kind of like saying car A Malibu offers more legroom and fuel economy than a Mercedes C350 sedan. Not really that impressive to me, since the BMW isn't going for the whole "quiet serene" thing, that is far from its purpose.
    A car being quieter than a BMW does nota a BMW-ish car make. That's my opinion (right or wrong).
    I like the Sonata and think it is a good automobile. That part of the article bugs me though.
  • m1miatam1miata Member Posts: 4,551
    1) it is a good car, though others are better. If you take it for a test spin and look over the interior closely, I think most people would say, pretty good, as in 80% or 85% that of an Accord or Aura. It simply doesn't have the steering and overall refinement of the best. It is fine for the money, if you keep it though the warranty period.
    2) Other cars will go pretty darn fast without a speed limiter. As for the 147 MPH, I guess it is all things possible, but I am not so sure that is accurate. Strong tail wind :surprise: I will take an inline 6 made by BMW any day over a Hyundai, thank you.
    3) I paid around $22,500 for an Accord SE V6 and it should cost me less than a Sonata to own, should I sell it in three to five years time frame.
    Just my take,
    Loren
  • bhmr59bhmr59 Member Posts: 1,602
    80 to 85% as good? I disagree.
    As for price, bang for the buck, we got an '07 Sonata SE w/ XM (& floor mats, big deal) for $16,651 plus $189 doc + TTL for a total OTD of $18,189. I don't know where the Accord SE fits in Honda's line up or how it is equipped compared to the Sonate SE, but based on your paid price of about $22,500 our Sonata was at least $4,300 less, assuming your "about" $22,500 was the OTD price. $4300 sure as heck covers a lot of the depreciation Edmuind's uses in calculaing TCO. (Our purchase price was a couple/few thousand less than Edmund's TMV at the time.)
    Keep in mind that C/D was quoting MSRPs, not typical out-the-door prices on the Sonata LX. $19k is a more typical price for that car, although I've seen some buyers get better deals. That is for a car comparable to the Accord EX-L V6 but w/o moonroof (C/D didn't get it on their tester).
    Right now, the only place you can read the rest of the long-term wrapup on the Sonata is the September issue of C/D. Eventually they'll post it on their web site, www.caranddriver.com.
    And yes, there is some negative stuff in the review, e.g. it doesn't handle like a sports car and it doesn't make the driver stand out in a crowd. But what mid-sized family cars do? Overall I think you'll see it's a very positive review. (There's a lot more than two positive quotes in there.)
    bhmr59, isn't that Sonata a 4cylinder model? That's not a good comparison to an SE V6 Accord. If you were to drive both, the difference would be clear. It will also be clear at resale time. My 03 EX V6 is 4 years old with 48k miles on it, and it's still probably worth more than that Sonata is. Apples to Oranges sir.
    No, for 2007 the Sonata SE was V6 only. For 2008 you can get it with an I4 or V6.
    As for the value of your Accord, Ecmunds.com says it's worth from $13.4k (trade-in) to $15k (private party sale). Original MSRP was just under $26k. Don't know what your price was, but it's lost about $10k in value. I don't think bhmr59's Sonata has lost $10k in value yet, and if it's worth less than your car right now, consider that he paid far less than you did for your car. I'll bet his car, if properly taken care of, will be worth more than $6500 when it's four years old, if it has only 48k miles on it then (it'll still have factory warranty to the next owner!). As you said, apples and oranges.
    bhmr59 sure gets excited about a car he doesn't even own (his brother does). I paid $25,000 for the car I wanted, because I plan to drive it for a long time (probably 10 more years). So my true-cost-to-own will be pretty low by then. Would I want to drive a Sonata for that long? Would it last that long? If bhmr59's brother wants to take a chance, he is welcome to. I want a sure thing.
    I have had a lot of cars where the cost of non-scheduled maintenance is $0.00 after three years or so. Here is my question, what is the cost of maintenance on a car after three years? (obviously excluding gas, insurance, tires but including consumables such as wipers, brakes, oil, etc)
    - My BMW, total outlay after 3 years was $250 for the dealer alarm system.
    - Friend bought has Acura in for 7K service, cost $300 ouch, however $0.00 on non-scheduled maintenance to date.
    - My Toyota cost $500 for 30K service, ouch, but $0.00 on non-scheduled maintenance.
    So that fact that $0.00 was spent on non-scheduled is not very impressive and misleading.
    doesn't impress me either. my 98 200sx total expense over 9 years has been about 400 in brakes + the scheduled stuff like oil changes and flushes. hasn't needed any unscheduled maintenance. My 2002 civic hasn't needed anything but oilchanges, cooling system flushes ect and a timing belt that was schedulded to be replaced at 110k, and I replaced it at 100k. didn't break or anything.
    But yea, 3 years doesn't seem like much. most people haven't even paid for it yet
    My Mazda6 came with tires that are priced at $201 each at tire rack. Not what I would call cheap.
    I certainly won't be spending $800+ on tires when it comes time to replace them, though.
