-juice
My local dealer keeps sending me Thank You letters, from salesman (several times), new car manager, servise manager and general manager, even I have already given them all 5 stars.
BTW, I got free floormats, which is not standard on my LX. And the stick list it as MFSP $99. How can they charge you $120?
Don't expect to hear anything other than unsubstantiated rumors about styling and/or features until Summer.
The release date is probably October or November. It's possible that it could be as early as September. You may have to deal with waiting lists, too. :-(
In contrast, the best favor my salesperson did for me was steering me away from any pricey add-ons. I later found out that the dealership maintains "equillibrium" with eye-popping rates at the service department. ($400+ for 15k service!?)
CanadianCL - Another "yep". Though that's been true of many of my cars (Mazdas, a Chevy, two Soobs,...).
Call the dealership supervisor and the Honda 800 number and complain.
-juice
http://auto.ascii24.com/auto24/e/2001/0509/e04nsc_tm0509_02.html?sm
These article seems to be suggesting that the next CR-V is going to move up to compete with the Highlander, Santa Fe, and RX300 rather than continue to slug it out with the RAV4, Forester, and Grand Vitara. Could just be the differing perspectives of a foreign market...
Thanks to Robyn at CR-V IX for the link. :-)
2.4l would be a good idea for the next CR-V. That would give it enough torque and keep the fuel efficiency up there with the class leaders. Then bring over the HR-V to compete with the Vitara, Sportage, and RAV4.
Forester will grow. There are rumors that the next Forester will be based on the Legacy platform instead of the Impreza, which would also make it bigger. An H6 or a turbo are virtually guaranteed, too.
Things should get interesting. Even if you wouldn't buy a Santa Fe or an Escape (for whatever reason), it's good that they're out there, because competition improves the breed.
-juice
I like the idea of the 2.4 four also.
Now, just give it a full frame, and 4 Low, and I'll take it!
Or, give the SantaFe some better looks, more power, and a frame, and we'll talk.
Or, give the Sportage some better quality and a little more power...
They aren't my cup of tea, but I'm sure they're quite capable and better suited for your needs.
Maybe Kia will bring the Sportage Grand here in its next generation.
Now don't hold your breath for 4Lo in the CR-V. It just ain't likely. Heck, the Forester is more likely to get one, since they already manufacture a unit overseas.
-juice
all are under consideration, but I bet the supercharger puts the Xterra out of price range.
Honda has pledged to redesign their entire line of domestic (Japanese market) engines within the next few years. Since the CR-V is sold in Japan, we can expect that this change will affect our version. Among the promissed changes are improvements in fuel economy, emissions, and power. So basically, any engine that meets the above criteria is a possible candidate.
I've suspected the i-VTEC 2.0 because it matches the above description AND meets a few other requirements.
1) It fits in the Civic platform (Stream, RSX, etc..)
2) It's not a completely new engine (therefore, not too expensive).
3) The factory that makes the 2.0 is geared to produce up to eight variants of this new block. Honda doesn't have that many cars, so it's likely that the CR-V would be one of those that gets the new block.
Since this 2.4 is based on the i-VTEC 2.0, I'd say it's a reasonably good possibility, but it might just be that someone is very good at crafting rumors. I'd call it promissing, but I wouldn't trust it until another reputable source confirms it.
But for better torque, the 2.4l would be ideal.
-juice
Juice - The same basic block makes abut 200 hp in the RSX Type S and is ruputed to make even more in the Type R. But peak torque is still in the 140-150 range and climbs higher on the rpm band along with the HP. The Stream's 156 HP and 141 FtLbs would be the best of the 2.0 versions. The torque curve is flat from 2,000 to 4,500 rpms. That would provide sufficient motivation for the current CR-V.
I'd *guess* about 180 hp and 160 FtLbs from the 2.4 version. More than I was expecting, but it sounds like they are trying to take on larger vehicles, so there will be more weight, too.
Makes me wonder what the next Passport is going to look like. I was expecting a competitor for the Highlander, but it sounds like the CR-V might take on that task. Maybe Honda is going after the Explorer, Pathfinder, and Trailblazer.
The article says 2.4l and VTEC, which would be great. Though it also implies it'll be getting bigger and pricier. Highlanders break 30 grand pretty quick with just a few options.
When is the Honda version of the MDX going to arrive? My guess is they'll price the CR-V at about 20-25k, the Honda MDX at 28-35k, and let the Acura take over where that leaves off.
The Passport ought to be cancelled soon, right?
-juice
The new Honda MDX will arrive in Fall of 2002 as a 2003 model. The Birmingham plant ought to be online at that point. If plant completion is delayed, so too is the new Midsized SUV.
We figured that the CR-V would have a more powerful engine. We didn't know if it was going to be bigger. IMHO, the surprize is how much larger the CR-V might be. I agree with Juice, the price will certainly climb and I can't make any guesses about fuel efficiency.
I was expecting Honda to play it conservative. You don't mess too much with a class leading seller. This is beginning to sound like a completely different CR-V.
Given the fuel efficiency of the new Civic, I bet mileage stays the same (22/25mpg). They'll gear it more conservatively, so it'll be no quicker (with the added weight), but quieter and better able to handle heavy loads.
Fall of 2002 is right around the corner, so I guess the V6 Passport can soldier along until then.
-juice
I think it will be a lot better in many respects especially considering it will finally have its own platform and not share an antiquated one like it does now.
Now, while the CR-V may wind up being bigger, I think it is a mistake to assume it'll compete with the Explorer and Highlander. That role will be filled by the Mid-Size SUV in Fall 2002.
While I don't expect the '02 CR-V to compete directly with the Highlander (in terms of size and price), these articles are making it sound like it'll be as big as the Sante Fe, Xterra, and Tribute. That means it's more likely that folks will cross shop the Highlander than the Tracker, Sportage, and even the new RAV4.
Beatfarmer - I'm with you. I could use a little more space in the back, but I'm not willing to pay for a brand new vehicle just yet. This speculation is purely for entertainment on my behalf.
I don't know that this is possible given the Civic platform the new CR-V will be sitting on. I mean if Honda is taking aim at the Liberty and X-Terra, the new CR-V ought to be more than "The king of the concrete jungle" as the CR-V billboard ads state. Two totally different markets and images there.
And, the Highlander isn't that big, you are correct, but it is still considered a mid-size SUV nonetheless. Actually, when I saw the Highlander for the first time, I said to the salesman, "I cannot tell you how much I do not like this vehicle, it looks like a station wagon on steroids."
As far as cross shopping, the first thing I look at is my budget. Then, based on price, I look at features, and try to find the most I can which fits into that budget. Size is but one feature I look at.
like for example the '00 and '01 Civics had a price
difference of under $1K
The Tribape is about 4-5 inches shorter than the CR-V. This is partly due to the fact the CR-V has a spare tire rack on the back. I'm told that the tire itself does not count, but the mounting bracket does. However, depending on your model, the Tribape can weight anywhere from 200-300 lbs more than the CR-V. While they share the same wheelbase (103"), the Tribape is slightly wider and significantly taller. So it depends on how you define "bigger".
I don't expect that the CR-V will be targeted at the truckish Liberty or Xterra, but many folks who shop this class do test drive both. Even the auto mags include both in their comparos.
IMHO, there has been a tendancy to create two subclasses to what we used to call "mini-utes". There were the little buggers like the old Sidekick and RAV4 and now we have what I call "small-utes" like the Tribape, Xterra, and Santa Fe. The CR-V kinda sits between them with the body of a small ute, but the engine of a mini-ute.
Anyway, if you believe those articles, then it sounds like Honda is trying to plant the CR-V firmly into the small-ute category. Further more, those articles are consistently mentioning "trucks" like the RX300 and Highlander. I agree that those are yet another step in the bigger direction. Which makes me wonder: Is Honda going to try to build a CR-V that will compete head to head with the Tribape and undercut the Highlander at the same time? Kinda like sitting between the small utes and the smallish mid-sized ones. Pure speculation.
Squatch has a good point. One of the only reasons why the Santa Fe and Xterra are included in the small ute class is the fact that they are priced within the same range. At 4,000 lbs, they really are big boys in this class.
Highlander 4WD 2.4 cyl
MSRP $25,395
Invoice $22,645
Length: 184.4 in.
Width: 71.9 in.
Height: 66.5 in.
Weight: 3715 lbs.
Wheelbase: 106.9 in.
Turning Circle: 37.4 ft.
Ground Clearance: 7.3 in.
Maximum Cargo Capacity: 81 cu.ft.
Maximum Payload: 1270 lbs.
Maximum Towing Capacity: 1500 lbs.
CR-V 4WD 2.0 (EX) AT
MSRP $21,990
Invoice$20,132
Length: 177.6 in.
Width: 68.9 in.
Height: 65.9 in.
Weight: 3245 lbs.
Wheelbase: 103.2 in.
Turning Circle: 34.8 ft.
Ground Clearance: 8.1 in.
Maximum Cargo Capacity: 67 cu.ft.
Maximum Payload: 920 lbs.
Maximum Towing Capacity: 1000 lbs.
Escape XLT 4WD
MSRP $21,750 + $1,480 (for v-6)
Invoice $20,350 + $1,33
Length: 173 in.
Width: 70.1 in.
Height: 67.8 in.
Weight: 3238 lbs. (3457)
Wheelbase: 103.1 in.
Turning Circle: 35.4 ft.
Ground Clearance: 7.8 in
Maximum Cargo Capacity: 65 cu.ft.
Maximum Payload: 978 lbs.
Maximum Towing Capacity: 1000 lbs. (braked 3500 with towing pkg)
Santa Fe LX 4WD (2.7L 6Cyl 4A)
MSRP $22,494
Invoice $21,086
Length: 177.3 in.
Width: 72.7 in.
Height: 66 in.
Weight: 3720 lbs.
Turning Circle: NA
Ground Clearance: 8.2 in.
Maximum Cargo Capacity: 78 cu.ft.
Maximum Payload: 2200 lbs.
Maximum Towing Capacity: 3500 lbs.
This pretty much shows that the current CR-V is a bit smaller in most dimensions than the Escape and Santa Fe, but there's not such a big jump between the Santa Fe and Higlander. So IF the CR-V grows to that size, it wouldn't be a huge stretch.
Drew
Apparently, so would others:
http://www.rockstomper.com/catalog/tubework/bumpers.htm
I assume this is to protect it from damage on trails and also make it easier to access (for damage from trails!).
I don't think any manufacture is going to build tube steel from the factory. Too much money, not enough profit.
I doubt the new CR-V would change quite that much. If you look at all the newcomers (RAV4 being the exception), they're all getting bigger, so it'll be about par for the class.
My guess is the 2003 Forester will also get bigger, leaving only the RAV4, Sportage, Tracker, and Vitara in the mini class.
Sad thing is I actually like light and nimble vehicles, so my choices are dwindling. Then again, there's always the WRX wagon.
-juice
I think the crossovers are just going to get more and more interesting. All these off-lease SUV owners are going to want something more car-like and efficient.
Anyone else notice Expedition residuals took a sudden nose dive lately?
-juice
And if you own one, you might be interested in joining some of us on the 'Summer 2001 Mid-Atlantic CRV Meet.' There will be prizes, promotions, a rally, and a picnic at Oriole Park in Baltimore. It is on June 2nd, follow this link if interested.
http://www.geocities.com/crvmeet/
We had a great time last fall, so if you are in the area...
When I bought my Ranger XLT Sport in August 99 (brand new), I paid $3000 below the $17,000 sticker price. When I bought my wife's 00 Accord SE in August 00, I paid over $4000 below the $22,000 sticker price. At the time both vehicles were in normal demand, and the Accord was only 1 of 2 SE's they had left (they had been selling at invoice price prior). I just bargained hard, had cash in hand, and got a good deal.
Anyone from the NE area buy one of these for a steal? If so, how much roughly? Where? Any contacts? Thanks. terrymcginnis.
The Hyundai is selling well. A local dealer that puts no-haggle prices on-line has exactly zero in stock. They are near retail in the DC area, at least, with little supply.
The Mazda is similarly new, though you may get deeper discounts than at Hyundai, because it costs more to begin with.
-juice
I did all kinds of research, Internet type, and we decided to get a Honda CRV. We also own a pickup and a large van. This is the "comfortable, long trips, better on gas" car. I love it. Our own baby SUV.
Went grocery shopping then drove the 18 miles to pickup grandkids for an overnight. Was going on, and on, and on to my daughter about how much I like this car. Then got in -
The car would not start. Well, the key would not turn past the 1st position. We have only had this car since Monday! When we were at the dealer last Friday I was sitting in the one that we took for a test drive. Tried to start it - and the key would not turn completely. The salesman, who was sitting in the passenger seat said I might not be turning the key correctly. (Yeah, right) After jiggling the key and steering wheel, the car started. Well, today I jiggled, pushed, jerked, thumped and finally called the service person at the dealer. He said jiggle the steering wheel. I did. No luck. He said force the gear (automatic) shift into Park. I did. No luck. Well, the guy was concerned that this isn't a problem starting. Me too. The car finally started, well, the key finally turned, after 20 minutes jiggling..
Anyone else experience this? Heard anything about it? I am still too excited about the car to be feeling this disappointed.
Help?
Judy
2001 CRV-LX
-juice
I have had that issue with my CR-V, but not to that extent. I had one time where I really had to pull hard on the steering wheel to get it moved enough to free up the ignition lock, but it was a matter of seconds rather than minutes to get it going. It has only happened 2 or 3 times in the year I have owned the car and the other times it just took a yank on the wheel to free it up. I want to say each time it happened I parked with the wheels cut fairly significantly. Sorry to hear it is giving you grief.
Drew - The Current CR-V already scores well in the NHTSA tests (19 out of a possible 20 stars). While the CR-V did tip on its side in the side impact test, the NHTSA specifies that this test is not designed to predict "rollability". However, in the test that IS designed to predict the potential for rollover, the CR-V scores a 3 star rating. While this is not good, I don't believe that any other SUV has done better. It's the IIHS off-set test score that could use some work. And yes, the new Civic platform should be an improvement.
Juice - The Highlander's 3500 lbs rating is with the V-6. It's the cargo space that illustrates the greatest difference.
John - I'll see you in MD. I'm having heated leather seats installed while I'm down there.
Judy - What you are describing sounds like steering wheel lock. The wheel can become locked into position if you turn it after shutting off the car. While the wheel is locked, the key will not turn. That's the reason why they recommend "jiggling" the wheel. IF this is the case, you'll notice that the wheel only turns in one direction. Turn it and hold it in that direction and turn the key at the same time. My only other thought is that your key might need to be re-cut.
A review from Cartalk
http://cartalk.cars.com/Info/Testdrive/Reviews/honda-crv-2001.html
and some more '02 rumors
http://www.europeanhonda.demon.nl/hondanews10.htm
