Reading your post, I don't think I want to bring it in .. specially when I have to pay to fix something for only 12 months!!!
A friend/co-worker, with experience in mechanics helped me look at the wheel, in our work place parking lot. No lug nuts where loose, the wheel bearing seemed fine, and was unsure about the CV shaft without a real look in a shop.
I seen someone else had a similar problem just after getting new tires, but he did not get a response. Has anyone else had this problem or now the issue? Is it a problem with the vehicle or the work done?
Let's go through the cars, 1998 Olds Intrigue-steering rack, ISS, and brake issues, GM bought the car after 26k miles, costing me only $800 to own..2nd car was a 1999 Olds Intrigue which I ran 75k miles, couple ISS problems, traded on a 2002 Olds Intrigue which I ran 120k miles, replaced the ISS once..Traded it on a 2006 Grand Prix GT showing 4k miles, ISS replaced 3 times, all free/no charge by dealer..Last shaft was done @30k miles and car is now @70k, no play, great tight steering..
The dealers tend to use up old stock when replacing these shafts and this item has been re-engineered many times..I got the latest shaft design, and if if needs lubing my mechanic will take care of it..Small shop 2 ex-GM certified mechanics, experts at wheel balancing is how I found them..Also replaced the main engine/tranny mounts, both collapsed.
Happy I found this site on Malibus, for I shall stay away from them...enough grief with petty problems..
You should still be within your bumper to bumper warranty, although if you want for us to check for sure we can do that. Just email the last 8 digits of your VIN and your request to us at socialmedia@gm.com
Sarah, GM Customer Service
I'm sure glad I found this forum, thanks all.
Thanks so much.
