Volkswagen Passat Bluetooth Questions
in Volkswagen
I've heard that there is something out there that you can buy to turn on the Bluetooth feature in my 2006 Passat. Does anyone know where I can purpose this?
Are they cheap enough and easy enough to install to be worth installing in a leased car?
Who wants to buy a car the price of a loaded Passat that doesn't have bluetooth?
So, what kind of prices to expect for either kit professionally installed?
If the Parrot is much, much cheaper, I suppose you could get some kind of phone mount (such as an air vent mount) and look at the phone's screen for caller ID.
They could have had the Skoda module installed at the factory but VW decided not to pay for the royalties or decided not to. Startac makes the unit for VW. It's also used in Audis and European BMW's.
This unit will be optional on the 2009 models but can be installed in 2006 and up models. 09's that don't have it can also get it.
Edit: This kit does offer A2DP but works like a Parrot kit that's OEM. It doesn't have any MFI integration. If you want MFI/MFD integration than get the latest Skoda kit. The Skoda kit has no A2DP though.
My dealer is telling me that he's had customers complain about the Skoda version of the BT interface, so I had high hopes that VW was going to "right a wrong" with this newly released accessory. But if there is no MFI/multi function display interface for caller ID, phone book, etc. then what is the point of a "new" accessory?
Seems retarded to me.
It would be nice if it had the Multi Function display integration. The skoda kit is the only one other than the Premium kit that has it. VW was using a Motorola kit as an interim solution until the Nokia/Novero Volk-L kit would come out. Some people are happy using Parrot kits while the Skoda kit seems to be the number 1 kit for now.
Hope this helps.
However this kit may just be an interim solution. An even better more featured kit may be in the works. In Germany there are 3 modules for bluetooth. Plain which is like the Volk-L but without bluetooth audio. Basic is like the Skoda kit and finally premium which the fully featured rSAP kit. The USA RNS-510 works very well with the Skoda kit and VW might just release a new kit that has A2DP and fully works with the MFI/MFD. Also this kit should have RNS-510 integration. It's sort of like the VW iPod adaptor. It was terrible until a new adaptor was introduced with the RNS-510 called the MDI. The MDI only works on the RNS-510 in the USA for now. Until this Premium 8 radio is introduced. Premium 8 is likely the RCD-510 which is a touch screen cd changer without the nav system.
Ted
Edit: It appears that the Skoda kit is now in the US parts system. It's even mentioned in the ETKA. The part number is 1Z0 035 729 A but it might have the B version. Also the CC has a part for bluetooth as wel. The ETKA is a VW parts database that the dealers use. There is a 2nd part for bluetooth as well. Part numbers are 1K8 035 730 and 1K8 035 730 B. Your dealer might be able to order this.
A factory bluetooth system has been released. Cars made after CW 45 will get a factory bluetooth system. CW is Calendar Week. It will have MFD integration and it will integrate with the new RNS-510 navigation system. VW has made a revision to the RNS-510 that has the Mute button replaced with Phone. Phone will enable a touch screen menu. Mute is also the Phone button on the older RNS-510's if this unit were to be installed. It will have bluetooth audio streaming and all that jazz. Finally VW is going to make it available but it will be an expensive retrofit.
Here are the recommended parts
1Z0 035 729 A
1Z0 035 729 B
The A revision kit is for White dot display cars which is the Passat CC. For the CC you must use the A revision or else it won't display right. The B version is for the red dot display cars which includes the regular passat.
We have not been able to use the steering wheel controls or access the Phone menu through the MFD. We can access the main Phone menu but cannot scroll through the options. The phone controls on the steering wheel simply do not work. Any suggestions? Thanks.
What exactly dd you have installed? Do you have any part number including the ones for cables and such? From what you wrote it sounds it works with your MDF without any problems....
I have a Passat 2006 as well and am interested on installing an integrated bluetooth solution.
Also, does this give you any navigation/maps etc. or just the phone functionality with the bluetooth and MDF. Pardon my ignorance:)
Any info is apreciated!
TY!
I appear to have the same issue as you had 2 years ago, my steering wheel buttons don't work in the phone menu.
I was wondering if you ever found a solution for this problem?
Thanks for your reply.
