Hyundai Sonata Climate Control Questions
Just got a fully load 07 Sonata. I cannot confirm this due to weather is still cool.
I pushed the "AUTO" round knob to run automatic climate control. Does the LCD show AC or the AC button lit when the system decided to run the AC. How to tell the AC is on?
In manual mode, AC comes on if temperature dial is cranked below 17C (I think ?) or by pressing the AC button; in both cases, the LCD show "AC".
1. With AUTO on the temp. is set by you and the AC will be on automatically. You will see that it pulls moisture out of the cabin so no fogging of the windows.
2. Push the AC button and the AUTO is off and your AC is on and temp. is controlled in the same manner as above.
3. Push AC button and it will turn off completely and your compressor will NOT be on.
It's a little crazy but that's the way it is set up to work. I'm used to it and it works the same way in my 06 Azera Limited. In the summer here in NY I keep it on AUTO all the time and the compressor will cycle and keep the air comfortable and at the same temperature.
Hope this explains it and that it makes sense. Good luck with your Sonata. It's a really neat car.
Don
For the pass 4 days, I was sure the air cond was on, but no indication except the cool air, there goes the gas mileage :mad: . I pressed some buttons today and the behavior is now as expected. Too bad I forget what I pressed to get into this behavior and worst forget the steps to fixed it :mad:
I have a habit to switch off AC and let the fan run a minute prior park to remove some moisture on the condenser. This is way too complicate for the wife to follow when in auto mode.
I think something is missing in the climate control software. Everything on the climate system in auto mode have an indicator, except AC in auto mode. Ideally the AC indicator should follow the compressor relay in any mode.
Interesting question:
#1 The climate system doesn’t have a heat only or cool only switch in auto mode, in the event that the setpoint temperature is met, what does the climate system do, for example in summer ? I can think of two scenario.
a) Switch off AC, keep fan running; temperature buildup then switch on AC.
b) Switch off AC, keep fan running, turn on heater; temperature buildup then switch off heater and switch on AC. I hope this is not the case!
#2 The same question for winter.
#3 How does the logic work when ambient is at the borderline like in fall and spring.
So what could be the possibility of this kind of problem? I dont want to go back to the same mechanic again because apparently he cant do any better. Your help would be really appreciated. thanks!
Yeah, it is a bit confusing.
Other inconsistencies which Hyundai Motor America claims to be "normal" that we and the regional service manager have experienced is as follows: At times, the system doesn't switch over to recirculating in the presence of exhaust gas; at other times it randomly recirculates for no reason at all and will stay on reciruclating for several miles; often switches to recirculating when going under freeway underpasses; and our Sonata and a test drive by the dealer's service manager of a 2007 model both always switched when entering a garage. I could go on and on with many more incidences.
My 2006 Sonata performed perfectly for ten months, then became erratic, recirculating 80% of the time. The dealer replaced the sensor which slowed down the reciruclating but has not resolved the problem. Hyundai claims that the random recirculation is normal regardless of what the owner's manual says.
The dealer's service manager, after test driving two 2007 models, has experienced these inconsistencies and states that he doesn't understand the purpose of the system, since it does not perform as described in the owner's manual. Hyundai refuses to admit to any problem, and we are heading toward arbitration. Also, I am preparing two complaints to be filed with the State Attorney General's office over this issue and the sloshing fuel tank.
I urge you to read your owner's manual and observe how your AQS system is operating. By the way, the air quality in this part of our state is relatively free of smog, so the system should not be recirculating unless it's exposed to exhaust gas.
Because it was on Auto, you activated one of those 3 controls (see my earlier reply) to gain manual control (just for this control, ex: fan speed), the Auto text is no longer displayed on the LCD, BUT, the other 2 controls (AC and recirculation) are still in Auto.
It remembers the setting on next engine restart. In this example, no Auto message on the LCD, but AC and recirculation are still in Auto mode.
Just press the Auto knob to put the system into a known state, which is auto. Or shut it off and do not activate the Auto mode, manually activate the desired controls.
Now that sounds easy. Where was I?
1. I don't currently own a Sonata with this feature.
2.I don't really know how it actually functions (from a technical standpoint) so I don't know what "triggers" it to automatically use recirculate mode. I am assuming it is some type of sensor but what exactly does this sensor have to sense??? What components in "smog" or exhaust gasses does it need to see?
If yours seems to have worked automatically for a long time frame I guess it does work. So, with these provisions out of the way my comments then:
You don't see any discussion of this feature because it isn't of great concern to most who post here. It either works unobserved or doesn't and most don't care.
I understand your special circumstances (wifes illness or circumstance) but guess what...cars have had (for years and years)a switch or button that can switch between recirculated air and outside air. If you detect something she doesn't like in the form of an odor or particular substance simply reach over and manually make the change to recirculate then when the crisis passes change back to fresh or outside air. Problem solved WITHOUT yet another lawsuit or arbitration trail. Yeah, I understand because Hyundai states it (this feature) exists it should work but whatever sensor drives the system apparently isn't ready for prime time. For my part this feature would be one of those "nice but never used" things like "Shiftronic". Admittedly none in our family has a breathing problem but I have NEVER switched to recirculate mode on ANY of our AC equipped cars for any reason.
As for the "gas sloshing" problem?? I personally feel you are much too picky and much too quick to file legal recourse for non-problems (in the case of gas slosh) to minor annoyances (auto recirculate) in as much as this can be accomplishes manually.
This is simply my take on your commentary. In the meantime I will try to educate myself on how this system works.
There are better things for you and our legal system to tackle than this. If it really does bother you that much trade it in and buy another car. No offense intended.
Skeeter, I'm with you on that and I totally agree with you.
"I now realaize it is a waste of my time discussing issues on this forum"
Well, it's not. You have a very valid point and you should not worry about other's opinions. They're entitled to it, aren't they? Although I do have a gas sloshing problem, it doesn't bother me too much. It doesn't change the fact thought the problem should be addressed by Hyundai's engineering stuff. If not, the legal way is the only road to go. It's not NORMAL to have a car with the gas sloshing problem. Especially a new one. Your fight is not a lost case. I'd be glad to join you , if need be.
I have noticed the temp reading tends to show a warmer temp when the car is stopped, at idle, for a few minutes (as in waiting in line at a drive-up window).
I have 07 V6 with auto climate control. Immediately after start, the defrost control (on the driver side) automatically activated, ie, the LED lit. I believe this control automatically runs the AC too. I have a habit not to run AC while the engine is cold, also no frost/fog on the windshield so there is no need for the defrost function. I had to manual depress the button to shut it off. Just for curiosity, I shut off and restart the engine, same thing. If I remember, the LED is lit even on the accessory position (before the cranking the engine).
Is this normal?
I maybe wrong on this, in auto control, if defrost is required, AC will activate but the defrost LED is not lit???
http://jerrystout.us/sonata/tsb/ambient%20temperature%20sensor%20replacement.pdf-
Thanks go to Jerry!
But, what do you mean by "not working"? Cold air doesn't come out when the A/C is on and the temperature is set to the coldest setting, for example?
Before I head to the dealer has anyone else had a similar issue?
I don't think this normal behavior. Had the car for almost two years.
But what do I know? I've got two GLSes, and neither has auto-climate control; my Father's Suburban and my FILs Lincoln Town Car both do, and they behave as you describe if the climate control is set to auto, but I'm in both of those vehicles so rarely (twice a year each?) that I could be wrong.
Automatic AC/heat controls the fan speed, vent and recirculation. You can override them. If you do, that control is no longer in automatic mode. Untouched controls still work in automatic mode.
For multiple drivers, there is no way to tell which control is manual/auto. The only way is to press the Auto mode and then change whatever you like.
