Dodge Stratus Engine Problems
i have a 2002 stratus SE and about a month ago something in the engine starting rattling when i accelerate up to about 45-50 mph. it ran out of oil around december but the rattling just started. does anyone know what the problem may be? Please HELP
:sick:
the sound start at 45mph and stay for a while then stoped
Is it something of major concern? What can possibly be going on?
With it being such a common problem someone must have a definate answer by now. Please help if you can
starter put in my car. Removed the remote and haven't blown any fuses.
I need the timeimg marks and maybe not hooked everthing back up the way its so post to be and need to now how to hook up a water pump step be step
WheelMan
WheelMan
Paul :confuse:
Mike01
1. Blown Fuse: There is a fuse for it in the compartment under the hood on the driver's side of the car.
2. Bad motor on cooling fan: If the fuse is blown, the motor could be bad and will continue blowing new fuses. You may try using jumper wires to the fan from the battery for a short period of time to see if it runs. If not, the problem is identified.
