Pontiac Torrent Maintenance and Repair
Have any issues with your Torrent? Please tell other owners about your experiences in here.
Most insurance companies have a pretty good deal on glass replacement... my State Farm deductible is only $100 for complete replacement. It's zero out of pocket if they can just fix it, but most glass shops won't fix anything in your direct line of sight.
So far my first pontiac experiance is no pleasurable . They are refering us to some where that is over a 25 minute drive (towards nyc off rt4 which leads directly to the gwb ) where as the old place was one town over from me .
I'm very upset with the dealer as i only bought the car 1 week ago and they are only giving us 2 weeks notice .
I hope that helps...
I have another question -- when the FUEL LOW light comes on, has anyone figured out roughly how many more miles you can get out of your car? My Torrent does let me see how many more miles I can get out of the gas that I have left, but it IS an estimate. I of course try to fill up before that light comes on, but if it every DOES come on, I'm curious to know if I will indeed be safe for the next, oh say 20 miles, or so.
Thanks!!!!
Several years ago I had a Chevy Camaro and wanted to take it to local Pontiac dealer for warranty repair (they were big into racing Firebirds and knew the F-body cars inside and out). They said they could only do warranty work/claims on Pontiac branded vehicles but would do the work I needed done at my expense if I wanted to take the car there.
Chrysler, however, will let you take any brand Chrysler product to any dealer for warranty work. I used to take my Dodge to a Chrysler/Jeep dealer because the Chrysler/Jeep service was fabulous (the Dodge dealer not-so-good).
They explained to me that most dealerships just don't like to do any more warranty work than they have to. The reason being, is that while corporate pays for the parts... they make the dealership eat the labor cost. So many dealerships will come up with excuses not to do any more than they have to.
I am from Toronto, Ontario I have had my 06 torrent sport for almost a year. These are the issues I have encountered. daytime running light module replaced 10000kms, Rear spoiler on trunk expands in the heat and hits when opening trunk, and the one that bothers me the most the temp gauge flucuates from just over the quarter mark to half point, anybody experiencing these probs please tell me especiallty the temp guage that scares me the most. I currently have 19000kms
No issues with the rear spoiler but I will keep an eye on it. No squeek on the brakes yet. Had it at the dealer today to have them look at the remote key entry and tire pressure monitor system. Both were giving me problems. There is a bulletin out there to replace the modules so that is what they did. We'll see.
The dealer said normal but if it fluctuated to much they would address it, if it bothers more I will have them run some tests. I dont have tire pressure monitor they came out with that for 07, my keyless entry has been flawless. Keep passing on the news
Took mine in last week for issues with the Tire Pressure Monitoring system and Keyless entry. They replaced transmitters but the range on the RKE is still non-existant. You practically need to be standing beside the car for it to unlock. Taking it back next week.
I am sure the dealers know and are not telling you.
Keep in touch
1) Anyone with 17" rims - can you tell me what the sticker on the side of the driver's side door says with respect to tire pressure? Mine states 30PSI
2)Can anyone tell me what kind of range they get with the remote keyless entry (without the remote start feature).
1) I have 235 60 R17 PSi on the door says 35psi they are Brigestones if that matters.
2) The range is okay, I dont have the starter just the keyless entry. It is not the best range I have had in the past.
hope this helps
Less then a half hour later and the break in oil was removed and replaced with 5 quarts (yes, techincally you only need 4.6 quarts, same as my GAGT but I always put 5 in) of Mobil 1 5w-30.
Break in oil was black at 2500 miles, and there was a bit of metal bits in it, nothing unusual for a brand new engine. Nothing large, just some very tiny metallic specks. Shouldn't be many in the next change.
Cost- 19 bucks for the synthetic oil and 3.50 for the AC Delco filter from Autozone.
I started using synthetic in my 01 Grand Am GT after noticing that the dino oil was leaving a nasty sludge inside. It's just a dirty substance by nature. Since I do my own changes in all but the cold Ohio weather, I figure I'm breaking even anyway by not letting a shop charge me 22.95 for an oil change and getting something that's dirty (aka Pennzoil was the offender that really got me thinking). Since using the synthetic in the GAGT, the inside is significantly cleaner, it's much better lubricated on cold days, and the engine is a touch quieter with less valve train noise.
Then I started using it on our 02 Formula with the LS1. Figured I had good results with it on my 01, and that GM puts Mobile 1 in the Corvettes from the factory, so why shouldn't the 300+ hp beast get the better treatment too. So while it was still low in mileage, around 10,000 miles, I made the swap over.
And with the Torrent, I might as well keep the trend up, if for nothing else the ease of having one type of oil in the garage for all the cars, synthetic 5w-30 all around.
I firmly believe it's a better lubricant, it's a cleaner product, it lasts longer between changes, and there probably are some very *small* gains in performance and mileage (but I haven't ever averaged it anyway, since I'm a leadfoot and get crappy mileage in the fun cars). I go to Walmart and buy the 5 quart jugs they sell there for 19 bucks. Don't bother buying it by the quart because it's much more expensive. A quart costs 5.86 at Walmart, and if you need 5 of those, you're looking at close to 30 bucks before tax.
I also run K&N filters in all my cars, down to my '88 Astro. I do notice gains, especially on the GAGT with a 5 inch round cone filter replacing the stock airbox. Sounds aggressive too.
I guess now is the time to switch I only have 20k on it. I am going to think about the K$N filter to.
Once again thanks
It's been a while since my last post, actually i was in the Mazda Millenia forum before... Got the Torrent '06 in Sept.06, sold the Millenia in Nov.
Anyway, so far so good. A few minor issues...
I am however watching the brakes on that puppy, hummm not so sure about their longevity.
GM HAS REPUTATION for using sub-standard discs so...
We'll keep an eye opened :shades:
I leave work, go the dealer, take the mechanic out for a drive again, only this time i'm driving!!! Oooops at 80-90km/h apply brakes there's the vibration again. took it back inside, for about an hour, they adjusted the rear(cleaning etc..) and lightly machined the front rotors
to remove some rust.(beware if you do a lot of short drives
7-12kms, it could also happen to you, humidity will damage your brakes due insufficiant heat to dry off any humidity.)
Same rule applies to the exhaust system.
I've looked into aftermarkets (already) and found the following http://www.powerslot.com/ which appears to be excellent unfortunately don't have for our Torrents , for now anyways.
Cheers :shades:
Did you or anyone notice that there's a second filter up in the air box cover? ( did you remove it or left it there?)
let us know !
Cheers :shades:
For the price of taking your vehicle in for a quick oil change, you can do-it-yourself and get synthetic.
Anyone else receive the RECALL notice about the ESC not lighting up even when it's disabled? I received mine earlier this week.
:sick:
Haven't called my dealer yet, but assumed (at this point) that it was the AWD system engaging and trying to limit the power to specific wheels in the back.
I also noticed that the tires that came from the factory are TERRIBLE in the rain & snow. I hydroplaned really badly the other day just with a little water on the road. Those tires are outta here.
Joe
Steering is unresponsive. Gas mileage is far below window sticker. Would trade in but I did a smartbuy and am buried. Worried about what will happen in next two years of my smart buy term. Anyone else have similar issues?
Thoughts?
Ellen
