Mazda 626 Electrical Issues
Hi, I'm new to this forum, looking to fix a really nasty problem on my 1999 Mazda 626 and I'm way over my head. I don't have money to take this to the shop, but my headlights are out so I can't drive at night, as a musician that ruins everything! (I'm only up at night!!!!!!)
Symptoms:
* right headlight is out
* left headlight flickers
* clicking or buzzing sound coming from the "headlight relay" which is in the main (engine compartment) fuse box
If the car is running you hear a buzzing sound coming from the relay and it flickers really really fast, but if the car is off when you turn on the headlights then it clicks instead of buzzing in that fuse compartment and the headlight flickers about 5-10 times a second in time with the clicking coming from the relay.
I checked the fuses in the main fuse box, and they're all fine. I switched the relay with the horn relay (same type) and the other relay did the same thing, so the relay is ok and it's just getting fed some bad electrocity i thinks. I switched light bulbs and the symptoms remained the same; the lights are not burned out. I also tried unhooking the hazard switch and dimmer from the dash but no effect (a n00b move i'm sure).
At this point, the only things I can see in the Haynes manual's diagrams shows me that it could be a short circuit somewhere in the wiring, (lots of wires to trace unfortunately) or the headlight switch could be bad (mounted on steering column) or maybe the CPU is bad. I don't really know how to test these with my multimeter.
No other systems appear to be affected; other lights work and I can drive the car in the daytime.
I should also mention that I just got done getting a new transmission, and then I took the dash apart and replaced burned out bulbs in the dash and also I rewired a new circuit from the battery through a 30 amp inline fuse and a 10-ga cable through the firewall to a new cigarette lighter receptacle and hard-wired battery chargers for my phones and laptop to that as well. Oh and I installed a new stereo and rewired the speakers. I just pulled out the 30-amp fuse to kill that new cig lighter circuit I had put in and nothing changed, and I'm pretty sure I did that right. Things worked for about a month after all that work I did, and just last night this new issue started.
I'm really over my head. I'm a musician and computer haxx0r and I fix my car when it breaks but I'm kind of a hacker here too and not really sure what I'm doing. I wish I could take this to a shop but I have a feeling it could cost $500 and I'm literally broke, so broke that now I can't go to sit in with some natinoally known musicians tomorrow and the next night because I can't drive and anyway I couldn't pay cover to get into the sessions. so I'm looking for advice to get these headlights working myself! I have plenty of electrical wiring and a multimeter and a soldering iron
can anyone help or point me in the right direction to troubleshoot this? thanks in advance for your help.
Nicole
www.nicole-sherburne.com
Symptoms:
Nicole
Well, it didn't just ground from the light to the frame. But I could tell I had a ground problem since putting an ohm meter between the ground post on the battery and the ground wires showed 55 ohms of resistance for the right light and 12 ohms on the left. That seemed not good to me, even with my limited experience.
I figured out that the grounds to the headlights are definitely switched. The hot wire is also switched, and determines whether the lights are on at all. Then there is a ground to high beam and a ground to low beam that are switched between to control high versus low, and so I couldn't just ground to the frame.
So I ran heavy gauge speaker wire (best I had since the other wire I had was 22ga) from the high-beam ground on the left light to the high-beam ground on the right, and the same for the low beams. the headlights now work 100% correctly and everything is ok.
I have no idea where those grounds eventually end up, since it goes through the switch on the steering column, so I didn't go to the trouble of making sure the rest of that is ok. If the left headlight's grounds fail then they'll go out again. But I'll burn that bridge when I come to it, the one good ground is handling everything just fine.
I swear I will never forget the ground again
Nikki the Invincable :shades:
Symptoms:
* clicking or buzzing sound coming from somewhere
If the car is running you hear a buzzing sound and it flickers really really fast and the headlight flickers about 5-10 times a second in time with the clicking coming from the relay. It doesn't happen when only the parking lights are on
1. the "charge" light and "rear" light come on.
2. Power steering is lost.
After I cleaned the battery terminal, this problem only exist when I turn the steering wheel.
I get 12V when the engine is off and 13.3V when the engine is on. I've taken the battery and alternator out of the car and had them tested at AutoZone. They are both good.
Thanks in advance.
Is the fuel pump supposed to be running constantly when the ignition is on and the engine is running?
Any suggestions as to what I should check next? I am considering bypassing the relay if the pump is supposed to operate anytime the ignition is on anyway. Good idea???? Please help
it would start sometimes first try and then sometimes second try and sometimes I had to wait a few minutes and try again, It also cut off a few times while driving and I had to do same . the problem I had to replace the whole distributor it cost a little more than 200.00 but everything works fine now
Today I have to miss a day of work to try to track this error down.
I have a 2000 Mazda 626 2.0l
Car started and ran fine.
I left my house.
I got 3 miles up the road and noticed my voltage up close to 16. (radar detector is telling me the voltage)
Then my radar detector threw a high volt warning.
Car down shifted, check engine light blinked, voltage dropped below 15.5, car shift back to normal and light goes off.
I turned around as i am 30 min from the closest town. Since it was throwing high volt i was turning everything on that i could think of to try to draw it down.
I could not go above 40mph.
As soon as i did the voltage would spike, and down shift, light blink, return to normal, normal shift, light off.
This happened for ~1.5-2 miles and then went back to normal and i could accelerate as needed.
Same symptoms happened when i first bought the car and transmission company told me it was my battery connection. 3 other companies later and i got the transmission replaced and there was nothing for 4 years till now.
I disconnected my Amp wire, pulled the fuse under the hood, and drove it around to no avail so i am pretty sure it is not the amp wiring causing the issue.
SO i am assuming i have an electrical issue somewhere... Any ideas?
One day I was driving it and it just dies...then it wont start...sometime later it fired up, then dies again...now it wont start at all...I have been workin on this car for almost 2 years..every mechanic that I now has looked at it, and none of them can figure out why I wont fire...please help!!!!!!!!!
I have checked all fuses and do not find a relay for the head lites. I have banged on the fuse box and tapped hard on the wiring coming from the head lites including the main harness. I banged on the head lite switch and ignition switch and nothing seems loose. no wires seem to be loose or plugs to wires everywhere don't appear to be corroded. I banged on bodyparts under the hood, but nothing points to an answer. the lites don't stay on very long before they go out for no reason.
My next step will be to look for ground wires to see if they are corroded or barely hanging on, but the visible ones didn't react when I banged on them hard.
Please let me know what you think. Thanks, Mr. B :mad:
Thank you for the info. My car runs great now and I will be taking it on a long distance trip to Miami soon. I will have a better chance to look everything over real good in the better climate.
Thanks again for your help. Sincerely, William Lichvarcik Sr. 216-240-2000
Its been a long trouble free time since my last post here. My wifes 94 626 LXA ATX Air Bag started lighting up last month. It flashes then stops then flashes again. Never stays on solidly.
Car has 88K miles on it and is in Athens Greece.
I cleared the codes with the battery disconnect step on brake pedal for 10 seconds trick. This stopeed it from flashing for a day and I
Brought it to a Mazda guy who tried to run diagnostics on it and it showed no codes.
It was not flashing when I brought it, and now 2days leter its flashing like crazy. He asked me if the I4 is a FS V or FS1 I did not know the answer. The 93 is a Ford EEC IV ignition so I dont think he will ever get any codes.
Unless the airbags are different from the OBD 1 system the only way I ever got codes in 10 years is the OBD1 jumping wire technique, and reading check engine light pulses
Any ideas ?
Does anyone know what the 1993 626 LXA I 4 engine is . Here is Vin if that will help
1YVGE22C2 R5204361
He said when light flashes that means airbag will not open. I am afraid it will open when wife is driving it . Is he correct ?
My wifes uncle said that flashing light means a sevice reminder based on age/mileage and mazda can reset it . I thought the battery disconnect would do it but its back so is there any way to reset it , or is it defective for real
SORRY ABOUT THE WORK INVOLVED, BUT THAT IS WHAT IT TAKES TO FIX IT.
A QUICKER ANSWER IS TO SELL IT OFF. THAT IS WHAT I DID WITH MINE.
I don't know if there is a co-relation between the miss-tarting before and the burning i have now. What can be the problem and how to fix ?
car worked fine then didnt anymore, it started then died out , would not restart til that evening, then died out again, within 15 20 seconds , then wil just not go again
