Hyundai Veracruz Real World MPG
Report your gas mileage here!
SUVs and Smart Shopper
http://www.fueleconomy.gov/mpg/MPG.do?action=browseList2&make=Hyundai&model=Veracruz 2WD
19.710
20.303
20.571
20.730
21.068
21.914
I am 60% hwy and 40% city, driving 73 mph on hwy. Remember, it is your driving habits and tire air pressure. I will try the synthetic oil angle after the breakin of the engine. I am very happy with the Veracruz MPG.
Moreover, it's pretty insulting, in my mostly worthless opinion, to deliver such vehicles to the public given what we are up against with impending fuel shortages. But the buying public just proceeds on......... with their blinders apparently fully intact.
No offense intended, but the manuf's and the public need to wake up. Times, they are a-changin.......
A Sienna or Odyssey or Entourage/Sedona would be fine if it was always on pretty smooth roads.
I understand that the internet is a happening place for advertising, but I almost never glance at the ad, and if I do it's for just a few seconds. TV forces you to see it for 30 seconds.
I have this theory that the Veracruz didn't have a "full" launch, i.e. the dealers around me only have a couple on hand, never the Limited models. So it makes sense not to waste a lot of money on advertising if you don't have the inventory...
When we see some TV commercials in next few months sales numbers should be even higher.
I hope Hyundai will ship enough VCs to US till then to satisfy the demand for it.
Over a total of 5k miles I'm getting 20.9 mpg - 70% highway/30% city.
I find the trip computer to be fairly accurate, usually within .5 mpg of actual, sometimes high, sometimes low.
Still running strong with 2700 miles racked up so far.
I would like to know what fuel VC owners are using? I read the manual and the regular unleaded is high enough octane...but, should I buy the higher octane gas?
Thanx for ANY advice.
nrzjago
As Shifty says around here, premium gas is not a doggy treat for your car. :shades:
Also, the a/c has a couple of features I would like some opinions on...first, there is the circle with an "A" (read up and it is to help keep air pollutants out)..then just the circle/arrows (recycled air)..and then just a/c with outside air flowing. Is one better than the other to improve gas mileage?
thanx!
nrzjago
I know the sticker says 18/25 for VC FWD....and I anticipate closer to 15 or 16 and 23-24.....but NOT 12 or 13. Could this be a mechanic problem causing the poor gas mileage....or does it need to BREAK IN?
PLEASE HELP!
You can also go to
https://www.fueleconomy.gov/mpg/MPG.do?action=browseList
and you can search mpg my make and model as reported by actual drivers.
Cheers,
MC
Took a long trip and got 23.5 MPG, and I get 19 around town. I cruise at 75 in a 70 and 70 in a 65 mile zone. AC running and outside temps in the 90s. I predict 24 and 25 in milder climates.
Of course, I am not a leadfoot. I keep tires at exactly 30 PSI and I use the cruise control, stay in middle lane and let all the speed demons go around me. I crank that great stereo, and the miles just roll along.
I agree, that six speed transmission is superb and probably contributes to the great mileage. You have to concentrate to feel the shift points. It is one of the best transmissions I have ever experienced. It will set the trend for others.
almost entirely city driving, AC going full force (it's close to 100 here), and a LOT of stop and go, and also the car was idle for about 15 minutes w/ engine running
Oh and this was the first tank
As far as gas mileage goes - inflate to maximum psi and put up witha harsher ride. The best compomise is split the difference at 37 psi, which I did. Will let you know how the first tank does.
PS - The car was deleved from an out of state location to get the Model, color and features I wanter. It had 365 miles on it and the trip computer read 20.1 mpg.
As far as gas mileage goes - inflate to maximum psi and put up with a harsher ride. The best compromise is split the difference at 37 psi, which I did."
This is really bad advice, and will shorten your tire life, worsen your ride, and compromise your safety. The proper inflation pressure for any vehicle is that which is on the placard on the driver's side door jamb. That is the manufacturer's recommendation and takes into consideration the tires which are installed, the vehicle itself, and the real life loads you will encounter. The owner's manual will back this up, as will EVERY tire manufacturer:
Michelin's Advice
Goodyear's Advice
NHTSA's Advice
I work in the industry and see first hand just how closely the auto manufacturers and the tire manufacturers work together to arrive at these numbers. The pressures on the vehicle placard will give you what the manufacturer and the tire companies have together developed for your vehicle--don't second guess all their efforts.
BUT ... it is not a magic number that does everything. If you want to improve fuel economy, which is the subject of this thread, you can by increasing the tire pressure, but at the (minimal?) expense of one or more of the other design components. How much is up to you, as long as it is below the Maximum stated on the tire. Added pressure will reduce rolling resistance and help your ties run cooler, extending their life. This not only made sense to me, but was recommended by my local Michelin dealer as a way to get the best mileage from my tires.
The recommend 30 psi works great as an all around setting, but the suspension and ESC features don't make for an unsafe vehicle if you increse pressure to by 7 psi which is also 7 psi under maximum.
