500,000 Mile Accord
Come watch as my car turns a 500,000 mile milestone. Ouch.
http://www.youtube.com/watch?v=aQL87mahgEg
Roy
I thought my 1996 4-cyl Accord was getting up there in miles, but sheesh!
I'll be watching your progress!
TheGrad
173,200 miles
Roy
Now there is a problem with
- Steering fluid leak and i just replace the fluid i think my mechanic said it would cost me about $600 or so.
- And my car always goes to the left i got a wheel alignment and wheel balancing and rotation but still the same.
Wonder if you can help me out with this problem.
Thank you,
As far as your specific issue, I really can't speak to that cuz I'm not a mechanic, I do Photoshop retouching as my videos would suggest. But get a second opinion if you aren't sure about spending the dough on fixing the car.
How's the rest of the car? Does it run well? Is it worth fixing? Is it paid off? All worthy considerations when spending money to fix a car.
Roy
I am just worried about the timing belt, last time i changed it in my nissan at 200K and after that it died at 250K. and all the problems started after the timing belt. i don't mind spending if it is worth it.
Roy
I would love for you to continue your video casts, say every 5k miles.
Let the whole world see how far your baby can go!
550,000? 600,000? More?
Another benefit is this:
The longer you hold on, the sweeter your next accord will be!
In 2009 an Accord Diesel is coming to the US.
It will feature a 2.2 liter engine that is the cleanest diesel in the world, and gets 52 mpg combined!
And since diesels last longer than gas engines, imagine how far a Honda diesl will go!
1,000,000 miles is not impossible! To the moon and back 2X over!
And If your diesel accord out lives you? Then you can pass it on the your kids as a kind of family quest to see how many times to the moon and the accord diesel can drive!
Ironically, the most likely limiting agent for such a car would be that in 42 years, 2049, fossil fuels won't be sold anymore.
BUT REJOICE! For algea based bio-diesel shall be widely available and so your diesel accord could drive on into the next century!
But to tell the truth, I was planning on a car that flys in the future. I mean that's what the movies in the sixties suggested.
Regards
Roy
1. Once you pass 500,000 miles send a communique to Honda Corporation. Your car would make a great series of commercials. Perhaps you could be sponsored by them: IE they will pay you for your video cast coopoeration in future with free Future Accord when your 86 model finally dies.
2. If you can hold out till 2009 and get a Diesel Accord, try to run it on the highest concentration of Bio-diesel you can. Here's why:
1. Where you live, San Fran, doesn't get cold enough to make gelling an issue, ie, no need to mix bio-diesel with any petro diesel to gurantee start up in cold weather, sub 30 degree F.
2. Diesel acts as natural lubricant, which is why oil changes with diesel are more rare than gas and why diesel engines naturally outlive gas versions.
BUT Bio-diesel is a much better lubricant than regular diesel. For example, when low sulfur diesel was mandated in 2008, oil companies had to find way of increasing lubricity of diesel, which, with lower sulfur would decrease.
They discovered that mixing just 2% bio-diesel replaced all the lubricity lost when decreasing sulfur from 500 ppm, to 15 ppm.
Bio-diesel is much better for your engine than regular diesel which is better than gas.
In fact filling up on too high a grade of biodiesel in a cr that has used petro diesel can cause the filter to become clogged with gunk that the bio-diesel cleans from the engine!
So if you run 100% biodiesel from the start, then you will prevent almost all of the build up of gunk in your engine, and provide crazy lubrication that will extend the life of your engine even longer!
So if your 21 year old, gas Accord can go 500,000+ miles, then a 2009 Honda Diesel Accord can probably make 1,000,000+ miles, and a Diesel Accord running pure 100% biodiesel could make 1.5 million+ miles!
TO THE MOON AND BACK 3X over! A CAR THAT COULD LAST FOR 60-70+ years!
A car that could last generations!
Imagine buying it for a young driver at 16 and it lasts them their entire life!
Imagine driving the equivalent of 60 times around the diameter of the earth at the equator!
Granted, most people will replace their cars every 10-15 years out of pure boredom, but imagine knowing that you could drive it 5 times longer if you wanted!
That is what awaits you Roy if you hold on and keep your sweet blue Accord!
Also consider this:
Having a car that has lasted 550K-600K leads to super bragging rights! It makes you a legend!
Buying a new car that would take you another 20+ years to reach that same level is ok, but loses the magic of driving a car that you described as a good friend.
Indeed if your car is older than your teenage kids,(not that you necessarily have them) is just plain cool due to its uniqueness.
I shall leave you with this image, from the classive Seinfeld episode in which Kramer goes for a test drive and he and the salesmen end up driving till the tank is dry and still make it back to the dealership, a feat both thought would have been impossible, (they had never driven a car with the gas guage stuck at "E" so long) but their initiall goal accomplished, rather than turn off the highway and into the dealership, the episode ends with both men turning to each other, grinning, and the driver gunning the accelerator.
That episode shows the courage and heroism of driving, literally, into the unkown, pushing the limits for the shear thrill of it.
You, Roy, are just such a hero. Both for initially holding on to your reliable car, where lesser men would have traded in a long time ago, and for not giving in to temptation once your goal is accomplished.
For daring to see just how far your 86 Accord can go, and (hopefully) for sharing it with an international audiance, via your video cast, you have earned a special place in the pantheon of automotive gods, along side diesel, Ford, Diamler and Benze.
If your tongue is any more in cheek it's about to poke through. Like the balloon one exhale till busting. LOL, I love the seinfeld picture. I missed that one.
But I must be critical of the car that last a generation concept. Your flaw lies in buying the car for any 16 year old. I think the life expectancy hovers around 10 months.
Now if they could swap out my gas engine for this bio-diesel motor, I'd be all over taking it 2 more times around.
My name along with Hyundai, Hugo, and Kia
Roy
As for my overexuberance, I apologize. I am just so damned excited!
I have long been a believer in buying the most reliable car available and seeing just how long they can go.
I personally drive a 94 Corolla with 165K miles and am hoping it lasts me to 250-300K, around 2012-2015.
I was not really hopefull that it could be done, but now seeing your beutiful blue Accord I find my dreams rekindled! Perhaps my baby can last till 2020 when plug in biodiesel serial hybrids will be available!
Oh to get 200 mpg on algea diesel, what a dream!
And if I end up with nothing more wonderous than a Civic or Corolla I will be able to wait for 2 more redesigns!
Oh what wonders does the future hold?
Self Parking cars?
Super advanced voice activiated computer systems?
Advanced saftey systems tied into a car intelligence network that makes accidents a thing of the past?
Cars that drive themselves? (How sweet it would be to let my car chauffer me about while sleeping or watching my favorite Tivoed tv shows, downloaded over a super fast and car accessible Hi-fi!)
But I fear I am rambling, it's getting late and I just finished a 12 hour shift at work and must awake in 6 hours for more.
So goodnight Roy and keep up your holy quest!
Your 86 Accord is an inspiration to efficiency lovers everywhere!
On Feb 17th, there is a post about an 87 Accord with 634,000 miles, still going strong!
Google "million mile cars" and you will find that the world record is held by a 66 Volvo 1800P with over 2.5 million miles on it!
To the moon and back 5X!
Roy, you must not get rid of your blue baby!
If a 66 Volvo can last 43 years, and an 87 Accord 634K with no major problems, then surely your car can go another 2-300K!
Imagine how sweet it would be to wait not only for the current redesign, including the diesel, but wait for the redesign after that!
Hell, your current accord may end up outlasting the Volvo and last you the rest of your life!
You must not give up on it Roy!
It is a rare breed of men/woman who are part of such an exlusive hyper high miler club, and you shall soon be part of it!
If you trade in your Accord you will regret not daring to discover how far it could go, how long it could faithfully serve you!
And if you make the right choice and decide to "Kramer it" until the wheels fall off, please keep us updated with future video casts.
No need for 1 ever 1K miles, or even 5K, but every 10K would be nice, you know to see how your baby's doing.
At your current rate of 500 miles/week it would mean 1 update every 4 months or so, a reasonable request for such an awe inspiring vehicle.
Good night Ray, here's hoping you eventually set a new world record in your 86 dream machine!
Roy
Loved your new speedo at the end.... I truly laughed out loud.
Roy
it to a co-worker. It still had an original
tranny & engine, P/S pump, starter, etc.
The steering fluid was slowly leaked.
I just kept filling when the fluid in the
reservoir went near the low mark.
New set of tires may fix the pulling to one
side.
Last time I checked the car still runs great.
Oh, don't forget to keep draining & filling the
tranny fluid every 24K miles.
Roy
One lonely night while coming home from North Dakota, on a straight stretch of road, with no cars in sight I pushed my 94 Corolla to its limit of 110 MPH!
What a rush! Of course as I was slowing past 85 mph I approached a car from the back and i turned out to be a cop!
Lucky for me I had never had a speeding ticket in my life and so got off with a warning.
But since you have a history and you know the fuzz are watching, you may not wish to push your blue baby that hard.
Just some friendly advice.
lol.... I think we've heard that before!
Roy
Roy
http://www.youtube.com/watch?v=ePXSqazfWrQ
Did I hear you say 410,000 miles at some point?
Roy
http://www.youtube.com/watch?v=8TcwNerncFs
Thanks for watching
Roy
http://www.youtube.com/watch?v=YTDpFZlo-ag
Roy
http://www.youtube.com/watch?v=wYG7jZnA5c4
Roy
Need a break from all the election tension? Then you need a Moon and Back fix my friend. Remember last time I spoiled the end of the great 500,000 mile roll when the battery died just at that most critical moment? Well, I’ve been able, through the amazing technical prowess of my friends at Lumeralis Digital, turn a disaster into... well another sort of disaster ready to assault your eyes and ears. So sit back and try and enjoy the last installment of the Moon and Back Chronicles vol. 12
http://www.youtube.com/watch?v=cpJkuqDkGgc
