My 2007 Azera rides really rough
I just bought a 2007 Azera Limited. I did my homework and found it to be all I wanted in a luxery car. However, once I took possession of it I discovered I felt every bump in the road. It did not ride like a luxery car should ride. I understand "stiff suspension" but I am really disappointed in the ride of this car. Maybe I'm the only one who feels this way, but has anyone else been bothered by the rough ride of their Azera?
Get yeh over to Pep Boys or some other source and purchase a good tire gauge.
Check your tire pressures when the tires are cold, before you have driven, and preferably when the car has been in the garage.
In other words, not out in the sun.
You have the factory 17 inch wheels.
This can and does make a slight difference due to the lower aspect ratio of the factory 17 inch tires.
I will bet that your tire pressures are far to high. The key here is experimentation!
HTHs
Problem is that the shocks are too stiff and springs are too soft for this car. Apparently too many Sonata parts used on a heavier vehicle. Go to
http://www.autobytel.com/content/shared/articles/templates/index.cfm/article_pag- e_order_int/2/article_id_int/2050. Chrisitan Wardlaw pointed this out in his review of the 2006.
It is still a very comfortable and enjoyable car over good roads, Unfortunately S.C. does not have many of those.
I then paid to have the rear struts replaced with the 040s. It did not make the near the difference as having the front struts replaced. Only noticeable difference is less wallow only at slow speeds. Doing the TSB is worth it since its free and makes somewhat of an improvement. But paying to have the rear struts replaced is definitely not worth it in my opinion.
RAV is much noisier, but felt better at end of trip than taking same trip in my Azera.
Read an article that criticized GMC adjustable lumbar seats as being uncomfortable.
Figure in the Azera, it's the seats, the heating elements, the lumbar adjuster, the suspension, the Michelin VR tires or a combination of all.
The center post has a nut with a green mark on it.
The round top plate under the nut has two green lines.
One of the three posts holding the strut has a green dot in the center>
Does anyone know what these marks mean?
Should they all be lined up together or in some fashion? They aren't now.
If the strut is new, why are the colors all the same lime green?
Thanks guys. I know some of you are tired of hearing me bring this up, but I really do believe it can be fixed and Hyundai (and we) will be the better for it.
BTW, got a reply from Consumer Reports re: their ratings in the April 2008 issue. Based on the fact there were few problems reported in 2006, but a lot reported on the 2007, they downgraded the 2007, but kept the high recommendations for the 2008 Hyundai. Weird! Sounds like a sampling problem to me.
