Chevrolet Blazer Key Stuck
in Chevrolet
Hi Gang, I have a 2001 SLT Jimmy (49k) with a problem. A few months ago I had to have my multi-funtion switched replaced, ok no problem, then about a month ago the key would not go to the "HOME" position unless I played with the shifter and/or had the right touch on the brake peddle. This happens occasionally, but of course, at the wrong damn time!!I've had 5 back surgery's so I really can't maneuver like in the past, so I have to count on someone else's judgment (GRRRR) and I've had sooo many differant suggestions and the installer of the MF switch feels responsable but management says differently,does anyone have an idea where I can check some simple areas to start looking before I attempt to get on the floor and become part of the truck until the ER squad has to get the jaws of life to get me out? LOL
Silverfox
Silverfox
thanks for the the tip and the time to effort to reply, much abliged!
Silverfox
If you put a scanner on the vehicle, it will give you about 10 transmissions codes.
The only thing that is wrong is the switch is shot. You have to pull the airbags, pull the steering wheel, disassembled the column and remove and replace the switch and accompanying harness. Watch out for sharp edges on the tye wraps...I almost bled to death the first time I did one...
The whole job is easy, just follow the right procedure when disabling and removing the airbag, or you could be in for quite a jolt!
THIS WAS SO HELPFUL I CANNOT THANK EVERYONE ENOUGH!!!
GOD BLESS
TIA
