Toyota Tundra Electrical and Lighting Questions
Toyota Customer Service recently advised me that foglights are only available from factory on new vehicle. Has anyone added factory fog lights using Toyota parts?
I think it sounds great. another added benifit is that the wife says it gives her a head ache so she will usuall stay out of my truck!
http://www.blinglights.com/tsdiscount/tundrahalo.asp
Is there any engine modification that will increase gas mileage (i.e., air filter cartridge, electronic tuning kits, etc.)???? I see all this advertised to increase HP, so it would seem that it would increase gas mileage at least on long highway trips???
All those bolt on products MAF, headers, exhaust, return a relatively low performace for the buck. If you want seat of the pants results, install that new supercharger that Toyota has for the Tundra. That one will surely put a smile on your face.
Is anyone else having a problem. This is my 2nd Tundra and probably my last.
I've replaced the rear brake lights (both sides) twice now. Every two weeks, one bulb goes out, I replace, then the other side goes out, and this process continues. Obviously its not a problem with the bulbs at this point, so my mind is going toward either fuses, or possible shorts in the electrical system. Has anyone had this happen or anyone have an idea if I'm on the right track?
On another note, my dash lights are starting to go out... the AC/vent controls are dark, and now the low gas light has now gone out. I've found the process for replacement of bulbs behind the instrument panel, but not for the low gas bulb (I assume I'll have access to it during the replacement of bulbs behind the vent controls). Again, am I on the right track?
Other than this stuff, the truck is a beast and will never die! :shades:
The 1st 8 failures were covered by my extended warranty and the 9th occured just 9 days after this warranty expired. I'm now facing the same $440.00 fee form the dealership to repair this door.
I've contacted Toyota Corporate about this issue and was told there has been no recall regarding this issue so I was on my own. Understandable if this was the 1st failure, however, they never solved the problem to begin with.
I'm going to continue to contact Toyota about this issue in the hope that I'll eventually talk to the correct customer service rep. willing to help.
If I don't get the results I'm looking for, this will be my last Toyota of any model.
HELP PLEASE
Thanks in advance
