Dodge Sprinter Engine Problems
HI,
I have a problem with Sprinter 2006 - 2500 model - 150 k miles. When temperature outside is above 75-80 the temperature of engine is going up
abot 30 degree only during driving on highway abou 70MPH. The situation make it worse after turning on AIR CONDITION. The temp is about to be on the beginning of 4 white parting. CHecked fans - OK coolant level - ok. Changeed thermostat. Cleaned radiator.
Thinking about changing the CLUCTH. IS it working on bematel and has variable speed????
PLEASE HELP !!!!
PLEASE HELP !!!!
2) Pull off the road very soon, while hot (don't shut down first). With A/C on and at hottest temp. get out (van in "PARK") and check that both the fans are running (aux. a/c fan and engine fan). Obviously the engine fan should be turning as the engine is running.
3) then shut down van. Grab fan (remember engine should be OFF), and spin by hand. If it spins easily and/or does not stop spinning very quickly, then the fan clutch is spent and a new fan clutch is needed.
4) restart the engine right away and let idle (or drive again) to let the engine oil cool down a little (and the turbo to cool off). As my dad has been warned on other turbo-diesels, don't go from full out hot-running to totally stopped without having a bit of run-down time to let temps stabilize at the normal values.
My sprinter also runs a bit hotter above 80 outside with A/C running, especially climbing hills (even gentle ones) as the turbo is running due to fuel useage to keep up speed.
Not likely to be water pump unless it is binding (you said no leaks, full system), also could be other accessory dragging and/or fan belt not running accessories correctly (cracked, glazed, worn to cord on backside).
Correct oil being used? also affects temps. Fully synthetic? Oil full, but not over full?
Best guess is same as yours I think: fan clutch.
Second guess is that the electric fan is not kicking in (I think it will run even with A/C off if the temp is going high. It seems to do so climbing steeper hills in 5th gear at 70-75 MPH).
Please let us know what you find.
KenB :confuse:
Additional Details
I drove this van for 4 hours already while the smoke was developed.
I bought my 2003 / 2500 van
at eBay. It had a terrible vibration when stopping and some
vibration at 2000RPMs when running. The local
transmission place here in Half Moon Bay, Ca. rebuilt the transmission at a
very high cost ($4200). The vibration when stopping is gone and only once
in a while I feel vibration when coasting at 20-30MPH. The problem I have
now is when it idles there is a low roaring (low harmonic) vibration at 1/2
second intervals, something like: ROW, ROW, ROW etc. if I increase the idle
100 t0 200 RPMs the roaring stops and sounds very nice. Question:
Can this be caused by the Harmonic Balancer? if so, I am afraid it will destroy
my newly rebuilt transmission also can the idle RPMs be increased and how this is done? Any suggestions/advise will be appreciated.
I am 60% done converting the van to a mini motor home for two, when it is
done I will post pictures and more yet plan to provide information, drawings
list of materials for anyone that wants to convert. Thanks
I have two 2003 3500 Dodge Sprinters that I've had since new. Both have approxmatly 150K miles on them. The first one developed a loss of power around 125K and the problem was traced to leaking fuel injectors around the seal for the injector and caused replacement of head, all injectors and injector seals. The dealer replaced these items. The second Sprinter has the same problem and I've removed the injectors. There doesn't appear any damage to the head and I plan on changing the seals,cleaning everything up ( looks like a coal mine under injector cover ) and reinstalling the injectors. Have any others had this injector problem and if so how did they correct it? Am I to expect to do this seal change as a maintenence item every 100K miles?
Thank you for any help.
1g8r
The temp dropped to -40F over night Jan 04-2009, the sprinter wouldn't start, now I have determined that the circulation heater must not be properly installed. My next step is to get an independent Mechanic to check the circulation heater.
Anyone have any suggestions?
bill and not under warranty, according to Chrysler. :mad:
I have had glow plugs swell in diesel cylinder heads making them impossible to remove or sheering off during removal and leaving the heat portion frozen in the port.
In all cases I have been able to remove them and the remaining debris without replacing the head; although in many instances I have had to do bench work on the head to clean it and make it serviceable again.
I am interested to know what has rendered the damage to the extent that the estimate is $6500--CURIOUS
Dennis
Patrick
$5,000 exchanged Plus Shipping.
$6,148 installed!
Pictures may be seen here.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=230383299630&- viewitem=&sspagename=STRK%3AMESE%3AIT
Location Toledo, Ohio 43612
Wayne (419)304-9996
Is this confusing you too? Bottom line: approx $5k to do. Anybody have some experience with this issue? I'm looking for some answers. Thanks
Truth is I have never seen any changes in the way that a motor runs when the calibration for each injector has been changed.
If you can get to Toledo, Ohio 43612 I can get this done for you for less than $3,000 and that includes the new injectors, injector seals, injector bolts, removal of the back death problem, resurface the injector seats so that this problem will not happen again soon, and also take care of the calibration issue for you. I assume at this point in time that this is a 2004-2006 Sprinter we are talking about.
Hope this helps, Wayne
Does anyone have any suggestions on what I should do? Is the dealership cheating me? Should they fix it for free this time? Should I yell at them and tell them they don't know what they are doing and go to a Mercedes dealer? Please let me know your ideas.
Andtay
Other things include, loss of vacuum at the turbo. Easy to check. Remove the vacuum at the line at the turbo. With the van running check to see if there is vacuum at the line. If there is no vacuum at the line, the cause that I see fail most of the time is the vacuum solenoid. It's located under the air cleaner. But check all of the vacuum lines for damage before buying a new one. Check all boost hoses one may have a split in it. Also it is possible that your boost pressure sensor has failed.
It is very hard to get all of the oil out of your cooling system once this happens. About the only thing you can do is keep flushing the cooling system untill it is all gone. Each time you flush the system there should be less oil in it. Is your van using more oil than normal? If it is not I would not worry about it. If it is or you think that it is have the cooling system pressure tested this should show if there are any leaks in the system. But my best guess at this time would be that the oil you are seeing is left over from the cooler leak that happened before.
dose anyone knows whats the best way to Flush the sprinter engine and also whats the recommended engine flush for the diesel engine.
Your condition is what we call blackdeath. This condition happens when the injectors seals leak. To fix this problem you should replace your injectors, bolts, seals and have the injector seats in the cylinder head recut. It takes special tools to remove your injectors when they get like this and also special tools to recut the seats. I have both. If you are ever near Toledo, Ohio 43612 I can help. Good luck, Wayne 419-304-9996
Sacramento, CA
Ron
Ron
Sacramento, CA
http://www.youtube.com/watch?v=ImZ6hlsojpE
954.34 shipping included 100 dollars core charge.
I have almost never heard of the turbo itself being the issue, but there's plenty of possible causes of power loss problems (hoses, sensors, EGR, DPF, turbo actuator), I've written up a post on my Sprinter RV blog discussing how to troubleshoot Sprinter loss of power problems:
http://www.sprinter-rv.com/2013/08/09/sprinter-losing-power-how-to-figure-out-th- e-problem/
Greg
Greg Keith
Boulder, CO
www.sprinter-rv.com
