Visitor Agreement.
Sticky Prius Throttle Plate
Bob Wilson
No dash lights would light up. My key fob would not lock or un-lock the doors I had to do that manually. My interior lights and brake lights would work, but no dash lights and the car just would not start.What could the issue be anyone know?
Prior to starting my car, my 2 year old was near the gas, break peddles. Could I have over looked the emergency break being pushed in or could this be another issue all together
My 2 year old was playing near the gas and break peddles and must of hit one or both buttons underneath the steering wheel. One button says ( Key) the other says (Reset). I never use my Key Fob in the so called Key ignition so I put in the key fob and pushed in the Key and Reset buttons and pushed the start button and the car is running fine now.
I hope this helped. Tell your dealer to look at the crank shaft sensor.
Cathie
Can you give a few more details on "running hard"?
Change oil AND filter at 5K mi. Drain while at operating temp ( the engine that is ).
You'd use this button also is you're going to leave the vehicle undriven for 4 weeks or more so that the 5 sensors don't run down the small 12v battery in the back. Upon your return you'll need to use the SKS fob as a normal keyless remote fob in order to get back into the vehicle, release the KEY button as you did, and reactivate the 5 sensors.
coolant flow control valve went bad. 200 miles later the belt
shredded. Replaced belt, thermostat, coolant, did diagnostic - no further issues.
I picked it up today and it didn't get 10 miles before apparently shredding the belt again. At least, when you look in the engine on the left side there's an obvious pulley and no belt was there. The engine really overheated and the same 3 warning lights came on - overheating. I'm having enormous problems getting the first service dept. to take responsibility. The national customer service is helping in baby steps. All this and I've got the top extended warranty but no one wants to just call the whole mess a warranty issue. Anyone have belt problems?
Computer misreading a sensor keeps the engine from starting and then the traction battery runs out 3-5 minutes later. Could happen at highway speeds. Got a lot of press four years ago. TSB=no problem.
Current Mileage: 187,000 Miles
Dealer Proposed Action: Replace the recharable battery ($4,300), run diagnostic and possible replace Inverter for another $4,200)
Here’s my predicament
Where do I start...?
I purchased a 2005 Toyota Prius New...it currently now has 157,000 miles on it. Was driving through the desert to Vegas and my light on the dash turn on (check engine light, vsc, red (!) ) and then my air con goes out...not good for a newborn in the car. Brought it to Fletcher Jones Toyota of LV. Told me that my Inverter water pump went out. $600 dollars later and back in Cali the next day...my lights turn on again. Take it to Hooman Toyota of Long Beach..stated that they just forgot to reset and didn't find anything. Same day in Corona, CA....light turn back on. Take it to Quality Toyota. Told me that the actual Inverter needs to be replaced for like $4k. I was hesitant and then drove it for about a month. On my way back from Van Nuys, lights turned back on and then I started to lose power on the freeway until it stopped completely. Weird thing was that a week prior to this occurring, when I was driving in San Diego, I noticed that the energy monitor was at full bars, which is very unusual; the newest development was that the engine would not turn, even at complete stops and the battery fan located near the rear seats will not turn off.
After cooling the vehicle for a few minutes, it would start moving again, but would die out after a few miles engine would have a high idle and then the car would no longer accelerate.
I then got the Prius towed back to Quality Toyota of Corona expecting to get the inverter replaced, but after doing another diagnosis, they told me that the rechargeable battery need to be replaced. They also mentioned that they will not know if the inverter needs to be replaced until they replace the battery, run a new scan and if it shows that the inverter comes up faulty, then I will need to replace the inverter as well.
I contacted Toyota about the issue and since I surpassed the 150k miles, they cannot warranty neither the inverter nor the battery. The battery alone is about $4,400 w/tax and labor and another $4k plus tax for the inverter. Not sure if the prius is worth saving at $8,400 even if I do have a carpool sticker.
Any thoughts or suggestions on what just might be happening for Toyota seem to be very questionable about their diagnosis. Any assistance is greatly appreciated!!!
SO PLEASE...if you have been diagnosed with another or cheaper way than my diagnosis...then I am all ears! Hope your diagnosis works for you and then I can try that vs doing my route.
Also if you are under 150k....Toyota should warranty the recharable battery & I think 100k for the inverter...so if it is...you might want to relay this to the dealer and see if this can get replaced on your vehicle.
Hope this helped!
Well if this fixes the problem, then Toyota HQ will hear an earful for I have an open case with them about this situation. My service director indicated that those were not the issue and that the codes pointed to the battery and inverter replacement. Will find out today.
Thanks for the reply and will keep you posted if it works or not.
Just got the update...replaced the camshaft sensor and got the software upgrade...the tech actually thought it did the trick, but after a few miles and going up a hill...car started to hiccup again and flashed the dash. When he got back, codes were saying that it was still the recharable battery. Well it was a $400 dollar experiment, but was alot better than hitting that $4k initial price tag. Any other thoughts or suggestions are duely appreciated.
JON
Toyota Tech is telling me that lights came back on and still reporting that the battery needs replacing.
I did a test run tonight and ran the car for over an hour at 80mph. Hiccuped a few times during acceleration, but held all the way. The main difference is that my energy moniter is acting more normal. Before the service, it was at fully green capacity...to the top for an entire week...not much power being transferred to assist the engine. That is now in the blue range which is working good.
The same or bad thing is that my engine continues to run while I am at a complete stop...a really slow idle, but never turns off any more. The other issue is that my recharable battery cooling fan in the back seat does not turn off. I am still contemplating on switching out the battery....I am also considering doing an aftermarket upgrade that will give me the first 60 miles on electric and then shift it over to the hybrid side...more costly, but feels like i'm tossing away my 4k with another toyota battery. PLUS, thier warranty for the battery is unlimited miles for up to one year. What happend to the 100k warranty...so if this fails after a year again, then I'm back to square one.
Sorry...just venting because this is the fourth dealer I went to...all with different outcomes....prius techs or just people guessing at the codes that pop up on the screen...your guess is as good as mine!
coverage on the grounds that it was commercial usage.
Try getting a Toyota rep to come to the dealer that was most cooperative.
I had a serious question when my 2004 was new and Toyota sent a rep to Glenwood Springs, CO, to drive my Prius up a long mountain pass side by side with the dealers demo to see if I had a real problem, which I did not. I now have 55,000 miles with the understanding that my battery is still under warrantee.
Police Help Stop Runaway Toyota Prius
i WOULD LIKE TO KEEP THE CAR BECAUSE CAN NOT AFFORD SOMETHING ELSE AND AM AFRAID OF GETTING ANOTHER TOYOTA. WOULD YOU TRY TO GET A SERVICE WARRANTY AT THIS STAGE OF THE GAME? WOULD ANYONE GIVE IT TO YOU? HOW MUCH DO THEY RUN? I AM JUST AFRAID OF MORE THINGS GOING OUT.
THANKS FOR YOUR INPUT
I have a prius that has over 177k...at about 151k, I got my inverter water pump replaced as well. That didn't solve the problem, then they told me it was my hybrid battery. Instead of spending over 4k, I found a third party company that provided both the battery and the ECU for only $2400. Now the dealer installed everything for $800 so total was $3,600...and that is with a new battery. I'm not quite sure why your ECU is not warrantied up to 100k? Also the battery is warrantied up to 150k (which I just missed). (TaylorAutomotive.com...just fyi)
So...the call is up to you. I actually had to go to four dealerships before they confirmed that it was the battery that needed to be replaced. First dealership was the Inverter, the other was the ECU, the other was a crankshaft sensor....
Not sure what to say shay 2...you should see what the original warranty covers for I got the platinum warranty and everything seemed to have expired just as the warranty ran out. I would simply suggest get a second opinion at another dealership and see what they find out and go from there.
Those of you you have experience filling a claim, perhaps you can share with us any procedure we need to do.
I am shooting for the entire repair that I undergone...all the way down to getting a reimbursement of the H2O inverter ($500) to potentially having a new Inverter replaced ($4,000 for the dealership informed me that that might need to be replaced next), to the radiatior I replaced a few months ago ($600) to the hybrid battery I replaced year ago ($4,500). The inverter was the first to go and then they stated that the overheating of the inverter might have caused damage to the other components in which I replaced. So skies the limit to take advantage of any costs that you replaced which was associated to the H2O inverter.
Hope this answer and others questions.
J
Graffiti1
You should contact your dealership again for there was another recall on the Prius Water Pump Inverter. This was actually my 3rd time replacing it...I did spend the $500 dollars initially BUT since there was a recall, I am submitting paperwork to get that dollar amount reimbursed.
it should be free to you if your vehicle falls under the recall. I too have a 2005 prius, so check with your dealership...if they still say the same thing, then contact another dealership and ask the same question. they should be able to see if your vehicle falls under the recall with the last 9 numbers of your VIN.
Hope this helps.
J
1. Make sure you get the software upgraded by your Toyota dealer. That should be a no cost upgrade.
2. I have ALWAYS been able to get it to start somehow, sometimes by playing with the start button which usually worked at least on the 5th or 6th try.
3. The one time it wouldn't start at all, I disconnected the 12V battery using the underhood red terminal. After an hour I reconnected it and everything was back to normal.
4. There may have been one occasion (in 2006 or 2007) when even that did not work so I left some lights on overnight so the 12V battery fully discharged. The next morning I jumped that battery with cables and everything was back to normal. There may have been still another earlier problem when I disconnected the hard drive under the passenger seat which caused a hard reboot when I reconnected it a few minutes later. I may be imagining this last solution.
5. I don't recall this happening again since then. I never had to get the dealer involved except to upgrade the software as mentioned above.
6. I do need a GPS map upgrade and will probably have to pay $250-350 for them to do that
Second is the keyless entry.. I have no idea why this is such a pain in the butt but I would like to have my care unlock all the doors since most often then not I am not the only passenger in the vehicle... Oh might I add that this car I go has no owners manual.
Third is the navigation/bluetooth/voice command system. How do you get the voice system to recognize your voice? I would like to use my navigation and other toys but the voice recognition is not working at all. I am not familiar with the commands but nothing is recognized. It look forever to get the bluetooth to recieve the contacts from my Evo. Now I have to use my phone almost as a remote.
Fourth and last thing that concerns me is the mpg. My car is currently getting 38.9mpg mixed. Most of my driving is on the highway during rush hour. Traffic has not been horrible so the average speed is 50-55. I know the vehicle is suppose to be getting 48/45mpg. This is a pretty large concern too.
