Volkswagen Golf Transmission Troubles
in Volkswagen
I just got a 99 golf 2.0l gas, cheep igot it for only $600, 213000 ks, but it will not stay in reverse, the sec you give it some gas it pops out, tryed to hold it in but no,all other gears work fine ? I can get a trany cheep, but I would rather not replace it unless I have too,
? thanks bill r
Like when I left the gas, there is a loud sound like as if ur sticking a baseball card in a bike tire and it's only when i let of the gas or if i am in neutral or braking coming to a stop and it sounds like its coming from right in front of me inside the engine area. At first my friend and I thought it was a wheel bearing, until yesterday. I was driving home from my friends house and my car was shaking like crazy when accelerating and it sounded as if something was dropping out every few seconds, like it was a big bang and then it would jump a bit. I came to another stop sign and went to put in first and let off the clutch and nothing happens i just revved the engine. So i tried it again, same thing, so i turned it off and tried again, nothing. So i put it in neutral and my friend pushed me to the side of the rode. I tried from second, nothing and then my friend pushing me got it rolling it a bit and i tried third, and nothing again. Then when we were sitting at a stop again, we noticed that when u let out the clutch all the way, while your in gear that the car doesn't even stall. So then I let out the clutch again and tried to go, and i revved the engine, and still nothing, but then we noticed that the Speedometer hit 30mph and i was sitting still. I don't think its the clutch because I just had a new one put on when I bought it 4 months ago. I think the place I bought it from sold me a piece of crap if you ask me, b/c i had to replace the clutch that same week, also i had to get my reverse fixed b/c when i would try to put it in reverse it would jump out of gear, so after i got that fixed the next day the check engine light comes on and i got it check out and my mechanic says the code is in Evaporated Emissions, also recently it when starting theres a squaling noise coming from the engine area and it sounds like its the air pump (which go for 849.99 brand new) and now this. The dealership i bought it from told me the evaporated emissions is my problem b/c thats something they don't cover so tough luck for me he told me. The car is just about to hit 100,000 miles... Anyone have any suggestions of what i can do?
you can message me back here or on aim at mael686
I just baught my 99 Golf and it has 86000 km and all of the sudden its making that same noise you guys are describing, ( like a card in a bike spoke) did you guys ever figure out what the noise was? i would like to find out sooner than later before it gets worse!! any info would be much appreiciated! Thanks Danielle
I have recently bought a 98 Golf Series 1 last Nov. About a month ago I had this weird bucking thing while driving, similar to other posts. Took the car back to the dealer and found out it was the oil cooler (heat transfer) unit. After finding water in the trans fluid and trans oil in the overflow tank he also said I need a new trans, preferably reconditoned one. Instead I got them to flush the trans and replace the fluid but the problem has come back two weeks later. The problem I have is that I didnt buy the car from a VW dealer but am paying for the extended warranty. The insurance company (for the warranty) said the oil cooler is not covered as it is not "inside" the trans, although I feel it is part of the trans. I have already spent $800 for the oil cooler and am looking at another $2500 for a recon trans.
Is this a common problem with the Golf? Will the problem come back again?
On may to the mountains the car started to get worse and the engine light came on. When I got to my destination I told my father and we put some oil in it and it seemed to work fine. When I got back home the car seemed fine for about 4 days even with AC on. On Wednesday the engine light came on after acting up. It now has problems even getting to 45 mph. It is on 4 rpm's when I try to go 60 mph.
I was wondering what could possibly be the problem and what your tips on solving it would be. I hate to spend massive amounts of money because this car has been so troublesome. Just wondering what the problem might be. If anyone has any ideas spill them, really curious what is wrong and if anyone else has this problem...
Auto gearbox reluctant to come out of second or third gear when engine or ambient temperature is high. oxygen and air flow metering system, between air filter and carb has been changed twice. Each time the car behaved faultlessly for two weeks, then back to old tricks. Can over come this problem by having the Air Conditioning on with blower on lowest setting.
Feels like a sensor or ECU has become heat sensitive, when air con comes on, both fans are working on radiator.
Any suggestions would be gratefully received
Cheers
H
I got bad news for you. Your guess is right. It probably is the clutch. When I had this problem it cost me 1300 USD to have the dealer repair it. Others in town didn't have parts to it, or were going to purchase it from the dealer also, so their quotes were similar. I was told it's an assembly, plate, wieght, and some other parts. The explanation I got is: that the clutch is electronic not a traditional cable so it's a complex job. It's not warranted since it's considered a wear and tear item like a brake pad or tires.
Good luck
my sister and her friend are touring NZ in a vw golf 1998 automatic
the owner is my sisters friend Courtney, they have always had trouble with the car eg abs light never turns off, the brakes occasionally kinda graunchs.
but the most recent problem is the car isnt selecting a gear at all, my sister has been driving it as its a manual as in 1st , 2nd, 3rd drive
every now and then it will work properly but it seems to bunny hop, kinda like the automatic clutch is letting out to early.
They took it to a mechanic and they said it needs to have a new air filter sensor which is 300 dollars, i don't know alot about vw but i don't know if that's really the problem
if anyone can help it would be really appreciated
cheers timcloake
I Have Golf 4 1999 , It Had transmission Gearbox problems 2 years ago,I replaced Whole GearBox kit,then same gearbox failed again 1 week ago,that I replaced with another New/used gearbox that Had reverse problem,solved after replacing with another Gearbox,these cars have nanufacturing defect,after passing the 100000 Miles , the gearbox starts giving failure ,sensor,and other parts,should be replaced as a kit to avoid wasting money like i did , replacing part after the other
Take Car
For long-term driving with lowest maintenance, an automatic xmission is not the right choice. Too many moving parts, too much maintenance and lower MPG as compared to manual xmission.
