Visitor Agreement.
Even at 3% over which is good, we need to drive this car first before I commit. I already pute money down on a 2002 Camry which will arrive in late November. If the CRV floats my boat I may pass on the Camry.
If the CR-V gets this type of response (which I'm hoping it won't), I really doubt that the CR-V's won't be sold at invoice. It wouldn't even surprise me that you would have to pay OVER MSRP, not just MSRP, if demand exceeds supply.
I've had bad experiences with most Honda dealers since I always shoot for the cars that everyone else wants. Plus the fact that I always demand 36 months financing at the lowest APR possible from American Honda.
fanatics keep you from enjoying life then they have won.We are all going to die someday and if
you live in fear you are already dead.Anyhow I like the looks of the CRV and have been a Honda fan for years.Do we know what the basic price will be? Any thing over 20 grand is overpriced
in my humble opinion.
An MDX+8" sounds good. Yes, demand for the Ody has outstripped supply, but they just started production at the 2nd factory.
Any how, now that demand is way down (for the entire industry), I think with two factories up and running they can finally get supply up to snuff.
If I decide to get a minivan, though we're still undecided on what type of vehicle we'll purchase next, the Ody would be a strong candidate if prices dip a little.
-juice
I only hope, even though it's based off the Odyssey/MDX, that it will offer true off-road capability with a low range as part of the package.
Bob
I frankly don't think Honda wants to build a true off roader.
Bob - While discussing future plans with a Honda Rep at the Mid Atlantic CR-V Meet, we were told not to expect an off-road package from the Passport replacement. This guy is just a Rep, though, so take it for what it's worth.
If so, they'd be following Toyota's strategy with the Highlander/RX300. That means good value for the Honda model.
-juice
Toyota thought its Sequioa would make a dent in the charts- and so far it's selling well, but not to the point where it threatens the Tahoe or Expedition.
http://www.usatoday.com/money/columns/healey/2001-10-05-crv.htm
Incoming...
Bob
I wonder, though, how significant the timing difference is for a RealTime vs. a full-time AWD system. Sure, every second counts in a slippery situation, but still, is it significant? I don't know; are we talking about a fraction of a second?
For 4WD and AWD system specific discussions, I invite all of you to also contribute to the 4WD & AWD systems explained discussion topic.
Drew
The delay might be an issue under very slippery conditions such as climbing a steep incline covered with loose gravel. The on-off action could result in a bit of a herky-jerky ride that may impair forward progress. Again, it's better not to slip in the first place.
Also, I've read that because RT4WD wasn't designed to be engaged full-time, it can overheat after long periods of continuous on-off cycling. One owner reported it being inoperative for a few minutes until the system cooled off after which it worked fine again.
Digressing a little here, but one other feature a part-time AWD system won't be able to offer is the inherent neutral handling characteristics provided by full time systems.
Ken
To the best of my knowledge, there are two reports of overheating. Hardly worth getting worked up about.
I disagree with Ken's speculation about the problem. If the system is fully engaged for long periods of time, then the two clutch packs are locked. There's nothing to generate heat. It would be the constant engage/disengage cycle that would generate heat. From my own experience, I've driven a constant 3-4 hours in 6" of snow on snowmobile trails without a problem.
I thought this bit was interesting: "Passenger volume is 106 cubic feet, qualifying as midsize." Anybody know what the cut-off point is?
However, if the system were to be fully engaged, doesn't that imply that the front tires need to be spinning faster than the rear tires the whole time? How likely is that scenario vs. constant on-and-off cycling?
Here's the write up I was talking about:
http://www.tiac.net/users/daveread/horta/comparo.htm
Ken
they judge it as ineffective and yet they
have not experienced it first hand.
look at them pix and movies in www.hondasuv.com
be it sand snow or mud, the cr-v keeps on going..
and going...
and going...
and going...
and going...
Bob
Bob
Drew
It's adequate- but no paradigm by which other AWD systems should mimic.
Yes, it's interesting that they went from the VC to the current set up. Not sure why they would do that since VCs are known for their simplicity and reliability. My guess would be that they had problems integrating it with ABS.
I guess the argument for better fuel economy also wouldn't apply since the previous generation was also FWD until needed.
Ken
I agree with Spyponder about the journalism.
I expect that the RT4WD is adequate 99.9% of the time. The writer was splitting hairs.
I know: What if my family is involved the other .1% of the time? Well, I guess I could drive a Hummer. That would probably be safer.
The writer's comments regarding RT4WD are based on a largely theoretical position. He is correct. A split second after slippage could be a split second too late. The question is a matter of degree. How often will it matter? Probably not in my lifetime, but the possibility is always there.
I was more interested in his comments about the automatic gear selector and the fact that it might possibly "spear" an occupant in the event of a crash. It would have to be an unbelted occupant, but how many people wear belts? Not as many we'd like to think. I'd have to see the set up myself (I suspect that it's too close to the wheel), but it could be a problem.
Diploid - I'm not sure if you're reading the comments wrong. The "old" system in this case is the one used in the old Civic Wagon. Honda also called that system "RT4WD". The CR-V uses a system that functions the same way (it detects slippage and engages), but it is mechanically different. It appears to be the same between 1st gen and 2nd gen.
With regard to proven reliability, the "new" RT4WD is also used in the Stream, other Civic models, and the Ody as well (though it's isn't sold here). All have strong records for reliable drivetrains.
I'd have to agree with Healy's comment about the CR-V's AWD system being one of the least effective for slippage, but it's also one of the most fuel efficient, reliable, and compact. So it depends on how you are grading.
Canadiancl: Take a look at the Accord V-6 as well as the Camry. Many feel it has more personality and fun to drive factor than the Toyota. I think its better looking too.
Does anyone else wonder why many reviews seem to mention 'odd' or 'extreme' styling cues?? If anything, from the photos it looks more conventional to me than the original. That's one area, exterior looks, where I think I may actually prefer the original. Hard to say until you see it in person though.
I'd say it's more just a matter of a difference of opinion.
Bob
dill6: Actually I have been also looking at the Accord V6. In fact in one of earlier posts (somewhere) I argued how it is hard to justify going for the Camry if you look at prices and compare it to the Accord feature by feature.
