Nissan Altima Sedan 2008-2009
Although I'm only 6'3", my legs are freakishly long
However, after a month, it became obvious that even with the seat ALLLLL the way back, I still lacked proper thigh support (even though we ordered the 8-way pwr driver's seat), and was getting an aching tailbone from having my knees in the air whilst driving.
So............... I took out the seat, and had 2 steel spacers made to bolt onto the seat rails, effectively elevating the front part of the seat cushion under my knees.
WHAT a huge difference!!! I love this car now
Not only does the seat now support my entire thigh, but I'm able to avoid sliding the seat all the way back (making more rear seat room). As a result, the shifter (6speed manual), steering wheel & 3 pedals are in PERFECT position.
I'm NEVER selling this car now :P
(now if I can just figure out a solution for the passenger seat that feels like sitting on a chair that's missing its legs.)
The passenger seat is bad, bad, bad...not only are you right about feeling like a chairt with no legs, but it feels like it slants forward as well. If just the front end could be propped up a bit, I think it would be a huge improvement.
I'm so glad I'm not the only one who feels the seat cushions are angled too downward toward the footwells. If you can come up with a good solution for the non-adjustable type seats, please LET ME KNOW!
On the ADJUSTABLE DRIVER'S seats, fortunately there are pivot mounts on the brackets so that if you custom-alter the bracket's front end, the rear of the seat bracket won't get screwed up.
As mine is now, all the adjustments work as before, the entire seat assembly is just leaning back a bit more.
(My current solution for the PASSENGER seat is to use an old-fashioned "wedge pillow" tucked under my knees when I'm riding shotgun).
I'm not sure whose odd anatomy was chosen when Nissan designed the seat mounting, but my much-shorter-than-me wife also feels the seats are tipped forward (our only gripe with the Altima so far) and she makes use of a wedge pillow, too.
Good luck & let me know. :shades:
So now it sits at the dealer, awaiting some parts so they can replace the entire clutch and I'm praying this isn't a sign of things to come.
Anyone have clucth problems with a 6spd?
scottgarz@hotmail.com
Trying to get a photo while the seat is in the car doesn't work, but I'll try to describe the alteration:
1) Turn OFF the ignition (to avoid side airbag deployment from seat)
2) Remember, this mod only works on the power adjustable seats\
3)Tilt the seatback all the way fwd (makes it easier to get seat out of driver's door)
4) Remove the 4 bolts holding the seat bracket to the floor
5) Undo the electrical connections under the seat (airbag wire & pwr wire)
6) Remove entire seat & bracket unit from car'
7) Once the seat is out, you'll see that the rear of the seat is connected to the bracket with a pivot Leave this part alone
8)Undo the 4 nuts on the front of the seat which attach the seat to the bracket.
9)At this point, I had a local welder make two 2" high spacers (from steel square stock he had) and he also extended the existing studs (which protrude UP from the seat brackets) so the 4 nuts would reattach to them. He extended the studs using threaded couplers available at hardware stores. You can't reattach the 4 nuts unless the studs are lengthened this way.
It will be obvious what to do once you pull the seat out of the car.
It helped that my wife was out of town for the week so I could do this mod while leaving the car stationary.
Just picked up my new 08 White Frost/blond leather Altima! This replaces my :lemon:
NissanUSA offered a new replacement at no charge and I took it.
I hope and pray that the problems with the little Precision Grey one were a freak of nature and isolated! :sick:
Thanks to all who read and posted responses....that means a lot to this newbie! I do like this site now that I have discovered it.
You can change wheels and tires all day long and not void the warranty, as long as the replacements are the general size and specifications as the original equipment.
However, if you replace the standard 16 inchers running 60 series tires with 22 inch rims with a 1/2 inch tire thickness, you probably will have a problem if the suspension has issues.
I called Traverse Motors and Steve in Service was not aware of that fix. He said that if I knew your name he could look it up and see what they did to your car. If you could, could you email me with possibly your name or if you could call them and have them email me with the info, I would appreciate it.
I am planning on bringing in my Altima this Friday, May 2, and want ammunition that other dealerships are fixing this problem and it is a known problem and they will take care of me.
Thanks, Fred Jerina (fredjerina@msn.com)
I have not purchased a towing package for my 2008 Altima yet, but expect to at some point to pull a lawn mower trailer. I have noticed a couple of vendors on the internet that sell a package for the 2008 Altima.
There is not, but there are 4 manufactures to choose from: Injen, Fujita, Weapon-R, and Stillen. Installing these will not effect the warranty, unless it's determined that the reason for whatever went wrong was caused by the intake. Fujita is your best bet, because they are all basically the same and it's the cheapest.
Good info: Intake info for Altima
In this era of horsepower & efficiency competition between the makes, I would assume the engineers had optimized most components like that. :confuse:
If you're looking for some aural boost from the QR25, beware that they don't sound particularly tasty (not like a rev-happy SR20DE or Honda S2000) when they're louder.
Trust me, I absolutely Iove the very ample low-rpm yank from our Altima 2.5, but it's better felt than heard.
I do have to disagree with you on the sound though. With the stock intake when you get on the gas, you hear the car rev up and it sounds like a weinie car...thanks to the 4cyl. Throw on the SRI, and you get a much lower tone, somewhat throaty, and not near as "weinie." This can cause a lower mpg though, because you find yourself wanting to hear that beautiful sound, so you get on it a little more often.
Also, it's a heck of a lot easier to see when the filter is dirty, and clean the filter. (don't have to buy new ones)
I've gotten aftermarket intakes on my last 3 cars, and will continue to get them on all my future cars.
However, I have noticed (similar to comments posted in some other threads around here) that when I get the car moving over 30-35mph, I hear a high pitched whistling from outside the car. If the windows are up, you can't really hear it... but with the windows down, even just a little bit, it's loud enough to be very obnoxious. The pitch changes with the speed and the gusts of wind, so it must be a gap or hole somewhere that's making the sound.
Do other people have this problem, and what have you done about it? I suppose I'll bring it back over to the service department and see what they have to say... but before I do, any advice on what to call this problem would be greatly appreciated.
Sorry I couldn't be more helpful...
Does anyone know? Thank you!
Do you have a sunroof? If so, is the noise the same with it open, tilted or closed?
Are all the windows completely open when you hear it, or only the front?
I have a pretty good ear for car noises, but I swear I haven't heard anything like what you all describe here...maybe I'm just lucky...
This is certainly NOT TRUE!
Your warranty will be honored by any Nissan dealer and the factory simply by documenting any service performed by yourself or by an independent mechanic.
Any warranty requirement that dictates specific products or services be used on your car must be provided free of charge by the manufacturer. For further info read up on the Magnusson-Moss Act.
Read your owners manual to see if there are any restrictions on type of mechanics used. Most manufacturers merely state the independent mechanic must be ASCE certified, or something like that.
If anyone just recently purchased an Altima i would love to know what you paid for similar options.
thanks in advance
TPS tire pressure sensor equipped
1. Brakes were squealing and shuttering under any sort of brake pressure.
Solution: Brake rotors had to be rotated and brake pads replaced at around 11k miles
2. Annoying rattle coming from rear right door panel.
No solution yet.
3. Loud "Thunk" noise coming from under the hood at 1-2 minute intervals during driving and idling.
No solution yet.
4. (just found this today) When starting the car from a cold start, the rear right exhaust (sounds like it's coming from inside the muffler) makes a metallic rattling noise. It sounds like either something is loose or something is stuck in the muffler.
No solution yet.
I'm calling the dealer in the morning. I'm also really tempted to start looking for a new car. While the car drives just fine, it seems like everything is going wrong with it. What's even worse is that I only have a little over 16k miles on the car, and I was planning on keeping this car for at least 4-5 years. Now I'm not so sure anymore.
I wish I had bought an Accord. :sick:
They replaced the right rear door panel, so the rattle is now gone!
They also replaced the right rear muffler, so the exhaust rattle is gone too!!!
For some reason, I think most of the rattles were stemming those areas, because on the way home from the dealer (roughly 30 minutes) I heard no rattles or squeaks in the car!
My faith in Nissan is restored for the time being. Maybe it won't show up again.
Mine just started doing that a few weeks ago! I wasn't sure if I was just imagining it, or if there was a real problem!
So, you say it's the heat shield over the muffler... and that if they tighten it, that should fix it? I'll make note of that, and next time I bring it in, I'll let them know.
Thank You!
See you there!
